Old 05-08-2011, 05:14 PM   #1
AdvRonski OP
They call me......Ronski
Location: Wishing I was back in Grand Junction, now in MN
Oddometer: 688
An Auxiliary Fuel Tank is Born
I have been thinking about adding an aux. fuel tank the the 950 ever since I converted to a 2-1 exhaust. The huge, empty space where the left muffler used to be beckoned to me, while I considered some options.
Convert the old muffler into a fuel tank-
This looked like a huge PITA to me. The only way to gut the muffler's baffles seemed to be cutting it in half length-wise, and it would barely hold 1 gallon of fuel. Nope.
Neduro's AdvTank looked promising, but availability was a problem, and I had some concerns about the rigidity of the mounts. There are a few reports of tanks rubbing on the rear tire when mounts bent. Plus, 400 bucks isn't easy to part with.
Make my own out of aluminum-
Now this I like. I can design it just how I want it, and make the mounting system plenty stout. Also, I just like the look of custom fabbed aluminum bits, like my skidplate and swingarm projects.
http://www.advrider.com/forums/showthread.php?t=657112
http://www.advrider.com/forums/showthread.php?t=640537
After some goofing around with different shapes, I came up with an elongated hexagonal cross-section,
The tank would impinge on the swingarm at full compression, so a cutout would be needed,
After some tweaking, the final shape emerges,
Note the high-tech rear wheel stand,
Since I don't have access to a large sheet-metal brake, I had a fuel tank company bend the basic shell out of .125 5052 aluminum alloy,
The cutout for the swingarm is fitted,
And checked for fit on the bike,
Before welding the shell halves together, I added a baffle in the center of the tank, to keep fuel slosh at a minimum under 950-style hard acceleration,
Then it was time to put it together, and start welding,
Starting to look like something!,
Now, for some mounts that will have to control the movement of a close-to-30 pound tank of gasoline. The top mount is easy enough, just use the muffler mount to hang it from. The front and rear mounts need to be as low as possible to control tank movement, while also isolating the tank from engine vibration. Since I don't plan on ever taking the stock KTM rear bag mounts off, they are the perfect spot to use as mounting points.
First, the front mount gets a bracket,
And a stainless-steel bracket joins the rubber-mounted left side crossover pipe mount with a small rubber mount on the new bracket,
The nose of the tank is narrowed to give frame clearance,
And a tab is added to mount to the bracket,
Some detail on the bottom plate, where the KTM fuel valve will mount,
The screws that fasten the fuel valve need to be sealed, or they will leak fuel. I considered different methods to accomplish this, and settled on just building up the areas above the screw holes with layers of welded material,
Wow, that is a lot of welding. But it looks good to me!,
Now, I need some way to put fuel in it. I'll start with a big hole,
Finding a fuel filler was a bit of a problem. There were huge fillers for diesel fuel tanks, and some very short fillers for drag racing tanks, but nothing really suitable for my purpose. I found an oil filler extension for VW buggy engines that seemed about right,
Unfortunately, the first time I screwed the finely-made aluminum cap on, it galled the threads, and I had to cut the damn thing off!,
Well, when you need some fancy machining done for a 950, who do you call?
That's right! You call Craig at CJ Designs, and beg for mercy!
What I really wanted, I explained, was a fuel filler tube that would fit a small KTM fuel cap. Would you PLEASE consider making one before you go off to Alaska for the summer?
Incredibly, he was just going to make a few up for his own fuel tank project, so it would be no big deal to make one for me! No freaking way!
Thanks Again Craig!!!
So, while I marveled at my good fortune, I finished the rear tank mount by adding a mounting block on the rear of the tank. Then I welded another bracket on the bag mount cross-bar, and joined the two with a stainless-steel bracket that bolted to the tank through rubber mounts,
In a few days, the filler arrived from Craig, and I welded it into place.
The finished tank looks great, and holds about 2.4 gallons of fuel, good for around an extra 100 miles or so,
Thanks to Craig at CJ Designs, and also Ned at AdvTank, who very kindly donated a fuel check valve to this project, although he had no idea what I was up to with it.
Thanks, Guys!
Ronski
Enduro Racer & Big Bike Adventurer
AdvRonski is offline   Reply With Quote
Old 05-08-2011, 05:20 PM   #2
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 9,735
Very nice
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 05-08-2011, 05:41 PM   #3
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,072
Nice work! I particularly like the FMF sticker. The baffle is clever!
I'm so jealous of you guys with welding tools and knowledge to operate them. I may have to do something about that in my workshop...
viola-tor is offline   Reply With Quote
Old 05-08-2011, 05:42 PM   #4
aurel
Cheese&Wine!
aurel's Avatar
Oddometer: 3,687
Nice job
In 20 years you'll only regret what you didn't do.
World Tour finished! http://www.the-great-adventure.fr
aurel is offline   Reply With Quote
Old 05-08-2011, 05:53 PM   #5
Dusty
Dusty's Avatar
Oddometer: 1,269
Sweet!
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty is offline   Reply With Quote
Old 05-08-2011, 05:56 PM   #6
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
very nice! Looks awesome
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 05-08-2011, 06:05 PM   #7
WIsixfitty
ceiling unlimited
Oddometer: 2,159
cheers to the do it yourselfers.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 05-08-2011, 06:05 PM   #8
RickS
RickS's Avatar
Oddometer: 575
Looks great! Am I missing something here, but should there not be a hole at the bottom of the baffle as it appears that some fuel will not be avaiable due to the lower hole being a inch of so off the bottom? It may just be the angle of the photo - if so sorry.
RickS is online now   Reply With Quote
Old 05-08-2011, 06:25 PM   #9
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,697
Take a closer look.
Rocker59 (aka guzzimike), Aux Arcs (NW Arkansas)
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 05-08-2011, 06:25 PM   #10
dejr2000
dejr2000's Avatar
Oddometer: 362
There is a small opening between bottom of tank and the baffle, baffle doesn't go all the way to bottom of tank.
Great project! Thanks for sharing
dejr2000 is offline   Reply With Quote
Old 05-08-2011, 06:46 PM   #11
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,697
Yep. Great project!
IBA #24873
Old 05-08-2011, 07:25 PM   #12
JTXT
Oddometer: 82
Nice work!!!
JTXT is offline   Reply With Quote
Old 05-08-2011, 07:47 PM   #13
wheatwhacker
It's raining here
wheatwhacker's Avatar
Oddometer: 2,945
Great work.
How many gallons?
European bike sales and storage.
https://www.facebook.com/motofeirme
wheatwhacker is offline   Reply With Quote
Old 05-08-2011, 08:09 PM   #14
RickS
RickS's Avatar
Oddometer: 575
See that now. excellent project and great looking!!!!!!!!!!
Old 05-08-2011, 08:44 PM   #15
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,769
I'm with you there! I can fabricate but don't have a brake or a tig! Yes, nice work!
'06 KTM 950 Adventure S
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox
"The bouncer is a bulldog who looks like Wilfred Brimley and the password is 'diabetus'"-Stefon, SNL character
DakarNick is offline   Reply With Quote
Times are GMT -7.   It's 07:55 AM.
