Old 02-25-2013, 08:44 PM   #1
dazler OP
Oddometer: 183
wr250r or drz400s
Hi im still looking for my 1st bike.
I seen a lot of videos of the wr250r and it seem like a real fun bike but then reading more I read that some people want more power. Im pretty sure as a 1st bike the power would be perfect but also some others say you get bored of a 250 fast which I donít understand seeing some forum members have switched from much bigger bikes to the tiny wr250r and they love it.
negative - power by some people.
A coworker suggested me to look into the drz400s and I did concern is the carb are they easy to adjust would I have to be adjusting on the fly as I ride going up hill etc.
negative - close ratio gearbox, carb old technology.
I was also looking at the KTM 690 enduro R which seem to be the best of both except when I looked at the maintenance is needed more often but donít know exactly how much time a valve check takes.
But it seem it also have some issues like:
-close ratio gearbox.
-bad tank bolts.
-radiator fan shroud and blades wearing into radiator quickly.
-leaking coolant on metal pump face.
-stalling at idle at lights,ecu fuel tuning etc.
-rubber fuel or coolant hose needs to be zip tied to frame to avoid wear.
I would like some sound advice. I know theres a lot of user here that have tried the bikes in question, would it be better to get the WR250r and later on buy the Athena 290 http://www.yamaha-motor.com/sport/pr.../0/detail.aspx or the thumper racing 280 http://thumperracing.net/index.php?r...&product_id=97.
or get the DRZ400s with the ACT wide ratio gears. http://www.advancedclutch.com/100wrh02-4189
Or the KTM and fix those issues.
What would the valve check on the wr250r be with the Athena or the thumper kit?
I know stock is around 26k miles but using the big bore donít know.
I want a reliable bike I dont want to go out and worry about how Im going to get back.
Thanks.
dazler is offline   Reply With Quote
Old 02-25-2013, 08:57 PM   #2
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
I've had both. WR250R didn't have enough power for me. But it's personal preference.
Ive owned 2 DRZ400Es, and i find them the best compromise for power, weight, price, and longevity.
I'd love the 690 but couldn't justify the price. I can thrash my DRZ with peace of mind.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 02-25-2013, 09:38 PM   #3
It'sNotTheBike
Oddometer: 704
DRZ is your best choice if you are tall enough
You left out some key info which would help with knowing which bike might
be best suited to you. It would be nice to know how tall you are, what sort
of riding you intend to do ( will you stay on secondary roads or will you
sometimes need to ride on a highway) and what other experience you have
riding two-wheeled devices ( mountain bike experience can be very helpful
when you are learning to ride a dirt bike ).
I've ridden all the bikes you mention enough to have familiarity with them.
I own a KTM 690 Enduro. It's a great bike and it is easily my favorite bike of
all the bikes I have ever owned or ridden. It is not an enduro race bike nor is
it a long distance touring bike, but it is more versatile than any bike I know, and
it can take you nearly anywhere you want to ride IF your skill level is sufficient.
The problems with the 690 are all easily solved ( most of them are one-time issues
which once dealt with will not be problems any more ) and I would in no way allow the
stuff you've read on 690 problems to dissuade you from buying one. However, I'm not
sure a 690 would be a good choice for a first bike. It's got a fair amount of power ( ok, the
bike has a LOT of power ) and that could get a beginner into situations which are best
avoided ( unless you enjoy using crutches etc. ) until riding skills are better developed.
So unless you are a world-class mountain bike rider or you have competed in other forms
of motorsport the 690 is probably best left as a bike you buy for your second bike, after
you've gotten your basic skills and are ready for more power.
It's hard to beat the overall goodness of a DRZ for an intro-level street legal dirt bike. I suggest
you buy the nicest DRZ you can afford, and leave the engine stock and invest in the best
protective gear you can afford. If you must spend money on the bike, spend it on suspension
rather than power mods. And when you decide you want more power, don't fall into the trap
of modding the bike, instead just sell it and buy a KTM or a Beta or a Husaberg or whichever
other bike comes closest to what you want out of the crate, and you will end up with a
MUCH better overall bike than a DRZ or a WR250R with less time and money wasted on
mods you will never get paid for by the person who buys your first bike when you decide to
sell it.
