Old 02-26-2013, 10:44 AM   #1
Clo-z-nuff OP
Oddometer: 52
Packable camp cot - not too shabby
Just an FYI. I noticed Sportsmansguide had a Belgian Military Collapsable cot that looked intriguing. They are "used" which always scares me a little but I thought for $30 it was worth a shot. Sorry, no pics but I'm mildly pleased. The one I recieved was definately new and is actually fairly sturdy. Packs down nice, probably 5-6" diameter by 2' long. It's not a real wide cot but should pack nicely on a bike and keep you off the ground.
I'm not looking to get into a sportsmansguide bashing here, just thought someone might be interested. I haven't seen these before.
Clo-z-nuff is offline   Reply With Quote
Old 02-26-2013, 11:02 AM   #2
Unstable Rider
Fart and run
Unstable Rider's Avatar
Oddometer: 2,503
Here ya go brother:
http://www.sportsmansguide.com/net/cb/used-belgian-military-foldable-cot-olive-drab.aspx?a=1145796
-“Ah, you're wasting you're time. They can't track us over rocks.
Tell them that.......... --Who are those guys?”
~Butch Cassidy
Unstable Rider is offline   Reply With Quote
Old 02-26-2013, 11:36 AM   #3
Clo-z-nuff OP
Oddometer: 52
That's the one. Helmet not included...
Old 02-26-2013, 12:07 PM   #4
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
Sweet. It's like the Byer Trilite folding cot:
http://www.byerofmaine.com/products/...ilite-cot.html
Except that the side poles slip together rather than staying in the cover and folding.
I know the Byer is excellent to sleep on - and this belgian unit is 1/2 the price.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 02-26-2013, 02:30 PM   #5
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,841
Does that cot use a bunch of 2" long steel poles that stack on the ends of one another and then slip into the sides of the fabric?
If so I have the same cot, mine was made by texsport, same price. Packs small, but heavy and is a pain to assemble. I'd only use it if I was staying in the same spot for a few days.
A couple of straps to keep the pad in place and it's actually very comfy.
HaChayalBoded is offline   Reply With Quote
Old 02-26-2013, 02:36 PM   #6
Clo-z-nuff OP
Oddometer: 52
There's (3) sections of tube on each side. Sure looks eerily similar to the trilite cot posted above but, as mentioned, the sides tubes dissassemble rather than fold. It probably took me 3-4 minutes to assemble and that included figuring out how to put it together as there were no instructions.
Old 02-26-2013, 04:11 PM   #7
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
The Ultralite cots use a system like that - the side rails are shock-corded pole sections (6 per side?) that you have to feed into the sleeve of the fabric. A bit of a pain because they try to come out every opening where a cross support comes in, but nice because you get a shorter minimum length when apart. I thought about modding a TriLite to fold shorter, but realized that 1/3 the length was the width - or the length of a cross support. The ultralite cross supports break into 2 sections, so instead of 26" they are about 13".
Old 02-26-2013, 06:12 PM   #8
sumwon
sumwon's Avatar
Oddometer: 139
I bought a couple of these from my local surplus store, works great. I have hip and back problems, so I put an REI 3.5" pad on top and sleep like a baby.
sumwon is offline   Reply With Quote
Old 02-26-2013, 07:45 PM   #9
Stalky Tracker
Stalky Tracker's Avatar
Oddometer: 129
Sounds like the LuxuryLite or something similar; http://www.luxurylite.com/
I used mine for about 3 months of actual usage and it works fine and packs small. Weights about 3 - 4 pounds, though.
2006 Suzuki V-Strom DL650K
Stalky Tracker is offline   Reply With Quote
Old 02-26-2013, 09:02 PM   #10
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,328
This one is like the luxury lite but it's 2" wider at 26" and that can make a big difference in comfort if you are a Clydesdale.
http://www.rei.com/product/846491/th...ylite-mesh-cot
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Old 02-26-2013, 10:05 PM   #11
JR356
JR356's Avatar
Oddometer: 3,645
REI mesh cot linked above and Luxurylite mesh cot are the same.
Cascade Designs(Thermarest)bought Luxurylite and Luxurylite is now a dealer for their former product.This is explained on their home page.
Look at specs on both sites,they are the same.
JR356
JR356 screwed with this post 02-26-2013 at 10:11 PM
JR356 is online now   Reply With Quote
Old 02-27-2013, 08:38 AM   #12
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,328
JR356
Yes, I was trying to point out that the mesh version is 2" wider. More comfort. +$10. Only a few ounces more.
Old 02-27-2013, 08:44 AM   #13
Clo-z-nuff OP
Oddometer: 52
Unless you are backpacking and a gram counter, for 2-3 pounds and 2" I'd gladly save $200+ and get the military surplus one...just sayin'...
Old 02-27-2013, 10:49 PM   #14
Hucker
Lost
Oddometer: 674
Looks similar to this cot that I picked up for cheap on CL. Put a 2.5" pad on it and sleep like a baby. Easy setup/takedown.
Hucker is offline   Reply With Quote
Old 02-28-2013, 09:15 AM   #15
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,976
So - the only take-down cot that hasn't been mentioned yet is the Go Kot:
http://www.campingcot.com/?section=original
Very similar to the TriLite - except with 2 extra legs. They are lighter steel than the TriLite, but it is higher weight rated (350 lb vs 250 lb). They also have a "large" which is the same 26" width, but longer (7'1")
Also comes in colors:
Times are GMT -7.   It's 01:17 AM.
