Old 02-14-2013, 04:28 PM   #1
THUMPER0475 OP
Oddometer: 78
How is your RAM cradle for 60csx
I've had a couple of failures with my cradle anyone else out there dealing with gps coming out of it's Ram cradle. Please let me know. I am in discussions with Ram, who says I'm the only guy in It's history to have this issue. I don't beleive it. Help prove me right.
THUMPER0475 is offline   Reply With Quote
Old 02-14-2013, 04:37 PM   #2
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,954
Never had a problem and i subjected my gpd to off road riding. It felt really well clipped in, but it did rattle a bit since it slightly loose
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 02-14-2013, 04:51 PM   #3
katbeanz
earthbound misfit, I
katbeanz's Avatar
Oddometer: 7,781
Mine got sprung a little from use, where it didn't pop in as tight as new. I carefully bent it back and it was fine until a crash. I always loop the lanyard around a mirror, and used a small bungee cord too.
Been using a montana for a while, but I miss the buttons of the 60.
katbeanz is offline   Reply With Quote
Old 02-14-2013, 04:54 PM   #4
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,422
I have 3 of the cradles (Ram) for the 60Cx, and haven't had any probs. even on the DRZ that I crash regularly off road.
PineyMountainRacing is offline   Reply With Quote
Old 02-14-2013, 07:18 PM   #5
RH426
RH426's Avatar
Oddometer: 113
Mine is great , I to use a lanyard and a rubber band around the top to stop the rattling.
RH426 is offline   Reply With Quote
Old 02-14-2013, 07:27 PM   #6
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Mine has never fallen out but I didn't like how it had a bit of play and would rattle around in the cradle. I cut a strip out of an old inner tube about 3/8"x2" and crazy glued it into the bottom/end of the cradle so it would put a little more load on the lug it doesn't rattle at all anymore. Like others said the lanyard is your friend just in case.
07 SE
PG007
Old 02-14-2013, 10:38 PM   #7
tedder
irregular
tedder's Avatar
Oddometer: 8,797
Been using it since the 60series came out in 2004. I replaced the cradle once and have replaced/upgraded the actual GPS a few times between then and now.
No problems, I've destroyed bikes and had the 60series mount hold up.
Jeff C, the owner of RAM/NPI, is a brilliant guy.
Perhaps you can explain the problem you've been having- you said "couple of issues" and implied it's falling out. How is that happening? Is the screw/post coming off? Is the GPS loose in the mount?
tedder is offline   Reply With Quote
Old 02-14-2013, 10:40 PM   #8
BBRadar
BBRadar's Avatar
Oddometer: 118
I use a rubber band to hold my 60csx in firm, and never had a problem with the cradle. It's been through hell, and some decent stacks/flips - big enough to break RAM arms on my double take mirrors.
The GPS itself is holding up well too.
BBRadar is offline   Reply With Quote
Old 02-15-2013, 06:00 AM   #9
THUMPER0475 OP
Oddometer: 78
Yes the GPS has fallen out twice. Once on the CDT ride. It had happened before when riding some whoops so I did tie a lanyard to it so if it happened again at least I wouldn't have to ride back miles to find it. I must have a defective cradle judging by the comments posted here. The cradle seems to be fine as far as flaws so I assumed it must be a design issue. Ram has offered to replace it for me so I guess I'll try that and take the other suggestions from members for the rattle fix.
Old 02-15-2013, 06:02 AM   #10
Yooper_Bob
Yooper_Bob's Avatar
Oddometer: 2,819
Mine is probably 10 years old now, and still zero issues with the GPS coming out of the RAM mount. It still fits as snug as it did on day one.
The same mount/GPS have been used year around on my snowmobile, KTM, and boat.
Guess you are the only one!
Yooper_Bob is offline   Reply With Quote
Old 02-15-2013, 06:13 AM   #11
V-Tom
Oddometer: 801
When I had my 60Cx I used it in my car, on my Ultralight Airplane, and on my bike. The only issue I had was on the first Ram Mount I got a crack on the top part of the mount where it clicks onto the top of the 60Cx. I discovered that I neded to press on the back of the bent part of the mount to release the mount when taking the GPS off. This cured any issues on the replacement mount (which was replaced under warranty) and it lasted 100.000+ miles and many rough field landing on my Ultralight with no issues.
For what it's worth it never fell off (even after a low speed crash and several drops of the bike) but I did alway tether it ot my bike just in case (a habit I got from flying my Ultralight.)
..Tom
2006 DL650 V-Strom * 202,000 km 125,500 miles 2012 DL650 120,000+ km, 75,000+ miles
V-Tom is offline   Reply With Quote
Old 02-15-2013, 03:28 PM   #12
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,310
I've had 60csx's fall out of cradles a few times riding offroad (and the last time the 60csx ended up with a broken screen).
Got a 62 now, with a different cradle mount and had no problems with it...
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is offline   Reply With Quote
Old 02-15-2013, 04:04 PM   #13
Midnightventure
Oddometer: 754
Mine came out within a half mile when it was brand new but I think something was pushing on the release. I always try to wrap the lanyard around something now but I haven't had it happen again.
Midnightventure is offline   Reply With Quote
Old 02-15-2013, 07:11 PM   #14
TOTim
TOTim's Avatar
Oddometer: 183
This method is failsafe even with a cheap bicycle type mount.
TOTim is offline   Reply With Quote
Old 02-16-2013, 06:54 AM   #15
team ftb
Befuddled Adventurer
Oddometer: 1,757
I've been riding with the Garmin 60 series for more than 6 years primarily offroad. I have heard of others losing the GPS unit out of the Ram cradle so tie the lanyard around the unit and cradle to keep it from being flung off the bike if ejected from the cradle. I have also broken 2 RAM cradles and countless ram mount bolts via crashing. A few years ago I awitched over to this gents custom cradles for the 60 Series:
http://www.advrider.com/forums/showt...ight=stovebolt
And after 3 years of continuous off roading and crashing have yet damage it and its still going strong.
Stovebolts cradles are the bomb from my crashing perspective.
Cheers,
Team FTB
Team "Fingering The Bean"
team ftb is offline   Reply With Quote
Times are GMT -7.   It's 04:55 AM.