If you can easily straddle a DRZ ( the saddle height is high ) then that's a great
choice of bike for you. Its power delivery is mellow and it will have enough power for
your first bike. The WR250R is a nice bike but at highway speed ( 75mph ) the engine is utterly
tapped out and has little to no reserve power. I see this as a safety issue which makes the WR250R
unacceptable to me personally, but if you know you won't ride on highways then the WR250R
could be enough bike for you. However a used DRZ can be had for significantly less than a
used WR250R in most cases, and that allows room in the budget for riding gear which will
make the difference between getting up laughing after a crash and a ride in an ambulance.
The importance of high quality helmet, boots, pants, armor, etc, cannot be overstated. Also
you will probably end up wanting other stuff like a hydration pack, maybe a GPS, etc. So
the price of the bike is just the beginning of the expenses and a realistic budget should
allow for at least $1500 to be spent on gear unless you buy it all used which is not a bad
idea if you can find good stuff that fits you.
It'sNotTheBike screwed with this post 02-25-2013 at 09:53 PM
It'sNotTheBike is offline   Reply With Quote
Old 02-25-2013, 09:57 PM   #4
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,403
I'm going to go the other way and say I really like my WR250R. I had a DRZ400E (Tagged) as one of my early dual sports and I enjoyed it, but the very narrow 5 spd transmission drove me nuts. You either geared it high to be comfy on the road or geared it low to have fun in the woods.
IMOP, the WR250R is a fun and enjoyable bike to ride and it so smooth with a great 6 spd transmission. BTW, I came from a Husky TE610 to the WR250R and I still enjoy the WRR. Now granted, the WRR isn't my only bike, but as a newbie you could really enjoy it. The DRZ isn't a bad bike at all, but I just couldn't get past the transmission.
BTW, I'm 6'4"/250lbs.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 02-25-2013, 09:58 PM   #5
dazler OP
Oddometer: 183
yes I forgot to mention
im 28yr 5'9'' inseam about 33Ē weight hovers between 195-200 lbs
I donít have any experience riding motorcycle except taking the MSF course.
I live in a small city the roads around here range between 30 and 65mph. I donít have a trailer that equals I will have to drive the bike back to this little city from a mayor city then I would have to ride highway speed 80mph for about 2 hours until I hit the desolate roads to get here.
I read that they both top at around the same mph. drz - wrr
Old 02-25-2013, 10:05 PM   #6
It'sNotTheBike
Oddometer: 704
Originally Posted by dazler View Post
I was also looking at the KTM 690 enduro R which seem to be the best of both except when I looked at the maintenance is needed more often but don’t know exactly how much time a valve check takes.
The valve clearance check on a 690 takes maybe 20 minutes unless
you need to install different shims. Anyone who wants a 690 is unlikely
to avoid buying one because of the valve adjustment procedure. It's just
not enough hassle to worry about. And the same goes for most of the "690
problems" stuff you listed above. I think in reality what keeps most people
who might want a 690 from buying one is that they are expensive bikes
which not everyone can comfortably afford to buy.
The main problem area with the 690 that bothers some owners is the fuel
injection system. A lack of understanding of the care and feeding of the fuel injection
system can lead to problems which can be avoided by proper use and maintenance,
such as making sure dirt doesn't enter the fuel tank, mounting an external fuel filter
which filters fuel BEFORE the fuel injector, and that sort of thing.
For a beginner rider, the important thing is that the 690 is most likely to be "too much
bike" and this can make learning more difficult and dangerous. It's like any other sport -
you don't start surfing at Pipeline or start skiing on a double-black diamond run. You learn
and grow into greater levels of challenges, and that's part of the fun of any sport.
It'sNotTheBike screwed with this post 02-25-2013 at 10:33 PM
Old 02-25-2013, 10:16 PM   #7
It'sNotTheBike
Oddometer: 704
im 28yr 5'9'' inseam about 33” weight hovers between 195-200 lbs
I don’t have any experience riding motorcycle except taking the MSF course.
I live in a small city the roads around here range between 30 and 65mph. I don’t have a trailer that equals I will have to drive the bike back to this little city from a mayor city then I would have to ride highway speed 80mph for about 2 hours until I hit the desolate roads to get here.
All three bikes are going to be tall for you in stock form. What I mean is that
you will probably have to tiptoe to reach the ground. Some riders slide their
butt off to the side of the seat and that makes it easier for them to reach the ground
on one side of the bike. I'm several inches taller than you are and I do this
on several of the bikes I ride ( I could lower the bikes but I don't see the need when
I am comfortable riding them like they are ).
It is possible to lower the bike by modding the suspension and that would probably
be a good idea for you at least in the beginning.
