Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 02-24-2013, 09:34 AM   #1
LaurelPerryOnLand OP
Oddometer: 3,481
Garmin Express FREE Updates?
OK...maybe I've been on another planet...(I'll check my GPS to confirm)...but does Garmin now provide FREE Map Updates via Garmin Express?
Ran across the Garmin Express software this morning.
Downloaded it and checked for UPDATES.
After a length process...I think Garmin downloaded 2013.40 maps onto my Zumo 660 along with firmware 4.80.
Is this possible? If so, more money for farkles...
Checked my actual GPS unit and streets that I know didn't exist before...now show up!
LaurelPerryOnLand screwed with this post 02-24-2013 at 10:23 AM
LaurelPerryOnLand is offline   Reply With Quote
Old 02-24-2013, 10:39 AM   #2
bighopper
Oddometer: 188
No, Garmin doesn't provide Free updates. Most likely you had a free update available for your 660 or you have 'Lifetime Map Updates'.
I'm actually just doing the map updates for the first time to my Montana using Garmin Express, for which I purchased a 'Lifetime Map Update Card' when I purchased the CNNA on DVD. That's why you have to have you GPS attached to your computer so Express checks for a valid registered GPS.
Now the question is can I get those maps onto my computer into Basecamp?
I Just Like To Ride
'03 BMW R1150GSA
'06 BMW K1200LT
bighopper is offline   Reply With Quote
Old 02-25-2013, 03:04 AM   #3
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 13,120
OK...maybe I've been on another planet...(I'll check my GPS to confirm)...but does Garmin now provide FREE Map Updates via Garmin Express?.
For units with preinstalled maps Garmin usually provides one no cost update after purchase and registration. So, it could be as noted above that you never updated your map data and their system is allowing you one update.
Other than that, unless you have a unit for which lifetime updates are included in the cost of purchase (usually noted with an "LM" in the name of the unit) or you purchased a lifetime update to some other map data, updates are not free.
dunno.....
Old 02-26-2013, 08:15 AM   #4
MotoJim
MotoJim's Avatar
Oddometer: 224
Express Has Problems
I tried to update my Montana with City Navigator North America NT 2013.40 with Express. It did not work. It thinks it did. It now tells me my device is up to date but I have an older map set on the device.
The option to load the map data to your computer is non-existent now also.
Once again we are unit testers, not even beta testers. The programmer clearly didn't even test that the code worked before they moved it to production.
It really is pathetic.
MotoJim is offline   Reply With Quote
Old 02-26-2013, 08:44 AM   #5
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,050
Jim, see if you have GarminMapUpdater on your computer, and if you do, try firing it up and using it.
Old 02-26-2013, 03:38 PM   #6
MotoJim
MotoJim's Avatar
Oddometer: 224
Emoto, thanks for the suggestion. Unfortunately the Garmin engineers are better at removing good software than installing it.
Old 02-26-2013, 03:52 PM   #7
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,050
Send me your email and I'll email GarminMapUpdater_v3.1.19.exe if you want. All you do is throw it in a folder somewhere and double click it to run it.
Old 02-26-2013, 07:05 PM   #8
MotoJim
MotoJim's Avatar
Oddometer: 224
Found a copy to download from the net. Downloading the map right now.
Thanks Emoto!
Old 02-27-2013, 04:13 AM   #9
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,050
Thanks Emoto!
Glad it worked out!
Times are GMT -7.   It's 11:32 AM.
