01-10-2013, 05:21 AM
#1 |
Oddometer: 2,486
The issues of fuel injectors and "adventure" bikes
Granted, this is coming from racing, but the issues that James West (and others?) had with clogged fuel injectors (KTM bike) in the current Dakar terrain (by only stage 5), and his explaining of it not being particularly a quick thing to have to change out an injector, has me questioning the need for, or role of, fuel injection for the average non-supported guy who is adventure-traveling through the middle of a sandy or dusty nowhere... most likely without a spare injector.
It seems to me that carbs are a little more forgiving to finer dust particles, and a single carb is, of course, the simplest device to use or maintain to keep a bike going. So if total HP isn't a huge factor in adventure riding, where instead actually making it to a destination can be close to a life or death factor, why would I want fuel injectors again? |
01-10-2013, 08:28 AM
#2 |
Oddometer: 3,377
It goes without saying, the more complicated something is, the more susceptible to failure, and the more difficult it will be to repair.
So the real question is if EFIs advantages outweigh its possible liabilities as you will actually be using it. Do you plan on doing the Dakar, or just doing occasional unpaved roads? Carbs appeal to me because they will basically last forever, don't "break down" and will survive serious abuse, but I also recognize EFIs advantages in power and economy that it provides in normal real world conditions.
"Take care, sir," cried Sancho. "Those over there are not giants but windmills". |
01-10-2013, 09:31 AM
#3 | |
Oddometer: 1,561
My fuel injected dirt bike hasn't had a single hiccup in the fuel injection, so I'd be fairly confident to run FI on an ADV rig.
I'm not so sure I'd consider a carb less complicated than fuel injection, just more well known and familiar. I'm geek so digital tech doesn't really bother me.
I say we take off and nuke the entire site from orbit. It's the only way to be sure
01-10-2013, 09:37 AM
#4 |
Rectum Non Bustibus
Oddometer: 3,520
Dust in the air doesn't clog injectors, stale fuel or filthy fuel does. Ideally, the refueling setup should have better filtering and the tank vent system needs a fine filter on it as well. Sounds like poor preparation to me.
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher |
01-10-2013, 09:40 AM
#5 |
Oddometer: 17,983
My Adventure bike is carbureted. Gravity never breaks.
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind." — Dr. Seuss “Watch out for everything bigger than you, they have the "right of weight" Bib |
01-10-2013, 09:46 AM
#6 |
Oddometer: 52
I'm with Dakez on this one! For an ADV bike I would not want injectors or a fuel pump to have to consider.
Why build a system for what you can get for free.
#7 | |
Oddometer: 2,486
I guess I was asking more for if I ever am able to travel abroad and start putting in dirty fuel, or fueling while in some type of dust storm. I'll take your word for it that stale or dirty fuel caused West's clogged injector, and that fuel injection isn't a problem for traveling through, say, Haiti. |
01-10-2013, 10:00 AM
#8 |
Oddometer: 17,983
Coffee filters work great to filter 3rd World gas as it is poured into the tank.
01-10-2013, 10:09 AM
#9 |
Rectum Non Bustibus
Oddometer: 3,520
Melitta plastic filter cone and paper filters. Cheap and light.
01-10-2013, 10:23 AM
#10 |
"Cool" Aid!
Oddometer: 41,497
If you are not racing it isn't an issue. You can cary a spare, or clean it along the way. Knowing what you are doing is the key factor for a traveler.
Jim
01-10-2013, 10:56 AM
#11 |
Paint it black.
Oddometer: 12,863
Racing has nothing to do with it, Jim. Where and how a person rides...empty lonely places of the west, alone...give me a carburator over FI any day of the week.
01-10-2013, 10:57 AM
#12 |
Brett
Oddometer: 4,710
I do not think FI adds any power on its own.
And the injectors are not what I would worry about, its the fuel pump that gives more problems, bigger to carry, harder to replace. FI is good for altitude changes and convienience, push the button and go, but otherwise its just something ready to go tits up. And don't compare a crappy cv carb to FI, compare a good pumper carb to FI. CV carbs and FI came around to improve emissions, then both were set lean. There is nothing worse in my book then a lean sluggish CV carb. |
01-10-2013, 11:39 AM
#13 |
Oddometer: 867
I'm willing to bet that everyone that thinks carbs are better are over 60. Maybe 50.
Injection works better, everywhere. Get better fuel filters. And my carb'd 950 has a fuel pump. I bet you guys also griped when electronic ignitions replaced points (can't fix it by the side of the road!). Move into the 21st century, because they are not going back to carbs, no matter how much you 7 or 8 guys cry about it.
Ducati S4 916 is history. KTM 950 SM, my main squeeze now. 1970 CT-70 And now, an XR75, |
01-10-2013, 11:52 AM
#14 |
Oddometer: 52
I'm 29 and choose Carb for ADV, Street Bike/high performance track bike and I would change my tune.
01-10-2013, 11:55 AM
#15 |
Oddometer: 1,115
I always said carburetor was French for "don't touch this"
The reliability of both I think is proven, racing probably isn't a good example to compare to real world usage. My last ATV and my Jeep are fuel injected....both saw some horrible conditions (okay not third world but beaten off-road) without a hickup. The Jeep is 15 years old and hasn't had ANY fuel related issues...probably should change that factory fuel filter one of these days
"I don't ride to be seen....I ride because I want to disappear...." Halfthrottle "The difference between genius and stupidity is -- genius has its limits." ~Albert Einstein |
