Old 02-25-2013, 02:40 PM   #16
KungPaoDog
Oddometer: 423
Latex gloves usually hold up pretty well to acetone, ethanol, OK but not great to MEK, whereas Nitrile are pretty good with most petroleum based stuff, especially oil and grease. DON'T TAKE MY WORD FOR ANY OF THAT. Get hurt on your own experiments, and other disclaimer stuff.
I still use Latex for home wrenching, since I try not to go elbow deep in grease, and an oil change shouldn't get enough oil on your hands to wreck latex gloves instantly.
Go cheap. You will tear through any disposable glove with something sharp, and they all get thrown away as soon as they are removed.
2010 Honda NT700V-Red
KungPaoDog is offline   Reply With Quote
Old 02-25-2013, 05:39 PM   #17
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,536
^^^ I dipped some "good brand" Latex and Nitrile into Acetone and both turned to mush within minutes.
Have tools, will travel!
Old 02-25-2013, 07:22 PM   #18
gsweave
Yinz, blinkers are on.
Oddometer: 11,435
Stolen from here....
http://www.aps.anl.gov/Safety_and_Tr...selection.html
also contains chemical listing with glove type recommendation.
Yes nitrile is poor against acetone.
Glove Chart
TypeAdvantagesDisadvantagesUse Against
Natural rubberLow cost, good physical properties, dexterity Poor vs. oils, greases, organics. Frequently imported; may be poor quality Bases, alcohols, dilute water solutions; fair vs. aldehydes, ketones.
Natural rubber blends Low cost, dexterity, better chemical resistance than natural rubber vs. some chemicals Physical properties frequently inferior to natural rubber Same as natural rubber
Polyvinyl chloride (PVC) Low cost, very good physical properties, medium cost, medium chemical resistance Plasticizers can be stripped; frequently imported may be poor quality Strong acids and bases, salts, other water solutions, alcohols
Neoprene Medium cost, medium chemical resistance, medium physical properties NA Oxidizing acids, anilines, phenol, glycol ethers
Nitrile Low cost, excellent physical properties, dexterity Poor vs. benzene, methylene chloride, trichloroethylene, many ketones Oils, greases, aliphatic chemicals, xylene, perchloroethylene, trichloroethane; fair vs. toluene
Butyl Speciality glove, polar organics Expensive, poor vs. hydrocarbons, chlorinated solvents Glycol ethers, ketones, esters
Polyvinyl alcohol (PVA) Specialty glove, resists a very broad range of organics, good physical properties Very expensive, water sensitive, poor vs. light alcohols Aliphatics, aromatics, chlorinated solvents, ketones (except acetone), esters, ethers
Fluoro- elastomer (Viton) ™ *Specialty glove, organic solvents Extremely expensive, poor physical properties, poor vs. some ketones, esters, amines Aromatics, chlorinated solvents, also aliphatics and alcohols
Norfoil (Silver Shield) Excellent chemical resistance Poor fit, easily punctures, poor grip, stiff Use for Hazmat work
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 02-25-2013 at 07:32 PM
gsweave is offline   Reply With Quote
Old 02-25-2013, 07:34 PM   #19
gsweave
Oddometer: 11,435
Glove Type and Chemical Use
*Limited service VG= Very Good G= Good F=FairP=Poor (not recommended)
ChemicalNeopreneNatural Latex
or Rubber
ButylNitrile Latex
*Acetaldehyde VG G VG G
Acetic acid VG VG VG VG
*Acetone G VG VG P
Ammonium hydroxide VG VG VG VG
