Old 02-19-2013, 04:03 PM   #1
john479 OP
john479's Avatar
Oddometer: 113
Honda XL500R starting problem
Hi all,
I'm in need of a little advice on my XL500R restoration.
I can't get it to start or when it does, it only runs for 5 seconds. I've found that if I hold my manual decompression lever on and kick it over to prime it and then kick it, it sometimes does start but for only about 5 seconds. This makes it sound like a fuel problem but I've thoroughly cleaned the carb and used a good rebuild kit. It has a good spark and plenty of compression, so much that when trying a bump start, it locks the back wheel up. Tried a different CDI but exactly the same.
Anyone got any ideas?
Thanks,
John
john479 is offline   Reply With Quote
Old 02-19-2013, 04:06 PM   #2
john479 OP
john479's Avatar
Oddometer: 113
More info
I'm getting good flow throught the petcock and needle. Can't see I have an intake leak as I've changed the o-rings on the rubber boot and spacer and they''re done up tight. Exhaust is fine as I tried it without the exhaust and it did the same thing - ran for a few seconds if I prime it with full choke, holding decompression lever in. Then big kick and it will start but die after a few seconds. Does behave like fuel starvation.
I'll try a squirt of easy start and see if it fires. Bike is 1982 so single carb
Old 02-25-2013, 02:32 PM   #3
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Location: Da frozen tundra eh? 1.5 mile west of Lambeau
Oddometer: 792
When you say you cleaned the carb, did you actually completely disassemble it and clean all internal passages and jets manually? When I do this I use strands of copper wire pulled from 12ga or 16ga wire and I push it through all the jet holes and carb passages. Then I blast them all out with carb cleaner. Then I blast them all out with compressed air.
This is the only thorough way I know to really clean a carb. No amount of soaking or carb cleaner does it without actual breakdown and manual cleaning.
That said, is the float level properly set? Any internal screen/strainer in the carb cleaned? Is the fuel shut-off valve in the carb free to open and clear? That is the little valve above the float level arm.
When life throws you a curve,.....lean into it!
42+ year rider, 22+ year MSF Coach, Street, Dirt, Ice, ride em all!
Andyvh1959 is offline   Reply With Quote
Times are GMT -7.   It's 03:35 AM.
