Old 02-19-2013, 08:33 AM   #1
ExTex OP
Oddometer: 227
ATF for Clutch Hydraulic Fluid ?
I'm rebuilding the clutch hydraulic system on my Nighthawk 650 and would like to replace the DOT 3 brake fluid with ATF.
Are there any problems that will arise if I do this ?
The ATF is a lot easier to be messy with and there should be no high temperatures to cause any boiling.
I appreciate any comments.
Ride Safely,
ExTex
1983 Nighthawk 650
1989 Inteceptor VTR 250
1985 Sabre 700.......Sold
1983 Shadow 500.... sold
2006 Ninja 500........ sold
ExTex is offline   Reply With Quote
Old 02-19-2013, 08:37 AM   #2
Hootowl
Oddometer: 1,257
I use it on my 990 KTM
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is online now   Reply With Quote
Old 02-19-2013, 08:39 AM   #3
jar944
jar944's Avatar
Oddometer: 642
Ride Safely,
If it calls for brake fluid you CANNOT use mineral oil (atf) in the system. The seals are not compatible.
jar944 is online now   Reply With Quote
Old 02-19-2013, 09:17 AM   #4
ExTex OP
Oddometer: 227
Thanks. Seal compatibility is very important, so I will continue to use brake fluid.
Thanks again,
ExTex
1983 Nighthawk 650
Times are GMT -7.   It's 09:28 AM.
