Old 02-23-2013, 08:55 PM   #1
SCsurfer OP
surfing explorer
Oddometer: 170
KTM 640 help needed
Doing some prep for Baja and noticed milkey residue in the crank case breather
tube. No signs of this in the oil level sight glass or the valve drive as I was doing a valve check in prep for the trip.
The bike is an '07 with 18k and I replaced the cam rollers and water pump seals about 2k miles ago .
Any input would be greatly appriciated.
'07 640 Adventure
SCsurfer is offline   Reply With Quote
Old 02-23-2013, 09:02 PM   #2
CSF
CSF's Avatar
Oddometer: 164
It may just be some condensation build up? Although you might have some leaking gaskets,and there should be signs of that in the oil and the color of the exhaust smoke... very very white, like the engine is burning some water... just a guess.
CSF is offline   Reply With Quote
Old 02-23-2013, 10:05 PM   #3
SCsurfer OP
surfing explorer
Oddometer: 170
Exhaust output is the same as when I bought the bike new .
'07 640 Adventure
Old 02-23-2013, 10:27 PM   #4
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,176
Like CSF mentioned, it is not unusual to get a snot buildup in the pipe from condensation... I find that the build up is worse in the winter due to cooler temperatures and where I live, damper conditions...
If you only have 2K on a rebuilt pump you should be good for a while, as long as you used the correct double lip pump seal...
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Old 02-24-2013, 07:21 AM   #5
CSF
CSF's Avatar
Oddometer: 164
If the exhaust is the same, its probably just condensation build up. Nothing to really worry about in that case. But just to be sure I'd drain the oil and remove filters. Inspect the oil for any contamination, if there is no evidence of anything in your oil then clean the gunk out and put fresh filters and oil in. Wait and see if the gunk comes back.
Old 02-24-2013, 07:52 AM   #6
SCsurfer OP
surfing explorer
Oddometer: 170
CSF and gunner,
Thanks for your input. Changed the oil and filters last night. No signs contamination.
'07 640 Adventure
Old 02-24-2013, 08:14 PM   #7
bmwktmbill
Traveler
Oddometer: 5,089
Surfer,
Wish I was going to Baja!!
Watch your coolant level for sure.
Pack a couple of replacement water pump seals and a spare head gasket.
Just in case?
Well that's what I'd do.
(And a headgasket is always a nice thing to have, protect it with cardboard, etc.)
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Times are GMT -7.   It's 10:19 AM.