*Amyl acetate F P F P
Aniline G F F P
*Benzaldehyde F F G G
*Benzene F F F P
Butyl acetate G F F P
Butyl alcohol VG VG VG VG
Carbon disulfide F F F F
*Carbon tetrachloride F P P G
Castor oil F P F VG
*Chlorobenzene F P F P
*Chloroform G P P P
Chloronaphthalene F P F F
Chromic Acid (50%) F P F F
Citric acid (10%) VG VG VG VG
Cyclohexanol G F G VG
*Dibutyl phthalate G P G G
Diesel fuel G P P VG
Diisobutyl ketone P F G P
Dimethylformamide F F G G
Dioctyl phthalate G P F VG
Dioxane VG G G G
Epoxy resins, dry VG VG VG VG
*Ethyl acetate G F G F
Ethyl alcohol VG VG VG VG
Ethyl ether VG G VG G
*Ethylene dichloride F P F P
Ethylene glycol VG VG VG VG
Formaldehyde VG VG VG VG
Chemical
Neoprene
Natural Latex
or Rubber
Butyl
Nitrile
Formic acid VG VG VG VG
Freon 11 G P F G
Freon 12 G P F G
Freon 21 G P F G
Freon 22 G P F G
*Furfural G G G G
Gasoline, leaded G P F VG
Gasoline, unleaded G P F VG
Glycerine VG VG VG VG
Hexane F P P G
Hydrochloric acid VG G G G
Hydrofluoric acid (48%) VG G G G
Hydrogen peroxide (30%) G G G G
Hydroquinone G G G F
Isooctane F P P VG
Isopropyl alcohol VG VG VG VG
Kerosene VG F F VG
Ketones G VG VG P
Lacquer thinners G F F P
Lactic acid (85%) VG VG VG VG
Lauric acid (36%) VG F VG VG
Lineoleic acid VG P F G
Linseed oil VG P F VG
Maleic acid VG VG VG VG
Methyl alcohol VG VG VG VG
Methylamine F F G G
Methyl bromide G F G F
*Methyl chloride P P P P
*Methyl ethyl ketone G G VG P
*Methyl isobutyl ketone F F VG P
Methyl methacrylate G G VG F
Monoethanolamine VG G VG VG
Morpholine VG VG VG G
Chemical
Neoprene
Natural Latex
or Rubber
Butyl
Nitrile
Naphthalene G F F G
Naphthas, aliphatic VG F F VG
Naphthas, aromatic G P P G
*Nitric acid G F F F
Nitromethane (95.5%) F P F F
Nitropropane (95.5%) F P F F
Octyl alcohol VG VG VG VG
Oleic acid VG F G VG
Oxalic acid VG VG VG VG
Palmitic acid VG VG VG VG
Perchloric acid (60%) VG F G G
Perchloroethylene F P P G
Petroleum distillates (naphtha) G P P VG
Phenol VG F G F
Phosphoric acid VG G VG VG
Potassium hydroxide VG VG VG VG
Propyl acetate G F G F
Propyl alcohol VG VG VG VG
Propyl alcohol (iso) VG VG VG VG
Sodium hydroxide VG VG VG VG
Styrene P P P F
Stryene (100%) P P P F
Sulfuric acid G G G G
Tannic acid (65%) VG VG VG VG
Tetrahydrofuran P F F F
*Toluene F P P F
Toluene diisocyanate F G G F
*Trichloroethylene F F P G
Triethanolamine VG G G VG
Tung oil VG P F VG
Turpentine G F F VG
*Xylene P P P F
Reviewed January 14, 2011
The Advanced Photon Source is an Office of Science User Facility operated for the U.S. Department of Energy Office of Science
by Argonne National Laboratory.
1Paul 2:15
Old 02-25-2013, 08:19 PM   #20
triplenickel
triplenickel's Avatar
Oddometer: 2,426
Originally Posted by kantuckid View Post
Still have the question on how well latex handles solvent-not paint stripper but lacquer thinner type stuff for limited exposure.
Find the MSDS for your product online and it will tell you which type of material your gloves should be made from.
07 SE
PG007
Old 02-26-2013, 06:44 AM   #21
kantuckid OP
Oddometer: 2,933
I "won" an ebay auction yesterday for a box/100 latex gloves for 99cents so I'll try them for a bit. My use is usually greasy stuff but some AB paint work. There are some bundles of 100 8 mil nitrile gloves there for a nice price too. Definitely the better place to shop gloves on the cheap.
