Old 02-18-2013, 11:40 AM   #1
Shaggy63 OP
Oddometer: 1
BMW K100 cast wheel on chair ?
Hi All,
does anybody know about the use of a BMW K100 wheel on a sidecar ? everything I remember from my younger days said you shouldn't use a cast wheel on the chair as it is not designed to withstand the side forces a sidecar generates and will break at some point. I'm not sure if this refers to all cast motorcycle wheels or only older 'jap' wagon wheel style wheels.
I have recently seen a picture of a Ural fitted with a K 100 front wheel on the sidecar and a 2 wheel drive K75 with a K rear wheel fitted to the chair but I just wondered if anyone knows if they will work in the long run.
I have a spare K 100 RS swingarm, diff and rear wheel and was going to incorporate this into my next sidecar build but will it stand the forces involved ?
Any ideas ?
Shaggy
Shaggy63 is offline   Reply With Quote
Old 02-18-2013, 02:08 PM   #2
Rockman
Oddometer: 314
I've had a K100 front wheel on mine for a while now. Bikes done about 30,000 km with this set up no probs.
Rockman is offline   Reply With Quote
Old 02-18-2013, 02:51 PM   #3
jaydmc
Oddometer: 1,050
I see no problem, The Chinese even copied this BMW wheel and run it not only on thier bikes but also on thier sidecars.
Jay G
DMC sidecars
866-638-1793
jaydmc is offline   Reply With Quote
Old 02-20-2013, 01:52 AM   #4
Hellracer.nl
What the hack???
Hellracer.nl's Avatar
Oddometer: 435
@ Rockman; Can you post some details on how the wheel is mounted? Did you use the original axle? I'm planning to use a K100 front wheel and axle on my second leaner hack.
To beer or not to beer, that's no question.
My Leaner build: http://advrider.com/forums/showthread.php?t=836987
K1100rs, K100rs, F650, GSX1100, TS185
Hellracer.nl is online now   Reply With Quote
Old 02-20-2013, 11:05 AM   #5
MotoJ
Mobtown Hacker
MotoJ's Avatar
Oddometer: 1,175
I've collected parts for a /2 earles front end conversion on my R80/7 sidecar rig. I plan to use a snowflake cast front wheel.
I had this cast wheel discussion with a friend of mine who insisted the cast wheel would be a death sentence. Research led me to a BMW recall that is still being honored regarding the BMW cast snowflake wheels. Apparently the early ones would indeed crack and eventually shatter. They redesigned the wheel and beefed it up and I did not find any instances where they broke just from riding stress.
Since I started looking into the issue I have met a handful of Beemer hack pilots using snowflake or K bike cast wheels and no-one has had a problem. Your K100 wheel should be fine in any position. Do make sure your bearings are in good shape and seated right, because if the races spin you'll ruin the wheel hub. The bearings will take a beating.
The ladies used to check me out...now they just keep an eye on me.
MotoJ is offline   Reply With Quote
Old 02-20-2013, 04:49 PM   #6
Rockman
Oddometer: 314
I'm not sure if its the original front axle or not (probably). Its 20 mm dia and welded into a box section swing arm. I'll get a pic or 2 over the weekend and post them for you.
Incidentally, I seem to remember the "cast" wheels that caused problems were the Comstar wheels used by Honda in the 80's. These were a built up construction and not up to side forces.
Old 02-20-2013, 04:59 PM   #7
Rockman
Oddometer: 314
Heres an innovative use of a K100 rear swingarm mounted on the front as a leading link. Something to ponder.
The wheels shown are Renault with adaptors. I eventually took the Renault wheel & the adaptor off the front and fitted a K100 rear wheel instead. The Renault wheel was offset about 40 mm from the centreline of the bike and pulled left quite hard. The K100 rear lined up well with the centreline and steered fairly straight.
Old 06-17-2014, 04:40 AM   #8
Wazzz
Wazzz's Avatar
Oddometer: 11
Hello Rockman
Do you have anymore photos of the front end?
Wazzz is offline   Reply With Quote
Old 06-17-2014, 06:05 AM   #9
Hellracer.nl
What the hack???
Oddometer: 435
Are you sure that those are Renault wheels? They look suspiciously much like Citroen wheels..
Here is what I used for mounting a K100 front wheel on my leaner sidecar:
Original front axle on swing arm( unwelded here):
Welded together and wheel mounted:
Other side:
And completely finished:
Old 06-17-2014, 04:50 PM   #10
Rockman
Oddometer: 314
Originally Posted by Wazzz View Post
Hello Rockman
G'day Waz(zz), no mate sorry thats the only one I seem to have kept. Imagine a K100 rear swingarm turned around to
face forward, complete with the final drive and mounted on a leading link type setup. Used a K100 rear shock. I didnt take it apart at any stage, but I suspect the input pinion had been removed from the final drive, leaving just the main gear as a wheel carrier. This would reduce drag. Downside is that you only have 1 front disk.
Old 06-17-2014, 04:52 PM   #11
Rockman
Oddometer: 314
[QUOTE=Hellracer.nl;24412405]Are you sure that those are Renault wheels? They look suspiciously much like Citroen wheels..
Yes could have been. I was told they were Renault 10 but never bother to check.
Times are GMT -7.   It's 03:00 AM.
