02-18-2013, 10:07 AM
#1 |
Oddometer: 16
Question for You 1-Piece Suit Users
How do you route the cord for electric vests and such out from inside your 1-piece?
Is there a pass-through pocket or something similar? I've got an Olympia Phantom and if there is such a pocket I haven't been able to find it. Never had the need to use the electric vest under this thing until this Winter. Sam Bateman Arvonia, VA |
02-18-2013, 10:12 AM
#2 |
Big 'G'
Oddometer: 362
aerostitch one piece has zippered pocket
IBA 53683 09 R1200 GS ADV |
02-18-2013, 10:50 AM
#3 |
Oddometer: 66
http://www.webbikeworld.com/heated-m...jacket-review/
If that fits underneath or something similar with an inbuilt powersource. Or if you want to get even slimmer surfers use heated vests as well whith the added benefi of being waterproof
02-18-2013, 08:14 PM
#4 |
Road Trip Fool
Oddometer: 758
New 'stich...
...and retro-fit option for old 'stich is a dedicated jumper wire pass through for heated gear.
I have had it retro-fitted to two Roadcrafters. Works great!
1997 Ducati Monster 750 2004 Suzuki V-Strom 650 2004 Honda RC51 |
02-18-2013, 11:04 PM
#5 | |
Oddometer: 1,027
Now you should have a double pull Zipper. (What Olympia should have put on there to start with.) You should be able to zip down the top of the zipper a few inches, stick you cord through, and then zip it up tight around the cord. Walter
"How much a dunce That has been set to roam Excels a dunce That has stayed at home." |
02-19-2013, 10:57 AM
#6 |
Oddometer: 63
I have a joe rocket survivor suit. I put a small hole in one of the pockets on the left thigh area and threaded a gerbing extention lead thought it. It pops out through the normal pocket zip which closes 99.9 percent and the pocket flap locks over that. I kept it in the pocket when not in use. The inner part just plugs into the gerbing jacket as usual. Never had any problems with water leakage.
AB ![]()
02-21-2013, 05:57 AM
#7 |
Oddometer: 16
I Appreciate All the Replies
I'm leaning towards the putting a hole in the back of the pocket thing right now.
Although that zipper modification would also work nice. Sam Bateman Arvonia, VA |
