Old 02-15-2013, 08:07 PM   #1
David37 OP
David37's Avatar
Oddometer: 400
Changing Sparkplugs on a 950SE
While waiting for my suspension to come back from SuperPlush. I decided to change the sparkplugs, replace the air filter and clean my pre-filter. I read here how it was a PITA to change the front sparkplug.
Changing the front sparkplug on the 950SE is a PITA becasue of the tight space. With my gas tank already off the bike, I found the easiest way to access the front sparkplug and to create some space was to:
  • remove the 3 bolts holding the radiator to the frame
  • disconnect the overflow tank hose from the top of the radiator cap besure the open end of the hose is higher than the tank so coolant won't drain out of the tank
  • place a plastic drain pan underneth the radiator
  • disconnect the bottom radiator hose (rear brake side of bike)
  • let the radiator coolant drain into the drain pan
  • tilt the radiator slightly forward (gives room to access sparkplug)
  • remove the front sparkplug cap
  • to remove the sparkplug you have to use the "KTM sparkplug socket" (standard deep socket is too wide for the sparkplug well)
  • put everything back together and refill the radiator (good excuse to change your coolant) or you could reuse your old coolant
Overall, I found changing the 950SE sparkplugs fairly painless.
David37 is offline   Reply With Quote
Old 02-16-2013, 02:23 AM   #2
Schannulleke
Oddometer: 208
If you drain the radiator, you can just as well remove the radiator. Works much easier.
It's best to do it all at every 15000km service interval:
- drain and remove radiator
- change spark plugs
- check and correct valve clearances
- check and clean carburators
- remount radiator with new coolant
Schannulleke is offline   Reply With Quote
Old 02-16-2013, 03:49 AM   #3
charlie264
charlie264's Avatar
Oddometer: 8,311
Or take radiator bolts off, push rad forward and slide out cooling fan assemble. So you don’t have to touch coolant.
Old 02-16-2013, 05:29 AM   #4
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,334
Yup!
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 02-16-2013, 08:51 AM   #5
triplenickel
triplenickel's Avatar
Oddometer: 2,428
Thanks for saving me the time to type the same repyl!
07 SE
PG007
Times are GMT -7.   It's 07:46 PM.