Now that you've explained your prospective riding routine it seems even more certain
that a DRZ 400 would be a good choice for your needs for at least the first year of riding.
The time will come when you will know you are ready to step up to the next level, but
a used DRZ should do just fine for a start. It is true that the WR250R and DRZ have similar
top speeds but the added displacement of the DRZ gives it better torque at lower rpms,
and that makes riding easier in some situations.
Many folks are waiting for Yamaha to make a 450cc version of the WR250R because the
250 just doesn't have enough power for some riding situations. Rather than wait for
that bike which may never be built, some riders buy a 350 / 450 / 525 / 530 KTM EXC or
a KTM 500 EXC. The preceding bikes are the cream of the crop of light weight 50-state
street legal dual sport bikes in the world today and they are very sweet indeed, but are
more bike than a beginner could really make use of, so owning one as a beginner would
be kind of a waste.
It'sNotTheBike screwed with this post 02-25-2013 at 10:39 PM
Old 02-25-2013, 10:50 PM   #8
DefyInertia
Saratogian
DefyInertia's Avatar
Oddometer: 153
Don't get a 690 for first bike, just a waste. I vote 250 but 400 is fine. I have a liter bike sport bike and the 250...NEVER get bored.
There's a feeling I get when I look to the West...
DefyInertia is offline   Reply With Quote
Old 02-26-2013, 07:57 AM   #9
cbig
Rift- Raft, SCooter Trash
cbig's Avatar
Oddometer: 977
If u want an old guy's advice
(And I suggest you take it...would have saved me lots of time and money when younger)
I owned a Drz for a few years. Nice bike, cheap enough, easy to mod, has all the power you would need for most dirt situations.
Having said that a 250 be it the klx250, wr250, older xr250 will make you a better dirt rider. Why? The lower power output forces you to exaggerate your dirt bike movements and body language. To get the most out of a 250 you got to lean way forward to get the rear lightened up to turn under power and break traction for example. Hill climbs are more challenging if you pick a poor line on a 250..so you learn to do a better job. The bike is lighter and more maneuverable. Because you can, you throw it around more, learning what is and isn't possible without getting tired. You learn to use finess, technique, body language and ability to solve dirt problems instead of brute power. Throttle mismanagement on an obstacle won't hurt you on a 250 but you accidentlally snap the throttle going over some rocks on a te510 or exc better hold on! Don't get me wrong, power has its place, but sometimes the results are unpredictable. Power is for heavy road use or snotty, sandy or muddy hill climbs, excess sand washes and dez like Baja. Skills learned on the light bike will serve you well.
Once you get the fundamentals down, then move up. Never buy a nice bike for your first. I recommend an older bike like a klx250 (easy to up to 300) or an xr. Why? Motorcycle riding and maintenance should go hand in hand. Learn what your bike feels and sounds like..it will save you from problems out in the sticks and you will be more confident all way round. I personally wouldn't get a wr250r. Just me, don't like fuel injection on the trail. Seen too many newer trucks and a few bikes broke down, unable to fix and no triple a. Suggest your dirt skills will help on the street.
Get a plated bike, a rack to haul it on or small trailer for your car. You'll enjoy it more that way than riding 2 hrs out and back to a trail. What happens if you break something out there?
Cb
Cbig
cbig is offline   Reply With Quote
Old 02-26-2013, 08:03 AM   #10
BlueLghtning
Oddometer: 5,403
Cb
+1 Well said. A smaller 250 will definitely make you a better rider and certainly be easier to handle off road.
Old 02-26-2013, 08:05 AM   #11
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,906
The motorcycles you named are great, but at your height and riding experience you might want to consider something milder for a very first bike. The new Honda 250 has a smooth fuel injected engine with a nice wide six-speed just like the WRR, and it has the advantage of being lower to the ground and offering a little more power in the lower rev range, which will be a big help as you learn to ride off road. And the Honda is bargain priced.
I get a kick out of people on this site that think a 250 is something to outgrow. Yeah, a 250 is a small STREET bike, but it's a big off road bike with enough power for you to hurt yourself if you're not careful.
If fuel injection is important to you, you might also look at the latest model of the XT250. You'll have to adjust valves more often than the WRR but it's very simple and there are half as many, and air cooling means never having to flush your coolant. It's a real step down in power but has a nice low seat height.
montesa_vr is offline   Reply With Quote
Old 02-26-2013, 08:15 AM   #12
BlueLghtning
Oddometer: 5,403
We just picked up a used 2013 CRF250L for my wife and the main reason to go with it over another WRR was the seat height. She's on an XT225 so even the CRF is quite a bit bigger for her, but so far she's enjoying it. I've only had a little time on it myself, but my first impressions are pretty good. For a newbie, the CRF is definitely a good choice and it does have better power down low in the rev range.
