Old 02-27-2013, 09:59 AM   #1
KEELAYMONSTER OP
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 162
....Yet another suspension question
I have searched and cant seem to find any recomendations for fork springs for my weight and riding style. I am about 165lbs with gear, 5'7" on a '06 950A. I ride very aggressively on gnarly trails and single track. The only reason I slow down for whoops and big jumps is I am tired of hearing the front forks bottom out. I currently have the forks set to the sport setting + 2 turns preload and + 5 clicks comp (from sport setting).
I planned on going with a thicker fork oil and a stiffer spring. I have stock springs right now.
Any idea on spring rate???
Kyle Montagne #141K
KEELAYMONSTER is offline   Reply With Quote
Old 02-27-2013, 10:03 AM   #2
Qwik
Adrenaline Addict
Oddometer: 6,532
Talk to Trailtricks or super plush
Speed bumps never seem to make me go any faster
Qwik is online now   Reply With Quote
Old 02-27-2013, 10:33 AM   #3
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,775
Trailtricks closed some time ago.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 02-27-2013, 11:23 AM   #4
mousitsas
mousitsas's Avatar
Oddometer: 2,728
Ι think thicker oil will screw up your fast compression dampening.
Old 02-27-2013, 12:00 PM   #5
Hootowl
Oddometer: 1,254
Wouldn't the first thing to do is measure sag F&R?
Keep it Wild, Keep it Free
'07 990A
'12 Super Tenere
Hootowl is offline   Reply With Quote
Old 02-27-2013, 01:05 PM   #6
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
.....I guess. Ill do that and report back.
Good to know on the thicker oil. Thanks.
Kyle Montagne #141K
Old 02-27-2013, 02:59 PM   #7
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,424
I had Konflict Motorsports revalve and spring my 950 after going over the bars last year.
I cant tell you what a difference it made. Alex set my bike up really nice.
If I remember right he used .65 springs
I ride it like a dirt bike and could not be happier.
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 02-27-2013, 07:49 PM   #8
Lurkerlou
Lurkerlou's Avatar
Oddometer: 231
I'd like to put in a huge plug for Riders Edge Suspension here in BC.
He knows suspension , he knows 9xx's and in one way shape or another he has either done or supplied the valving or springs for every bike in my garage.
I just got to test out his handy work on my 990 a few weeks ago ( along with another buddy on his 990 who also had his done) and as always it was the best money spent.
Lurkerlou is offline   Reply With Quote
Old 02-28-2013, 05:24 PM   #9
DuctTape
Oddometer: 351
When you start looking at suspension upgrades you really need to include not just your weight but also your weight in all your gear including any gear like loaded tank bags, etc.
For example, I weigh 185 but after I put on all my gear and add my hydro pak and tank bag I'm now over 225 LBS.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 02-28-2013, 06:28 PM   #10
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
... I did. I'm trying to get a good setting for aggressive off road. Not touring.
At the very most I would say 175 with gear and what not. I'm a little dude man!!!
Kyle Montagne #141K
Old 02-28-2013, 09:10 PM   #11
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
Sag
ok. Race sag for front is 70mm. Thats with the preload at 9 turns.
Rear sag is 44mm with 6 turns preload. I have stock springs front and back. The rear hops around on washboard stuff. The front bottoms pretty easily if a small jump has a flat landing. At some point Ill send my suspension out to SPS for treatment For now I have budget constraints that limit me to just springs. Im just really tired of hearing CLUNK!
Kyle Montagne #141K
Old 02-28-2013, 10:31 PM   #12
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
racetech.com has a decent spring calculator. I have used it several times to get me in the zone without a bunch of messing around with different springs.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 02-28-2013, 10:37 PM   #13
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,047
Be nice if we could get you to try out my bike sometime, I'm nearby. . . and a titch lighter than you, maybe 160 with gear.
I had to change the rear spring, 130 seems much better. For the front, I went .56, I still run the preload all the way in- not necessarily a bad thing, but I think you could probably go .58 or .60 without any problem. I think valving on the fork makes a huge difference, too, but like you say, switching to something heavier (like synthetic ATF) would be a good start.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 03-01-2013, 08:35 AM   #14
crofrog
Oddometer: 1,455
Not sure what springs to recommend for you, but also increase your fork oil level. I'm running 90mm of space right now and am considering going higher.
crofrog is offline   Reply With Quote
Old 03-01-2013, 10:44 AM   #15
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 162
Thumb
Good to know. Thanks. We should ride sometime. I just moved to Pleasanton so I am even closer now.
I just ordered .64's from KTM Twins. I figured I would rather too stiff to avoid bottoming out.
Ill definitely be changing the fluid. ATF seems to be what a lot of people are using.
Does a higher fork oil level increase bottoming resistance?
Thanks everyone for all the replies.
Kyle Montagne #141K
Times are GMT -7.   It's 01:55 PM.
