Old 02-23-2013, 01:22 PM   #1
ixab OP
just Aaron, really
ixab's Avatar
Oddometer: 376
Tool Tubes without luggage racks?
Have any of you FFrs mounted a tool tube on the right side of an F800GS but without having a luggage rack? Got photos?
I have a GL Great Basin that will sit on a TT rear top rack, but no luggage racks on the side of the bike. I'd like to mount a Tool Tube (or possibly 2 stacked) on the right side, but without a rack I'm a little derp about how to fab up a bracket. Wondering if anyone has prior art I can shamelessly copy?
I can see where a rack would mount near the bottom of the rear inner mud guard, but can't see where it would bolt up toward the rear fender. The forward bolt holes also seem too far forward?
I'm tempted to just punt on mounting there, and maybe go for the spot at the front where the bash guard and crash bars meet. I sort of hate that though. I might also skip it altogether and just keep my tool roll in the GL bag. Depends on what solution comes to light here.
Input welcome, thanks everyone!
Youtube - Death, Death, Everywhere!
ixab is offline   Reply With Quote
Old 02-23-2013, 02:36 PM   #2
1994klr250
1994klr250's Avatar
Oddometer: 652
Have one mounted on the right hand side using those two mount holes under the fender. I don't have any pictures of when I made the bracket that holds the tube. I made it out of some 1/8 thick steel for the two bolts to go through. After that I welded on two pieces of 5/8 round tube to go to the bottom and top of the tool tube. Here's a picture of where it sits at on the bike.
2300 miles on a 250 all for a sticker http://www.advrider.com/forums/showthread.php?t=616239
Fall ride on a KLR250 http://www.advrider.com/forums/showthread.php?t=754065
1994 KLR250, 2009 F800GS, 2006 KLX351
1994klr250 is offline   Reply With Quote
Old 02-23-2013, 06:28 PM   #3
BcDano
One Lucky Dude
BcDano's Avatar
Oddometer: 322
Man that is one good looking bike. Love the set up.
BcDano is offline   Reply With Quote
Old 02-23-2013, 09:43 PM   #4
sorebutt
Oddometer: 1,801
I made my own from ABS and mounted it between the Motech crash bars and skid plate. I made one for each side. I mounted them with hose clamps. You can make them the length you need to fit. I like adding a little bit of weight to the front of the bike.
sorebutt is offline   Reply With Quote
Old 02-23-2013, 11:19 PM   #5
ixab OP
just Aaron, really
ixab's Avatar
Oddometer: 376
Originally Posted by 1994klr250 View Post
Have one mounted on the right hand side using those two mount holes under the fender. ...
That is exactly what I'm picturing! I'll have to dig around for the mount holes under the fender you're talking about, because I don't see anything near the center of the fender. The holes that are obvious are way toward the the front of the the fender, almost by the shock. There is what looks like maybe two covered holes, but they have rubber plugs in them. I'm not sure what those are.
From that photo, it looks like the next thing you need to make is a kitchen sink bracket? Holy crap, man... unless those bags are all full of beer, you've got some explaining to do
No photos I guess? I'm the kind of rider that puts crash bars to the test, so I'm wondering if stuff mounted there will survive. Maybe I'll mock something up and see how exposed it ends up.
Old 02-24-2013, 06:17 AM   #6
JRWooden
Oddometer: 4,249
I'd like to see a pic. of the up-front mount!
I too like the idea of adding some weight up front!
Rear mount ... how's about this:
http://www.advrider.com/forums/showthread.php?t=446410
Old 02-24-2013, 08:23 AM   #7
1994klr250
1994klr250's Avatar
Oddometer: 652
Thanks, its been a good set up for my long distance trips.
Old 02-24-2013, 08:26 AM   #8
1994klr250
1994klr250's Avatar
Oddometer: 652
I'll try to grab some pictures of my bracket later today and post them up. I thought I was packed fairly light for this trip. That picture was from this past June when I rode from Michigan to Alaska and back. I was gone for 28 days and covered 10,500 miles. I was just north of Coldfoot when I took that picture.
1994klr250 screwed with this post 02-24-2013 at 09:06 AM
Old 02-24-2013, 08:31 AM   #9
Hucker
Lost
Oddometer: 682
I used the smaller diameter ones on my rear rack. Perfect for tire irons, tow rope, rim protectors or anything else's small like that. You can see them here:
Not to mention, tailgaters are unsure whether they are James Bond type missile launchers or not, so they typically stay back...
Hucker screwed with this post 02-24-2013 at 07:07 PM
Hucker is offline   Reply With Quote
Old 02-24-2013, 10:22 AM   #10
ixab OP
just Aaron, really
ixab's Avatar
Oddometer: 376
Originally Posted by JRWooden View Post
Nice find. It's obvious to me now that there's a mounting point mid-way up the fender. It must be underneath the plastic? How much removal is needed to get to i? I'll have to look harder. The garage is about 25 feet away, I should just get my fat ass off the couch and go out there.
Now I just need to learn to weld... and buy a welder...
I'm mostly kidding about the over-packing, because I know how the stuff can pile on for a trip. I always fantasize about leaving with a toothbrush and credit card, but once you throw camping into the mix the pile gets big pretty quick.
Old 02-24-2013, 01:17 PM   #11
JRWooden
Oddometer: 4,249
I'm not sure how it bolted up I have luggage that gets in the way ....
Old 02-24-2013, 03:07 PM   #12
lawe
lawe
Oddometer: 141
I have some pictures of my mount here: http://lmw.se/%C3%96vrigt/BMW%20800G...ube/index.html
Lars
Umeň, Sweden
BMW F650GS -05, F800GS -08
lawe is offline   Reply With Quote
Old 02-24-2013, 05:54 PM   #13
JRWooden
Oddometer: 4,249
Very nice Lars!
I did not realize the fuel tank had "wings" on the back that would allow a bracket to
slide down between the inside of the tank and the fender well!
Also, I am told that acetone will remove the yellow ink from the tubes if you care...
(try it on a small place first )
I need to go do something similar to your project if I can make it fit before my big summer trip!
I'm low on packing space!
JRWooden screwed with this post 02-24-2013 at 06:01 PM
Old 02-24-2013, 07:06 PM   #14
Hucker
Lost
Oddometer: 682
...snip...Also, I am told that acetone will remove the yellow ink from the tubes if you care...
(try it on a small place first )...snip...
I can confirm this to be true with no adverse reaction to the plastic.
Old 02-24-2013, 07:46 PM   #15
2Stamp
2Stamp's Avatar
Oddometer: 360
I shamelessly copied this one. Worked well so far.
_______________________________
2011 F800GS
2014 350XCF-W
2006 450EXC
2014 Honda Grom (hers)
2Stamp is offline   Reply With Quote
Times are GMT -7.   It's 08:29 PM.
