Old 07-08-2013, 04:57 AM   #31
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,754
Originally Posted by hpsVFR View Post
I was thinking that you'd take your vent line from the sub-tank and run it underneath the main tank, all the way to the front, then up, over the top and to the filler cap. You'd have to modify the cap to accept the vent hose while retaining the water seal, and retaining proper cap vent operation. I was thinking something like a straight (not 90!) barb fitting bolted/glued into a hole drilled all the way through the cap.
I don't know if your cap has enough space to drill a hole, install some sort of pipe/tube (to prevent fuel seepage, and retain a vapor-tight seal), and glue/weld/bolt a fitting on the top. That's a lot of stuff to put into a fairly small space, and this seems like the biggest challenge to what I've suggested.
On the positive side, you would retain all the original characteristics of the positive-pressure tank, and (hopefully) retain the action of the tank vent. Your sub-tank vent line would be above the max fuel level in places where it's exposed. Areas where it's below max fuel level could be protected fairly easily, for example by using fuel line as chafe gear.
You'd also obtain that awesome old-school race-bike look, with a fuel tank cap with a vent line loop sticking out the top.
I hope that clarifies what I'm thinking about, and good luck with it no matter how you end up dealing with it.
I see what you are saying now. I get it and I like it.
Couple issues with your plan, the cap has that little flapper that covers the key hole I'd have to get rid of. Also there are internals that I would have to seriously dodge to keep the key lock functional. Plus the cap is fairly complex with the venting system as I discovered yesterday. I'll have another look and see if I can figure out a solution. Thanks!
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 07-08-2013, 05:08 AM   #32
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,754
Originally Posted by joexr View Post
I'd try the bulkhead fitting. Maybe on top in front of the cap.
I would think about that solution but I'd have no way to tighten a nut inside the tank. The big hole from the fuel pump is now welded up.
Originally Posted by the_gr8t_waldo View Post
things are a bit clearer now-I always say that before sticking my foot in mouth. the expelled fuel over flow is coming from the slop drain( or the fliptop cover), isn't it? clearly the main tank enjoys an elevated operating pressure. ( surprisingly this is normal and part of the design of the bike)- and by extension the sub too! end result is that the gas is blown out the sub and into the slop drain -and if i'm right about that, only rerouting the subs vent line INTO the main will fix it.( i'm not sure if routing to the lower part of the main will do anything for you, except to drastically slow down refueling stops.) this would be the exact same thing I ran up against. piping slightly different, but same problem. if you can't insert a vent into the top section of the main, then you might have to silver solder a tube that goes from out side bottom(hidden from view)- thru the tank to someplace reasonably close to the top. I believe you mentioned that the vent line is an AN#6 this would be the time to make the sub's vent bigger, as well.
Yes you are correct, the vent from the subtank is now the repurposed slop drain. And it ain't workin'
I'm hesitant to weld on the tank, mainly out of fear that it will screw up the liner and I don't want to have to deal with removing crispy POR15 from the tank. I guess if someone at POR said it's no big deal, I would weld in a "straw that exited near the top of the tank and problem solved.
Of course I wish I had know this would be an issue before I sealed it
Originally Posted by lnewqban View Post
If pressure is building up in your tank, your fuel cap is defective.
The way the cap works achieves two things that your system is not:
1) Slow and little fuel spillage in the case the bike falls on its side.
2) Reduce fuel evaporation.
For normal operation, the auxiliary tank needs no vent.
After you run it dry, a manual vent valve will suffice to re-fill it by gravity.
I think the manual vent for refilling is the best option at the moment. As you stated, the subtank does not need to be vented until you are refueling and the subtank needs to displace the air so that gravity can do its thing.
With 4 gals in the main tank and 1.2 in the subtank, I do have quite a bit of range. The effort to crack open a vent for 30 seconds and allow the subtank to fill and then close is fairly minor in the course of owning a bike like mine with so many crazy attributes to start with.
I am not totally satisfied with the tank welding and modifying I did. I have given consideration to finding another tank and redoing it. Perhaps when the winter teardown for painting and powdercoating happens. It's a couple hundred for a new tank and I can properly plan the location of the fuel supply and venting now knowing what I am in store for.
Just in case you are all wondering what the hell I am talking about, here's the maiden voyage a few weeks ago, since put 200 miles on it. The subtank sits in back, and around the other side of the shock.
Nessmuk
Old 07-08-2013, 09:29 AM   #33
lnewqban
Ninjetter
lnewqban's Avatar
Oddometer: 291
Cool2
Thanks for your response.
If not venting in and out correctly, this may be how your cap looks inside:
http://forums.ninja250.org/viewtopic...=846831#846831
This is how to clean the vent passages:
http://forums.ninja250.org/viewtopic...=clean+gas+cap
You could run that manual vent tube into a vented smaller transparent tank, so you can see when to stop before you make a mess on the floor of the gas station.
A better alternative: For industrial piping systems, there are automatic vents that are located at highest points, which blow out any air in the pipes but close when the fluid reaches them.
Check out how they work:
http://www.spiraxsarco.com/pdfs/sb/s31_06.pdf
Another thing about which I have been thinking for your solution: rain will eventually find a path around the cap, into the tank and into the subtank (lowest point of the tank system).
If not, some condensation will happen inside anyway.
You will need a way to drain that water from the lowest point, as I don't think that the pump and injectors will be able to get rid of it.
My bike has a carburetor and a cockpit with reserve.
Once in a while I drain the bowl and the reserve into a glass container, collecting an important amount of water.
Nice bike !
lnewqban screwed with this post 07-08-2013 at 09:44 AM
lnewqban is offline   Reply With Quote
Old 07-09-2013, 11:59 AM   #34
hpsVFR
Hoosier Daddy
hpsVFR's Avatar
Oddometer: 1,388
Yeah, this idea hinges on there being enough space in the cap to drill a reasonable-sized hole, and insert a reasonable-sized bit of tubing. It doesn't have to be big, but as you say, there's a lot of stuff in a fairly small space there.
I'll take a short moment to comment on joexr's suggestion that you bolt a bulkhead fitting onto the tank. Your fuel filler hole isn't huge, but it might be big enough to get tools in/out (or find a small-handed friend/neighbor-kid). If you can do that, then my idea gets even easier, because you just bolt a bulkhead fitting directly in front of the gas cap.
I'll get back in the saddle again if it kills me...
hpsVFR is offline   Reply With Quote
Old 07-09-2013, 09:23 PM   #35
joexr
Oddometer: 3,773
Or directly under it. There are also those screw in billet gas caps.
Times are GMT -7.   It's 01:57 AM.
