Old 02-13-2013, 08:09 AM   #1
tyluk OP
That's what she said
tyluk's Avatar
Location: Winter-Rocky Mountains, Summer-Spraying the Crops
Oddometer: 124
Short on Time and Wondering Should I buy a 2004 KTM Adventure S GO!!!!!!
I've been doing a little research but wanted to get some opinions also. I found the deal yesterday and have to get a deposit on it today just because the bike is kinda far from me but he can ride it closer (so it'll only be 12 hours away) but he has to leave tomorrow for it to all work out. Anyways, it's a 2004 GO!!!!! model with 9,000 miles. It comes with a steering stabilizer, Renazco seat, Zip Ty axle blocks, KTM hard bags, extra set of brand new tires, FMF exhaust, and Noleen suspension. It has some light scratches on one side but not bad. He is the second owner his friend being the first. He said none of the tech bulletins have been done but he does have an extra water pump for it in the box for when this one goes bad. He will take $6500. So what do you guys think of all this? What will it take to get the tech bulletins taken care of? Thank you in advance.
tyluk screwed with this post 02-13-2013 at 08:22 AM
tyluk is offline   Reply With Quote
Old 02-13-2013, 09:07 AM   #2
charlie264
charlie264's Avatar
Oddometer: 8,365
I could be wrong but I thought KTM covered the critical/safety updates? Mine 950 stopped burning oil at 9000 miles....
Old 02-13-2013, 09:15 AM   #3
Deuce
Crazy Canuck
Deuce's Avatar
Oddometer: 2,829
Buy it!
I wouldn't even worry about the water pump. The only tech bulletin I would want done would be the starter sprag clutch update.
I'm not lost for I know where I am. But however, where I am may be lost.
-- Winnie the Pooh
Deuce is offline   Reply With Quote
Old 02-13-2013, 09:24 AM   #4
RB450
RB450's Avatar
Oddometer: 296
Good price! The clutch cover doesn't even look worn.
RB450 is offline   Reply With Quote
Old 02-13-2013, 09:24 AM   #5
crazybrit
crazybrit's Avatar
Oddometer: 8,559
Does this apply to the 2004? I thought it was only for the redesigned part in the 05.5/06.
I *believe* if the TSBs have truly not been done, the dealer will do them regardless of the age of the bike. If you are concerned, get the VIN, call the dealer and they'll plug that into dealer-net and let you know what has been done and what needs to be done.
Price seems good given that it's the desirable GO! and has low miles and good accessories.
crazybrit is offline   Reply With Quote
Old 02-13-2013, 09:34 AM   #6
35xj
Oddometer: 914
great price! grab it
35xj is offline   Reply With Quote
Old 02-13-2013, 09:36 AM   #7
tyluk OP
tyluk's Avatar
Oddometer: 124
Okay I just called the dealer here in town and it's had 2 tech bulletins both of which have been taken care of. One was for a fuel tank connection and the other was a redesigned brake caliper for the rear brake.
Old 02-13-2013, 09:42 AM   #8
beergut
Thumper
beergut's Avatar
Oddometer: 414
based on what you've said, I would go for it.
My only concern, sometimes low miles can actually be a bad thing. -Parts are designed to be moved.
My KLR
beergut is offline   Reply With Quote
Old 02-13-2013, 09:47 AM   #9
crazybrit
crazybrit's Avatar
Oddometer: 8,559
I thought there was a cylinder head nut TSB for the older bikes. Also you'd want the generator bolts TSB.
http://ktm950.info/how/ktm_950_issues.html "Leaking head gaskets" "Freewheel bolts" "Crankcase Ventilation"
It's unfortunate that they did the fuel-tank connection one, it's actually the one that you'd like to avoid.
Anyways, the above is nothing that would turn me off the bike, but I'd check on the above three TSBs and see if the dealer will do them, else I would do the flywheel bolt one yourself, there was a recent thread about what happens when they back out.
Old 02-13-2013, 09:48 AM   #10
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,480
I have had the 04 GO!!!!!! since new. 70,000 now and as happy as the first day. The starter sprag was not a problem on the 04's. In fact that wasn't a problem tell 06 (the clack clack when starting, right).
The only TB you need to have checked is the freewheel bolts. They used the wrong locktite and need to be updated to the 648 locktite.
Looks like a really nice buy BTW.
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is offline   Reply With Quote
Old 02-13-2013, 09:53 AM   #11
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,732
Buy It. If you dont send me the info and Ill pick it up.. You wont be sorry
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 02-13-2013, 09:56 AM   #12
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,480
Check the size of that front wheel. Maybe just the pic, but it dosn't look like a 21 in wheel. I would think that would make the bike handle quite strange.
Old 02-13-2013, 10:08 AM   #13
tyluk OP
tyluk's Avatar
Oddometer: 124
Do you know why the dealer would not have these TSBs in his database for the serial number? Do some of these only apply to certain serial numbers?
Old 02-13-2013, 10:12 AM   #14
tyluk OP
tyluk's Avatar
Oddometer: 124
Wheel
It's got a 19'' front and 18'' rear. Is this normal?
Old 02-13-2013, 10:14 AM   #15
crazybrit
crazybrit's Avatar
Oddometer: 8,559
No. 21"/18" is stock. Many people install a 19" front (for street) but it's combined with a 17" rear. If he's keen to sell, I'd negotiate over this. You can get a 21" front easily enough and you'll be half way to a second 19/17" setup
http://www.advrider.com/forums/showthread.php?t=439443
No idea. Ask the dealer. Like I said, it wouldn't worry me. The only one that is critical is to re-loctite the generator bolts. Someone was selling a used bottle of the special locktite here recently for a good price, I can dig out his name.
Times are GMT -7.   It's 11:31 AM.
