Old 02-12-2013, 08:40 AM   #1
zigyphoto OP
Pay attention
Oddometer: 804
Parts source for Suzuki SV650 ?
My friend has a 2002 Suzuki SV650 and needs some parts such as shift and brake levers, etc.
Anyone have recommendations on good sources for these kinds of parts?
Since I ride an R12GS, I have no idea where to look.
thanks,
zigy
zigyphoto is offline   Reply With Quote
Old 02-12-2013, 10:43 AM   #2
Speedo66
Oddometer: 4,659
That's a common bike, probably a million parts on Ebay.
He can also check www.SVRider.com classifieds
'01 Kawasaki W650
'05 Yamaha XT225
Speedo66 is offline   Reply With Quote
Old 02-12-2013, 11:05 AM   #3
zigyphoto OP
Pay attention
Oddometer: 804
thank you!
SHE'LL be appreciative.
z
Old 02-12-2013, 04:40 PM   #4
ABHulgan
The Flying Mythos
ABHulgan's Avatar
Oddometer: 999
Shift and (rear) brake levers are pretty much unobtainium in my experience, unless you want to pay dealer price. Neither of these are folders, so they break off pretty often in tipovers. When I bought my 01 SV, the rear brake lever footpeg was broken off. Dealer wanted 78.00 for new; I couldn't find one on Ebay. I drilled and tapped the end, then used a bolt, sleeve, and jam nut, then forced a rubber sleeve over it. Been holding for a while now.
The hand levers, even aftermarket, are 25.00 per. Your 'friend' may have better luck buying the ASV knockoffs on Ebay for the same money. Some have had pretty good luck with them.
She should enjoy the SV. They're a great all-around moto.
"I tried to move my mind there and nowhere else and imagine a single detail that, if I didn't see it that weekend, I never would... The world is easily lost."
James Dickey
ABHulgan is online now   Reply With Quote
Old 02-12-2013, 04:50 PM   #5
zigyphoto OP
Pay attention
Oddometer: 804
thanks so much for both the detailed response for the "she" and the fine Dickey quote on your response.
I always appreciate a literate rider; coming thru my area, stop in and we can talk books.
zigy
Old 02-12-2013, 05:01 PM   #6
greendude
greendude's Avatar
Oddometer: 1,081
Blair at SVracing.com might be worth a try
plenty of aftermarket stuff available for these also
greendude is offline   Reply With Quote
Old 02-12-2013, 08:47 PM   #7
zigyphoto OP
Pay attention
Oddometer: 804
more thanks!
i LOVE ADVrider: where else would someone in OZ reply to such a simple request?
thanks from an occasional Sydneysider...
zigy
Old 02-16-2013, 06:51 PM   #8
AviatorTroy
AviatorTroy's Avatar
Oddometer: 1,253
In descending order...
SVRider classifieds
eBay
Ronayers.com microfiche
Bikebandit.com microfiche
A Suzuki dealer parts department
I prefer OEM levers and controls, if she is ok with aftermarket parts there are other options as well.
AviatorTroy is offline   Reply With Quote
Old 02-17-2013, 08:17 PM   #9
Alphamale11
Oddometer: 54
http://www.dietzracing.com/
I rebuilt an 01 GSXR600 using LOT's of parts bought through him. He knows his suzuki's. Good guy.
Alphamale11 is offline   Reply With Quote
Old 02-19-2013, 09:34 AM   #10
dasrider
Oddometer: 49
oneidasuzuki.com
hondaeasttoledo.com
^ both are about the cheapest online OEM parts I can find.
I wouldn't recommend going with Emgo or Chinese rip-off aftermarket handlebar levers. I've had bad luck with them not being machined at the right tolerances. Ends up with annoying side-effects like the brake light switch not engaging properly.
Quality aftermarket mfgs like Pazzo or ASV would be a good alternative to OEM.
dasrider is offline   Reply With Quote
Old 02-19-2013, 10:40 AM   #11
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 2,976
Send a message via AIM to Bronco638 Send a message via Yahoo to Bronco638
I have used Power Sports (LINK) and Boulevard Suzuki (LINK) in the past. Both have good pricing.
Be sure that all of the "savings" in low unit pricing isn't "shifted" to the Shipping & Handling charges. That is, I've found sites that have lower costs for the parts you want but when it comes to shipping, they're 2x or 3x more. So, be sure to (almost) complete the check out process before you decide which parts source to use.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Times are GMT -7.   It's 02:50 PM.
