Old 02-20-2013, 01:48 PM   #1
indr OP
Oddometer: 501
Best way to clean air box (fine silt and sand)
indr screwed with this post 02-22-2015 at 09:37 PM
indr is offline   Reply With Quote
Old 02-20-2013, 02:31 PM   #2
Vankaye
n00b on the move
Oddometer: 225
pressure washer?
If that's not possible I would submerse it in soapy water and go at it with a small brush. Maybe use a heatgun to put and 90* angle on a toothbrush.
Vankaye is offline   Reply With Quote
Old 02-20-2013, 03:52 PM   #3
ibafran
villagidiot
Oddometer: 1,289
Run it thru the dishwasher. If that doesn't do it, take it to the magic wand car wash. Truck needs a wash anyway, right? Silt might be sticking because the plastic has some sort of static charge. Find an anti-static pad and touch it to that? That's all that I can think of?
"beware the grease mud. for therein lies the skid demon."-memory from an old Honda safety pamphlet
ibafran is offline   Reply With Quote
Old 02-20-2013, 04:47 PM   #4
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,407
Air filter cleaner. Test it first before spraying the whole thing down to make it doesn't melt it. Then a bath with Dawn dish detergent and it should be good to go.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 02-20-2013, 10:28 PM   #5
black_labb
Oddometer: 44
May be a bit odd of a suggestion, but sodium percarbonate (nappysan/ diaper cleaner) works quite well to remove just about anything without any mechanical rubbing. It is most active in hot water. just soak it in hot water/sodium percarbonate, it's pretty impressive stuff.
black_labb is offline   Reply With Quote
Old 02-21-2013, 06:30 AM   #6
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,679
Anchor it to a sizeable rock, and drop it in a local stream for 24 hours.
Old 02-21-2013, 07:04 AM   #7
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,218
dishwasher
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 02-21-2013, 09:32 PM   #8
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
Dishwasher, or Simple Green and an old toothbrush.
Flashmo is offline   Reply With Quote
Old 02-25-2013, 11:31 AM   #9
JensEskildsen
Oddometer: 1,041
Use kerosene it "dissolves" the glue-like dirt. After that use a brush, and finish of with hot water and/or pressure washer.
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 02-25-2013, 03:29 PM   #10
el queso
toda su base
el queso's Avatar
Oddometer: 714
I use Carb cleaner and a bristle brush.
el queso is offline   Reply With Quote
Times are GMT -7.   It's 07:55 AM.
