Old 05-15-2007, 02:47 PM   #1
RAW OP
stamen in the sniffer
RAW's Avatar
Oddometer: 3,835
Strange tire wear: What's the problem here?
So, I noticed some odd wear on my front tire the other day.
I took a photo (that doesn't really show the problem, but . . . )
The circled spots are worn more than the rest of the tread; they're low spots.
Is this because of overinflation? or underinflation? or bad balance?
Get $5 off of your smugmug signup!
Enter code: sA9I4bmgcofRU
RAW is offline   Reply With Quote
Old 05-15-2007, 02:53 PM   #2
Cauldron
Now in DESMODROMIC!
Cauldron's Avatar
Oddometer: 2,841
Feathering. You need an alignment.
and sorry about the D-con sprinkles on your strawberry shortcake.
Cauldron is offline   Reply With Quote
Old 05-15-2007, 03:17 PM   #3
RAW OP
RAW's Avatar
Oddometer: 3,835
So, you think the forktubes are slightly off in the clamps?
What are the torque values for the clamp bolts?
I figure I can try loosening them to see if that "relieves" any tension. And then just tighten the clamps back up.
Any other suggestions?
Old 05-15-2007, 03:27 PM   #4
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,288
That's classic tire design right there. It's the 90° corner of a tread block that faces opposite the direction of friction. You know, the corner of the square is facing the friction of the road surface. The result is things like braking forces cause the 90° corners to go away first.
The tread blocks are shaped and oriented that way to visually wear out quicker. The tire doesn't actually get less traction with the front corner of the tread blocks worn off, but it sure looks like it does.
And if it looks like it gets less traction, then you need to buy a new tire fool.
Just keep your head down and row, you backbone of the economy
- Jim
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 05-15-2007, 03:43 PM   #5
Cauldron
Now in DESMODROMIC!
Cauldron's Avatar
Oddometer: 2,841
don't know the torque. Might help.
You could try the string trick to make sure the back tire is in line with the front.
Or Poolside could be on to something and they all do that. :shrug
Old 05-15-2007, 07:18 PM   #6
Motornoggin
Two-Bit Throttle Bum
Motornoggin's Avatar
Oddometer: 20,549
Send a message via MSN to Motornoggin Send a message via Yahoo to Motornoggin
Pretty classic block tread wear pattern. I'de say run it until the bars show and throw a new one on.
O.K. Joke's over. You can bring back the constitution now. Please.
My Wyoming has an East infection.
http://motornoggin.smugmug.com
Motornoggin is offline   Reply With Quote
Old 05-15-2007, 07:27 PM   #7
RAW OP
RAW's Avatar
Oddometer: 3,835
Thanks. I'll stop worrying about it.
I just hadn't noticed it wearing like this previously.
Maybe I was just too sensitive this week.
Old 05-15-2007, 09:00 PM   #8
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 8,182
Tired
Looks like a cupped Metzler Tourance. I'd run 40psi on the next one and keep my eye on it AND the pressure.
I am not intimidated by the DMV
James and Colleen Tucker.
DMV service. Moto buy/prep. Room rentals. Travelers help.
Aut viam inveniam aut faciam
TUCKERS is offline   Reply With Quote
Old 05-15-2007, 09:04 PM   #9
Jeffro115
Redemption.
Jeffro115's Avatar
Oddometer: 4,162
Send a message via AIM to Jeffro115 Send a message via MSN to Jeffro115 Send a message via Yahoo to Jeffro115
Aw, don't tease the man.
Raw, my tires do the exact same thing. No problems--all normal wear.
Some fronts do it more than others I have found.
Danger is one thing. But danger plus extreme discomfort for long periods is quite another.
Jeffro115 is offline   Reply With Quote
Old 05-16-2007, 05:56 AM   #10
gsweave
Yinz, blinkers are on.
gsweave's Avatar
Oddometer: 9,988
Looks like normal BMW R bike tire cupping at 8,000 miles.
I wouldn't worry much about it, though it can be frustrating, I have seen it on about 10 differant tire sets, of mine.
Start looking at other R bikes, you wll see it more often than not.
Combination of Telelever and block tread. IMHO
What PSI's have you been running? How many miles on tire?
If you can squeeze 14,000 miles out of a front, on a GS, you done good
If your looking for me. I will be at Rella's eating Blackberry pie.
http://www.youtube.com/watch?v=qri3VhRQA7Q
http://www.youtube.com/watch?v=_ampAFmwP_E
gsweave is offline   Reply With Quote
Old 07-06-2007, 05:40 PM   #11
GSman of La Mancha
So!? My dog loves me...
GSman of La Mancha's Avatar
Oddometer: 602
new life to old thread?
Okay, this thread is old - but - I did a search for cupping and this is what came back...
I have a question related to recent experience. First, a cigar and port wine and some background info is necessary.
Bike is 05 r12GS. Tires are Metz Tourance. I am 6'6" 300lbs ("my Gawd man that's over 20 stone!" he said in awe. By, a bit I'd say was my laconic reply)
On this set, before EVERY STINKING RIDE, i checked and adjusted my air pressure.
I have an excellent, high quality air guage ("it's German and it's expensive therefore it's gotta be good")and I used it to set the pressure at 36 front 42 rear. If my pressure was within less than a pound of these numbers I didn't add air. Sometimes I had to let some air out...
Over the last 6500 miles I have seen NO CUPPING on the front. The prior set which were Trailwings had a cupped front at 6k.
I have had other sets of Metz T's on another GS but I have NEVER been so dilligent about checking AP. These other Metz tires did cup.
Question: Does airpressure - as in over or underinflated tires - lead to cupping? Have I proved anything with this bike re airpressure and cupping being related? After all, the trail wings did cup on this bike where as these Metz T's didn't and nothing has been changed/aligned on the forks etc...
Just curious so I thought I'd "ax d quastein"
Sometimes I believe what I see. Other times I see what I believe. Occasionally, I don't even look.
-Me
GSman of La Mancha screwed with this post 07-06-2007 at 05:45 PM
GSman of La Mancha is offline   Reply With Quote
Old 07-06-2007, 08:10 PM   #12
Boatman
Ride more, BS less!
Boatman's Avatar
Oddometer: 8,448
Under inflation will cup the front so will heavy use of the front brake. Put the together and you get severe cupping. Once it starts it's pretty hard to stop.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 07-06-2007, 08:59 PM   #13
ibafran
villagidiot
Oddometer: 1,176
some riders hate the condition and dismount the tire every 1000 miles and flip it over. i think that is a little too anal. usually, to a man, they swear that it works and is the only answer.
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 07-07-2007, 09:42 PM   #14
openboatt
Don't harsh my mellow
openboatt's Avatar
Oddometer: 264
I'd kill
To get that kind of milage out of a tire... obt
openboatt is offline   Reply With Quote
Old 02-22-2013, 03:11 AM   #15
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 495
Send a message via Skype™ to RedRupert
That sort of tyre wear comes from braking... too much hard braking. So stop braking for corners/turns and look further ahead so as to avoid heavy breaking for other reasons. I'm not saying ride slower!
KTM 950 Adventure (2004)
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Times are GMT -7.   It's 01:45 AM.