"If I had my life to live over,I'd dare to make more mistakes next time...I'd relax,I'd limber up.I'd be sillier than this trip, take fewer things seriously, I would take more chances... take more trips...climb more mountains...swim more rivers...eat more ice cream." Jorge Luis Borges, at age 85
kantuckid is offline   Reply With Quote
Old 02-28-2013, 05:57 AM   #22
fiep
fiep's Avatar
Oddometer: 1,938
have the blue mid weights and the black heavy weights
(and some white doctor weight gloves for paint jobs of finicky carb work)
feels like
they tear only from a puncture
and it does not take more abuse to poke tru the thicker material
at least with me they last about the same
for abusive jobs, like changing tires, I found these to be great
close to indestructable
yet a lot more feel than 'real' work gloves
leather work gloves on my piano hands feel like cardboard boxes
these are very stretchy,
so they fit snug even on my hands
but allow for total freedom of movement
fiep is offline   Reply With Quote
Old 02-28-2013, 01:42 PM   #23
tvpierce
tvpierce's Avatar
Oddometer: 367
feels like
+1
I found these to be great for 90% of the shop work I do. They're tough as hell, and give pretty good feel. I've even washed them when they've gotten a little grubby: just keep them on and wash your hands, then hang them to dry.
When I have a real oily/greasy job, I break out the trusty old blue nitriles.
The laws of the road are superseded by the laws of physics.
"But I had the right of way!" makes a pretty crappy epitaph.
tvpierce is offline   Reply With Quote
Old 03-01-2013, 09:29 AM   #24
gspdbill
noobie allover again
Oddometer: 404
Had been using the Blue Nitrile (sp?) in 5mm but they tore real easily. Have a box of the 8mm now and they've been almost indestructible compared to the 5mm. Only issue I have is my hands sweat like crazy when I wear either of them, oh well. I get them usually from Amazon. May jump up a size to see if that reduces the sweating. Wouldn't want to try the black, I like to know when my hands have grease/oil on them so I don't touch anything I don't want oil on.
Just picked up another pair of Mechanix gloves yesterday for the heavy duty stuff.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 03-01-2013, 09:36 AM   #25
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,536
Old 03-01-2013, 10:29 AM   #26
Keating
pre-n00b
Oddometer: 187
I use Kimberly-Clark blue nitrile gloves from costco for "light" messy work.
Nitrile dipped cotton knit gloves for heavier messy work (12 for $6 at Home Depot) and thin stretchy deer skin roper gloves for "drier" work. Tires, general wrenching, etc
The wife is still a little freaked by the whole thing but what ya gonna do? Stay at home and die in your sleep? - laramie LC4
'04 KLR650
Keating is offline   Reply With Quote
Old 03-01-2013, 03:26 PM   #27
gsweave
Oddometer: 11,435
Originally Posted by H96669 View Post
Have tried in years past a couple differant versions of this...
Works great against copper allergies and light dust, not much else.
1Paul 2:15
Old 03-02-2013, 08:16 AM   #28
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,536
I have some of the other versions, unlike that one only good with water soluble products. But the best thing is that they make your hands much easier to clean afterward. And a good thing I was playing at cleaning the expansion foam gun yesterday, not much point in wearing gloves the acetone eats them and then expansion foam residues makes Nitrile so sticky as to be unuseable.
Not perfect for sure them "gloves in a bottle" but think of them as a second barrier for when the Nitrile/Latex fail, they always do....!
Old 03-02-2013, 04:03 PM   #29
HapHazard
t00 0ld 2b n00b
HapHazard's Avatar
Oddometer: 2,231
^I have a pair of butyl rubber "chemical" gloves I bought at the army surplus store for $10 that I use when I have to deal with acetone or other truly serious chemicals. Transfer through skin is not good.
They also are great for washing the car when it's cold (like today).
HapHazard is offline   Reply With Quote
Old 03-25-2013, 09:31 AM   #30
tvpierce
tvpierce's Avatar
Oddometer: 367
I have that same problem. That's one of the big advantages of the woven/nitrile coated gloves referenced above: since the back half of the glove is woven, they breathe... so zero sweaty hands.
Times are GMT -7.   It's 08:27 AM.
