Old 02-21-2013, 07:49 PM   #31
drrider1
just running amuck
drrider1's Avatar
Oddometer: 408
Originally Posted by Conedodger View Post
My bike is test ridden after every service. Usually on the way to work the next day!
28 years of motorcycle ownership. Never had a bike in a shop other than
my own.
1+
Every life needs 9 cats.
11R1200rt 96 Ural Tourist (red peril)
07 Ural Touist brides new ride
drrider1 is offline   Reply With Quote
Old 02-21-2013, 08:00 PM   #32
JTucker
JTucker's Avatar
Oddometer: 2,270
I always test ride a bike after working on it, usually dirt bikes and short rides. Just a few minutes, 5-10. If it's major work on something street legal more. We have a particularly problematic sumo that I've put over an hour on, but there are reasons for that one.
http://www.ktm-parts.com
03 Aprilia Caponord 06DR650
13 GasGas EC300 05 WR450F 87 T-dub
JTucker is offline   Reply With Quote
Old 02-21-2013, 10:21 PM   #33
corndog67
Oddometer: 1,281
I had a front brake caliper fall off pulling into a gas station driveway on my new bike. Could have been disastrous. Doubt if they would have found it if they had tested it. a
corndog67 is offline   Reply With Quote
Old 02-22-2013, 01:56 PM   #34
ttpete
Rectum Non Bustibus
Oddometer: 5,940
That was the dealer's fault. They didn't tighten the bolts after they put the front wheel in during pre-delivery assembly.
15 BMW RnineT
09 Kaw Versys
Old 02-22-2013, 07:24 PM   #35
c3eh
Oddometer: 30
Yes
Local BMW dealer does this, I had oil/brake fluid change plus little coolant top off couple months ago and they did it but I dont think it was a looooooong ride. However I did not pay that close attention to how long they were gone.
The best navigators are not quite sure where they're going until they get there and than they're still not sure
but I know one thing indecision may or may not be my problem.....
c3eh is offline   Reply With Quote
Old 02-22-2013, 07:34 PM   #36
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 3,795
My only local dealer claimed they did this, to the extent that I've been forced to go there. 100% unverifiable as per odometer and front end so tweaked it was a chore to go straight.
Be more appreciative of your dealer who does.
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 02-23-2013, 06:26 AM   #37
mikegc
mikegc's Avatar
Oddometer: 1,642
Does your dealer do this?
While on a cross-country trip a couple of years ago, I stopped at Gateway BMW in St. Louis as I needed an oil change. They helped me out immediately and I noticed the tech who did the swap rode the bike. Before they would release it, another tech, armed with a torque wrench and several sockets, torx, etc., started going over brakes, axles and various other areas. I asked the service manager what was going on and he said, "We try to check out everything that could make you fall down." I appreciated the attention to detail!
My local dealer has the service tech ride the machine after service. I don't mind a bit.
Mike
IBA 25881
Duty- Honoring a Friend
mikegc is offline   Reply With Quote
Old 02-23-2013, 07:33 AM   #38
markk53
jack of all trades...
markk53's Avatar
Oddometer: 8,799
With liability what it is in the US, a test ride is almost mandatory. It seems every attorney sees the fault for everything with the last mechanic who laid hands on the bike, even if the brakes fail and the bike was only in for an oil change. They see it as the fault of the shop because they didn't predict the failure.
The fact is the dealership where I used to work would actually make note on a repair order if they would NOT test ride it due to safety concerns listed on the work order that were not being serviced.
I'm betting there are some shops that will run new tires in a bit to avoid having some rider go out, crank a quick turn, then dump the bike due to the preservative on the new tire. We had someone raise a stink even after we emphasized the risk of leaning too far on new tires until scuffed in a bit. That was in the 80s, now they'd probably sue. But now I believe the shop has them sign off on the warning being given. If it was my place I'd tell the mechanic to put ten miles on the tires.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is online now   Reply With Quote
Times are GMT -7.   It's 02:16 PM.
