Old 03-17-2013, 03:09 PM   #31
nick949eldo
Oddometer: 1,106
Don't you dare!
Originally Posted by BOOTLACE View Post
Hey guys and girls, from the land of OZ, I have a VERY sweet V7 Sport,(1973). Unfortunately I can't seem to come to grips with setup of the 4LS front brake. (We have WOMBATS here, and brakes are kind of handy....)
I believe the later models into the U.S. had an option of a twin disc front end. I could do with that lot, so's I can ride my sweet Ruby on a more regular basis.
So. If anyone might happen to come across a disco front end to suit, I'd love to hear....
Hello Bootlace,
The 4LS brake on the V7 Sport (same as on my 74 California) can be a very effective brake. It is at least as good, if not better than the single disc setups on the later Loops - if not quite as good as the double discs on the later models.
My advise would be to find someone in Oz who can set it up properly for you. Its part of the bike's history and origins and it would be a shame to abandon it.
It can be very effective - you just need to find out how. Have you tried looking for advise over on the wildguzzi forum (http://wildguzzi.com/forum/index.php?board=1.0)? There are many people there who can, and probably will help you.
Lastly, wombats, badgers, raccoons, deer - hazards to riding all. Perhaps an adjustment of riding style is as much in order as a brakectomy.
Nick
nick949eldo is online now   Reply With Quote
Old 03-17-2013, 03:51 PM   #32
davebeef
Buffoon
davebeef's Avatar
Oddometer: 274
Kev,
My non Guzzi owning mate reckons I should remove the heads, check the barrels and if ok do the oils and try to fire up to see how the land lies. This before stripping to do Gilardonis.
What do you think??
DB
'70 Moto Guzzi Ambassador, '78 FLH Shovelhead
'81 BMW R100, '79 MZ 250/1, '81 MZ 250/1
davebeef is offline   Reply With Quote
Old 03-18-2013, 04:09 AM   #33
BOOTLACE
Bikie Scum.
BOOTLACE's Avatar
Oddometer: 4,460
Originally Posted by nick949eldo View Post
Hello Bootlace,
Nick
Yeah. I know where you're coming from, just I get a bit pissed orff with it occasionally.....WILL TRY HARDER!!!!!!
bootlace
BOOTLACE is offline   Reply With Quote
Old 03-18-2013, 05:36 AM   #34
danedg
Horizontally Opposed
Oddometer: 6,775
Originally Posted by davebeef View Post
Kev,
What do you think??
DB
Dropping the fluids before attempting to start would be recommended. Run them through a fine mesh paint strainer. Look for debris, shavings, etc.
Stick a wee magnet through the spark plug hole. Heavy attraction to the cylinder wall indicates steel liners. (Good) Mild attraction to wall indicates chrome liners. (Bad) No attraction indicates Nikasil liners. (Very Good).
From the looks of the bike, you've many hills to cross before firing it up and taking it for a spin around the block...
Patience grasshopper
If you can't stand it and must hear it run with no silencers, remove spark plugs and a head cover and turn it over
until you see oil pumped to the head. Your oil pump needs a prime after sitting so long...
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic, '78 Honda Hawk...... the Axles of Evil!
danedg is offline   Reply With Quote
Old 03-18-2013, 11:56 AM   #35
England-Kev
Oddometer: 3,749
Kev,
What do you think??
DB
Don't do it Dave!
By all means pull the heads and barrels etc, you will need to do this anyway to fit the new ones, and don't just change the oil, drop the sump, and give it all a good clean, ready for when you have it ready to go, otherwise you will be pumping all that old crud that has migrated to the bottom, back around the motor.
take your time Dave it will be worth it.
England-Kev is offline   Reply With Quote
Old 03-18-2013, 12:56 PM   #36
davebeef
Buffoon
davebeef's Avatar
Oddometer: 274
Cheers guys. Yeah I would drop the sump to clean out, de- crud carbs etc however if everything else seems ok inside and assuming the chrome is not flaking off the bores I would like to hear it run just to see if bottom end strip required. I would rather not do this if not required. I'm not interested in making this a show queen by the way. I like my bikes to look rough and original. They're more talked about that way. Mechanics have to be good though.
DB.
Old 03-18-2013, 01:59 PM   #37
danedg
Oddometer: 6,775
How many miles are on that thing????
There ain't no oil filter and everything else depends on a series of sludge traps.
Face it Man. The whole thing will come apart sooner or later if you intend on riding it.
You've GOT to clean the bugger out/up!
Old 03-18-2013, 11:29 PM   #38
davebeef
Buffoon
davebeef's Avatar
Oddometer: 274
Fair enough i'll pull it down. About 50K on the clock
Prepare for a bombardment of quetions now........
Rgds
db.
Old 03-25-2013, 05:55 PM   #39
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Does it count if it was a while ago?
Before as seen in the "basic guzzi info please" thread:
After:
MZ Rider (Hi Charlie ) did the engine and clutch for me. Charley Cole did
the final drive and the transmission, http://www.zydecoracing.com/home.html
I had a few others help with paint and powdercoating and I got to put it all
together. Started December 2007. Finished ??? It's a Guzzi hence a kit bike
that's a work in progress and a great learning experience.
AMA 'MOA
ECEA 'RA
ARRA DHMC
TCSMC: teamhammer.org
"I'm a choker!" ask me how
"They're ALL dirt bikes.....some work better than others"-----Harley Huey
deerslayR is offline   Reply With Quote
Old 03-26-2013, 10:28 AM   #40
England-Kev
Oddometer: 3,749
Originally Posted by deerslayR View Post
Very nice job, I love that maroon colour
Old 03-28-2013, 01:28 PM   #41
deerslayR
Spodely Adventurer
deerslayR's Avatar
Oddometer: 3,028
Thanks, Kev, It's actually a colour used by 'Guzzi for the early loop
frames, think V700. Glasurit by a guy who does BMW and Acura cars for
a living. It's the prettiest bike in the barn, although I like the patina on
the original Honda Super Hawk a lot.
AMA 'MOA
ECEA 'RA
ARRA DHMC
Old 03-28-2013, 07:15 PM   #42
lockyv7
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 1,067
Boot, give me a call and i can tell you how its done, the right way. locky.
lockyv7 is offline   Reply With Quote
Old 03-28-2013, 07:26 PM   #43
Lomax
Nanu-Nanu Adventurer
Lomax's Avatar
Oddometer: 9,344
I may join the fray this weekend. There is a 72 Eldo for sale here locally with 21K miles on it that does not look too bad. I am concerned about the chrome bores but it has laways beena a Colorado bike and it is dry here.
So before I make a total fool of myself, and with the great experiance here, What should I look for that would make or break the deal.
Marc
84 R100RS LE,14 Ducati MTSGT, 73 850 Commando, 78 CT90, 14 Ural, 74 Eldorado police, 64 R50/2, 13 TR650, 01 DRZ400E, 94 900SS/CR
Lomax is offline   Reply With Quote
Old 03-29-2013, 05:44 AM   #44
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 373
Marc
The usual stuff, plus: clunks in the U-Joint, slop in the rear-wheel splines, chrome panels on the tank, stripped generator mount bolt holes in the block, decent sheetmetal. Trust the chrome not to flake at your peril..
Life's too short.
F_Sahms is offline   Reply With Quote
Old 03-31-2013, 08:12 AM   #45
Bloodweiser
honestly
Bloodweiser's Avatar
Oddometer: 2,628
After:
Goddamn. I remember when you got this.
'07?
Congrats
Bloodweiser is offline   Reply With Quote
Times are GMT -7.   It's 04:51 AM.
