Old 02-27-2013, 07:36 AM   #1
Hewby OP
Hewby's Avatar
Location: currently on the road, but I call Tassie home
Oddometer: 315
F650gs Coolant Temperature Sensor fell off in Coolant Temperature Sensor?
Hi all, just a quick question - I discovered this on the ripo road in Southern Argentina
worked out it was the Coolant Temperature Sensor but it doesn't want to go back on. I had a hose clamp and duct tape and have attached it back, it seems the fan is on now more than usual but other than that it seems ok. Should i be worried?
Any advice?
I am trying to make the run to Ushuaia and have 2 weeks before I finish my trip in Buenos Aries. fingers crossed I make it!
Alaska to Patagonia ..... http://www.letterstocurlyflat.blogspot.com
Hewby is offline   Reply With Quote
Old 02-27-2013, 11:31 AM   #2
Tom48
Tom48's Avatar
Oddometer: 502
If possible, go to the Chain Gang site it maybe called F650. I have a 03 F650 and if that happened to me, I would find a fix.
Thomas Sells
Tom48 is offline   Reply With Quote
Old 02-27-2013, 09:30 PM   #3
WayneC1
Oddometer: 2,721
Newby, have info on that sensor online http://www.f650gs.crossroadz.com.au/EngineSensors.html
It is also used a a large No of BMW cars & possibly other cars so should be able to pick up a replacement locally
If it does not leak fluid from the engine and the fan is working when it is in place then you should be OK to carry on, you two seem to be good at that
WayneC1 screwed with this post 02-27-2013 at 09:40 PM
WayneC1 is offline   Reply With Quote
Old 02-28-2013, 03:16 AM   #4
Hewby OP
Hewby's Avatar
Oddometer: 315
Thanks for your advice WayneC1. Though strange after 10 months on the road to still be classed a 'Newby', but learning more everyday until we die; or else I 'spouse you are dead already. Will add some JB weld to the mix and keep my eye out for a place that might sell the part or just the bracket. I hear Puntas Arenas is good.
Old 02-28-2013, 03:33 AM   #5
WayneC1
Oddometer: 2,721
Eh, it was a busy morning, I had not had a beer and you know we cant function down under until after the sun is over the yard arm and then after that we hit the wrong keys anyway for obvious reasons. The big news is they had 50mm of rain at Cobar, now thats big
Old 03-01-2013, 07:48 AM   #6
Hewby OP
Hewby's Avatar
Oddometer: 315
No probs, glad to hear of the rain. My parents have breathed a sigh of relief and say that the grass even has a tinge if green again.
Times are GMT -7.   It's 09:54 AM.