It is brand new this year, but I'm seeing used examples come on the market and I think once spring gets here, we'll start seeing more. Honda definitely priced this one right.
Old 02-26-2013, 08:29 AM   #13
Gundy
Oddometer: 950
I had both a heavily modded WRR and a lightly modded DRZ. Either one is a great first bike, but I would give the nod to the WRR for its lighter weight and handling. The DRZ is very capable, but it is more top heavy and therefore less forgiving offroad. The power on the other hand is a little more forgiving since it has torque that will get you up hills even if you don't have much skill. I am actually tempted to get one or the other again as they are both a good blend of around-town/moderate offroad/low maintenance. The WRR will be a little better at the extreme ends of things, forcing your way down some nasty singletrack, or buzzing 60 miles home on the freeway. Everything in between the extremes (really where these bikes are meant to be) its more of a toss up, maybe even favoring the power of the DRZ.
Either bike can handle the highway, but neither bike is much fun above 60mph because of wind blast, so if you plan on spending a lot of time there, I would look for a different bike altogether, like a V-Strom. The WRR 6-speed makes it a little more tolerable, but it doesn't change the experience of riding a high, 300 lb bike on knobbies fast on the tarmac. Below 60mph, again, a toss up.
I think the DRZ can be modded to an acceptable performance level for a lot less money: basically a jet kit and a 47T rear sprocket. The suspension responds well to adding stiffer springs and does not really need a revalve.
The WRR needs a pipe, programmer, maybe header too, and gearing to get the power optimized. I found it to be uncomfortable loud set up like this, and the MPG dropped quite a bit. The DRZs stock exhaust was much more reasonable. The WR rear shock really does need a revalving regardless of your weight. I
Both bikes will need a skidplate, hand guards, and radiator guards if you spend time on rougher trails. The DRZ needs case guards, but they are fairly cheap.
In either case, try not to go hog wild with performance mods....these two will never be as light and snappy as race bikes, but you also may never need to open up the engine for the entire time you own the bike.
If I had to buy one of these new, today, I'd probably go with the DRZ, but I am tall enough to deal with the extra top-heaviness. Less setup required to get it where I want it.
'12 Sertao, '00 KDX220R '12 Tenere, '04 Tiger, '09 WRR, '06 DRZ, '06 TW, '01 250 EXC, '09 KLR
Gundy screwed with this post 02-26-2013 at 10:24 AM
Gundy is online now   Reply With Quote
Old 02-26-2013, 02:19 PM   #14
kawagumby
Oddometer: 1,032
My stock 04 DRZ400S didn't have much more power than my stock 08 WR250R. Neither will wheelie worth a dang without a lot of weight shift. I don't think the power difference is as important to riding fun and effort, both road and dirt, as the 6 speed tranny and the lower CG of the WR250R. I have done dual sport rides with other experienced riders who own modified DRZs's (all bigger guys than me) and I have no problem staying up or even leaving most of them on my WR. It ain't perfect, but it is more fun.
kawagumby is offline   Reply With Quote
Old 02-27-2013, 10:28 AM   #15
dazler OP
Oddometer: 183
wow all good advice for a new guy like me.
I think I would leave the ktm out for now it seem that it weight about the same as some 250 with a lot more power but like you guys say I should start small learn get good at it and maybe later consider something bigger.
I was not considering the litle red honda crf250L due to lower HP than the wrr and about 20lbs more. but it seem that you can easily lose some weight by removing not needed stuff and swapping the exhaust a mod that almost all bikes need, to reduce some pounds.
But now im considering the CRF250L
from http://www.rickramsey.net/CRF250Lmods.htm
no fuel - 280 pounds (FMF muffler and header; removed unwanted parts)
Just with the BDSB stage 1 and the air box mod = 6 HP that seem like a good deal. http://bestdualsportbikes.com/dual-s...-honda-crf250l
most likely I will keep the bike for a real long time that why in my 1st post I mentioned the big bore kit for later down the road, if needed. it seem that they are working on one for the honda too.
I was not expecting so much love for the DRZ it seem to be a great bike then. I guess I was focusing on the FI vs Carb to much too.
Times are GMT -7.   It's 05:08 AM.
