Old 02-18-2013, 09:10 PM   #1
Jimm Dandy OP
Oddometer: 117
steering damper for a Vstrom??
hopefully I sould have my hack mounted up in a couple of weeks.. while sittn here waitin for my knee to heal up I am wonderin whether or not a steering damper is a good idea.. any input will be appreciated.
Jimm Dandy is offline   Reply With Quote
Old 02-19-2013, 01:33 AM   #2
Midnullarbor
Oddometer: 332
Is there any game in town, other than the hydraulic rotary steering damper by Scotts ?
All sorts of combinations of damping patterns can be dialled up [compared with linear hydraulic dampers or the old frictional type].
Ralle-Moto used to have a good "RM1" version of rotary hydraulic, possibly still available on the second-hand market.
It was perhaps rather easier and more intuitive to use than the Scotts (which is okay enough in its own right).
Ralle-Moto nowadays sells its second version "RM2", but seems to be selling kits suited to a smaller range of models . . . not including the Strom!
However, I could be wrong about that, and it might be possible to work around that problem.
Midnullarbor is offline   Reply With Quote
Old 02-19-2013, 07:09 AM   #3
Slade 330
Slade 330's Avatar
Oddometer: 93
Steering Damper
Early Volks Bug Cheap and good
Slade 330 is offline   Reply With Quote
Old 02-19-2013, 07:15 AM   #4
davebig
Another Angry Hun !
davebig's Avatar
Oddometer: 3,763
Yep hard to beat for the money. Steering dampers are ones own taste if the bike has a trail reducing mod it may not need one allot depends on how much bump steer you can live with.DB
Patience: A minor form of despair disguised as a virture.
Ambrose Bierce
davebig is offline   Reply With Quote
Old 02-19-2013, 08:45 AM   #5
Melrone
Oddometer: 955
The VW steering stabilizer has been used on Sidecar rigs for years.There cheap about $25 and they work great..I bought a setup from Stroker for my 03 GSA/ Ural rig...That uses a VW Stabilizer..You will need to make a couple of brackets to hold it but you won't be sorry......
Melrone is offline   Reply With Quote
Old 02-19-2013, 04:13 PM   #6
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,053
Yup, gotta agree with Slade, the VW damper on my Strom works well.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 04-08-2013, 08:00 PM   #7
boxertwin
Oddometer: 1,022
Yup. Just be sure to attach it to the upper so it's not going upanddownandupanddownanddown because that's just silliness.
Your beer is still in my fridge.
boxertwin is offline   Reply With Quote
Old 04-09-2013, 06:47 AM   #8
claude
Sidecar Jockey
Oddometer: 3,807
The VW dampers work fine but must be mounted right. Mounting it high is best if possible. if not and you mount it low make sure it is free to move in all directions during bump and rebolund and steering. This is important. Also you want to have it mounted so it does not tend to induce a bump steer effect. Many bikes do well without a damper .
Also consider how much of th estoke of the damper you actually want to use. that can be varied with mounting. Less stroke makes for easier steering. You do not want to damper to top out or bottom out.
Dampers can also be mounted vertically or through a linkage system. Depends on how much effot you want to put into it.
If you have tapered roller bearings in th esteering head a little extra tightening helps a lot. Many will just get used to th elow speed headshake that some rigs have and forsake the damper.
We do a few dampers but not many overall. Most time the low speed headshake can be dialed out with setup and playing with tire pressures. Typically the sidecar tire being low on aiur is a culprit. The front tire can be the source throiugh either too much or too little air as well as tire wear or even tread design. Of course any moving part on the outfit such a swingarm bushings can be a factor too. What we are talking about here is a low speed headshake not a high speed true wobble. THAT is something that is rare but is also something that should not be taken lightly.
Claude
http://freedomsidecars.com/
Old 08-26-2013, 08:15 AM   #9
Al-X
Al-X's Avatar
Oddometer: 233
Any pics of the setup?
98 Honda XR600R, 06 Suzuki DL1000VS ADV, 11 Honda XR125L, 01 Honda CR250R
90 Yamaha DT180, Yamaha PW80, for the laaitie.
PREV: 95 DR250S, 04 KLR650, 96 R1100GS, 06 WeeStrom, 05 DRZ400, 00 XR650R, 07 KTM525XC
Al-X is offline   Reply With Quote
Old 09-02-2013, 10:56 AM   #10
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,996
Look up the 12x12 build on here and you will see how I mounted the VW dampner on my Vstrom rig.
Alan..
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Times are GMT -7.   It's 08:08 PM.
