02-15-2013, 03:11 PM
#1 |
Oddometer: 266
9 month old shorai needs a charge. Help...
05.5 950A won't start. I just installed the $$$ Shorai 9 months ago. No problems until now. I have a shcumacher charger. Any charging tips?
Deepc screwed with this post 02-15-2013 at 04:29 PM |
02-15-2013, 03:35 PM
#2 |
Oddometer: 217
Read this http://www.batterystuff.com/blog/can...y-shorai-.html you really should buy their charger since it is a charger/tender and reduces the oops factor.
2013 KTM 690 (Thanks FLHRCI Buyer! ) 2011 990 Adventure Dakar (Thank you Honey!) 2010 Aprilia RSV4 Factory 2010 Ducati 1198S |
02-15-2013, 03:54 PM
#3 |
Oddometer: 266
Yes. If I could afford the shorai charger I would use it, but right now I'm stuck with a schumacher ship/shore speed charger. My choices are 2A trickle, 10A medium, and 15A Deep. Also, have a option for standard, agm, or gel cell.
Deepc screwed with this post 02-15-2013 at 04:32 PM |
02-15-2013, 04:05 PM
#4 |
Oddometer: 217
If it was my battery I'd contact Shorai about using that charger,
02-15-2013, 04:26 PM
#5 |
Oddometer: 266
I hear you about contacting the manufacturer but I'm kind of in a "Spot." I know some guys have had some luck charging these things on a standard charger. I've set it to a 2A trickle on the standard setting. This battery had been great until yesterday.I have heated grips on the switched circuit so that shouldn't be a problem.
02-15-2013, 04:34 PM
#6 |
Let go of my ears.
Oddometer: 1,110
If your bikes charging system can charge the battery, then any standard charger should be able too as well. However, The Shorai specific charger is better, because it's supposed to charge the battery cells evenly. One big thing I did notice about the Shorai I put in my KTM, it says if it's low on a charge, that you should charge it first, before trying to start a bike, apparently you can damage the battery if you try to start it with a dead battery.
I have a Shorai charger, if you were closer I'd let you barrow it. Or you can send me the battery, and I'll hook it up and send it back when it's done.
Which one of you FF's was it?...FOUNDER! Entia non sunt multiplicanda necessitatem |
#7 |
Oddometer: 397
shorai
I'm on my 2nd.....I keep mine on a trickle charger/battery tender. Lots of guys that I respect on here love this batt but its the last one i will own. Just dont trust um 100%. Originally Shorai said the standard batt tender was fine but some guys on here say NO and if your running your big ktm with accesories the battery will not full charge while riding.
No Bueno! Cheers and good luck |
02-15-2013, 04:40 PM
#8 |
Wile E Coyote SuperGenius
Oddometer: 1,151
I have successfully used a standard auto charger on mine.
I wouldn't do it all the time, but sometimes, a guy leaves the grips on .
02-15-2013, 04:44 PM
#9 | |
Oddometer: 2,499
the short answer is yes you can charge Shorai batteries with most any automotive charger without conditioning mode. which will go up to about 15.5v, would not be good for LiFePO4 batteries. LiFePO4 batteries for motorcycle are fully charged at 14.6v .. your Schumacher charger should charge at peak 14.3v or so... so long as your auto charger stays below 14.6v, you should be fine. bulk part of charge is not critical .. As your LiFePO4 battery charges up, current will naturally slow down. using a dumb charger without float mode requires you monitor charge levels to prevent overcharge. in other words, measure your auto charger to make sure peak voltage doesn't exceed 14.6v and don't leave your charger attached longer than overnight. it's my experience some Shorai have internal BMS, some don't. all have external balance ports ... Shorai batteries should be balance charged from time to time with a charger with balance leads. see my LiFePO4 battery testing thread for LOTS more details .. link in sig.. Shorai LFX 21 being balanced charged with Powerlab 8 (note balance cables in center)
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? _cy_ screwed with this post 02-15-2013 at 05:03 PM |
02-15-2013, 05:07 PM
#10 | |
Oddometer: 217
02-15-2013, 05:39 PM
#11 | |
Oddometer: 2,499
some battery tender will deliver a slow charge for long as charger is plugged in. only use exact model and brand tender mfg recommends. my recommendations is not to use a tender, unless your parasitic drain is higher than normal. some tenders charge so slow, it could take several days to reach full charge. use a normal dumb automotive charger to charge your LiFePO4 batteries. then monitor voltage (14.6v max) and don't allow charger to remain on battery past overnight. most LiFePO4 cell mfg (not battery mfg) will recommend a .5C to 1C charge rate during bulk stage. example: Shorai LFX 21 actual = 6 amp hour ... so 3A - 6A charge rate is preferred during bulk stage of charge. some battery tenders charge at 150-500 milliamps
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
02-15-2013, 05:41 PM
#12 | |
Oddometer: 822
Shorai
02-15-2013, 08:12 PM
#13 |
Super Noob
Oddometer: 95
I bought one back in march 2012 and it died in November. I'm not impressed. I always felt it was going to leave me stranded. Riddle me this if it needs a special charger to charge completely how is the bike's electrical system going to charge it?
02-15-2013, 09:03 PM
#14 | |
Oddometer: 2,499
Li-ion batteries in general go from full power to NO power. the instant battery output goes down... STOP all drain! or risk over discharging/ruining your battery.
balancing is needed only on occasional basis to make sure all internal cells remain in balance. Earth-X has internal BMS that keeps cells balanced. one of the most common problem with LiFePO4 batteries is mfg spec only enough AH for warm weather, with bike in perfect tune. actual amp hour are tiny with little to no reserve should engine need extra cranking and/or use of heated gear combined with short rides and cold weather.
02-15-2013, 09:08 PM
#15 | |
Oddometer: 2,499
