Old 02-19-2013, 09:56 AM   #1
john479 OP
john479's Avatar
Oddometer: 113
Honda XL500R starting problem
Hi all,
I'm in need of a little advice on my XL500R restoration.
I can't get it to start or when it does, it only runs for 5 seconds. I've found that if I hold my manual decompression lever on and kick it over to prime it and then kick it, it sometimes does start but for only about 5 seconds. This makes it sound like a fuel problem but I've thoroughly cleaned the carb and used a good rebuild kit. It has a good spark and plenty of compression, so much that when trying a bump start, it locks the back wheel up. Tried a different CDI but exactly the same.
Anyone got any ideas?
Thanks,
John
john479 is offline   Reply With Quote
Old 02-19-2013, 11:56 AM   #2
lrutt
SILENCE.....i kill you
lrutt's Avatar
Oddometer: 1,347
first off, is your gas tank venting?
Have you left the bowl off and are you sure you are getting good gas flow through the needle? If not could be petcock, carb, tank vent.
Do you have an intake leak (major) typically this would make it race but if it's a big leak it could lean it out a lot.
How old is the fuel?
Exhaust system is not plugged is it?
What year BTW. just the single carb, not that funky dual arrangement of the 600's is it?
2006 HD 1200C, 2006 Tri Scrambler, 2001 Duc M900, 2001 Hon XR650L, 1994 HD Heritage, 1989 Hon Hawk GT, 1978 Hon CB750K / sidecar, 1977 Guzzi 850 LeMans, 1976 Hon CB750K, 1965 Hon 305 Dream, 1973 Nort 850 Commando, 1971 Tri Trophy 650, 1970 Hon Trail 90, 1970 Tri Tiger 650, 1973 Hon Z50, 1984 Yam Virago 1000, 1981 Hon Passport 70, 1970 Suz T250, 1971 Yam RT1 360, 1965 Hon CT200
lrutt is offline   Reply With Quote
Old 02-19-2013, 12:52 PM   #3
cam14
Oddometer: 181
Might consider posting this in the Thumper section also.
Pull the spark plug, if wet then flooded. If dry and flaky, then going lean. Also check the stator to make sure it is still creating spark.
Set idle to round 2K RPM and adjust polit to 2.5 turns from full seat (IIRC) and then adjust from there.
Sometimes valve adjustments can make a big differance.
None of this will matter if you are trying to run old and/or dirty gas. There are lots of small holes and passages that old fuel can gum up both carb and pecock valve.
Hope this helps.
cam14 is offline   Reply With Quote
Old 02-19-2013, 02:45 PM   #4
john479 OP
john479's Avatar
Oddometer: 113
Yes, I'm getting good flow throught the petcock and needle. Can't see I have an intake leak as I've changed the o-rings on the rubber boot and spacer and they''re done up tight. Exhaust is fine as I tried it without the exhaust and it did the same thing - ran for a few seconds if I prime it with full choke, holding decompression lever in. Then big kick and it will start but die after a few seconds. Does behave like fuel starvation.
It's 1982 so single carb thank goodness
I will try fresh gas although it's not that old and no signs of things getting gummed up. Even if the gas was old, surely it wouldn't run at all? Carb seemed ok when I rebuilt it. Probably didn't need new jets but since it came with the kit I changed them anyway. Main reason for the kit was new o rings and gaskets.
Thanks for the help
Old 02-19-2013, 04:07 PM   #5
john479 OP
john479's Avatar
Oddometer: 113
Posted in Thumpers section also
Old 02-19-2013, 04:42 PM   #6
stiggs13
stiggs13's Avatar
Oddometer: 203
take the tank off and check the connections on the right side, I had one jiggle lose under there and gave me similar problems on my xl
stiggs13 is offline   Reply With Quote
Old 02-19-2013, 08:33 PM   #7
redprimo
Oddometer: 458
Does sound like a fuel problem. have you checked the petcock filter screen? Ive got a Mikuni on my Xl500 so I'm not familiar with the stock carb, but I've had to clean old carbs more than once before getting them to run.
redprimo is offline   Reply With Quote
Times are GMT -7.   It's 09:22 AM.
