Old 03-01-2013, 10:22 AM   #16
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,132
Originally Posted by KEELAYMONSTER View Post
Good to know. Thanks. We should ride sometime. I just moved to Pleasanton so I am even closer now.
I just ordered .64's from KTM Twins. I figured I would rather too stiff to avoid bottoming out.
Ill definitely be changing the fluid. ATF seems to be what a lot of people are using.
Does a higher fork oil level increase bottoming resistance?
Thanks everyone for all the replies.
I'm probably in the minority, but I think the rider is a less significant variable in determining spring rate with the 9X0's. You might be smaller than the average 9X0 rider, but the bike is still big and heavy. With less travel on the standard Adventure you have less cushion to absorb impacts too. You need that suspension to stay up in the stroke and the .64's will probably do well for you with less preload than your factory springs.
You will get a lot of opinions on fork oil and fork oil vs. ATF. You can compare viscosities and other properties on the chart toward the bottom of this page.
Yardstick is online now   Reply With Quote
Old 03-01-2013, 11:17 AM   #17
KEELAYMONSTER OP
BRRAAAAPPP!!!
KEELAYMONSTER's Avatar
Oddometer: 184
That was an interesting read. Im book marking that link for sure!
Still debating on fork oil viscosity and whether or not to go with ATF. Im still thinking heavier than the stock weight though.
Kyle Montagne #141K
KEELAYMONSTER is online now   Reply With Quote
Old 03-01-2013, 11:20 AM   #18
crofrog
Oddometer: 1,455
With cartridge forks the oil viscosity has less effect on high-speed compression/rebound versus low speed compression/rebound.
So that's something to keep in mind that you can create a bit of an imbalance.
crofrog is offline   Reply With Quote
Old 03-07-2013, 12:24 PM   #19
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 184
OK. Got the .64's installed Replaced the for oil with Maxima 5wt fork oil at 90mm level. I have 0 turns of preload, 15 turns rebound and 13 turns compression. Basically just put the dampning half way between the "standard" and "sport" setup. Unrelated I also pulled the steering stem apart, cleaned and re greased it while the forks were off.
First impressions are good. A LOT less dive under hard braking. I have yet to do some hard core offroad with it but it definitely seems better.
I'll keep everyone posted........now, to go find some sweet jumps to launch off of
Kyle Montagne #141K
Old 08-20-2013, 01:38 PM   #20
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 184
Long Term opinion...
These .64 are perfect. The only adjustments I've made are to reduce preload. My adjuster was already as far out as possible so I removed the spacer on top of the spring. That got it just right. I have riden some trails several times now and its an enormous difference. I no longer have to slow down for rain bars to avoid bottoming out I also commute 30 miles one way, every day. It hasnt lost any comfort however you do "feel" the road a bit more.
This was probably one of the best things I've done to this beast
Kyle Montagne #141K
Old 08-20-2013, 03:04 PM   #21
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,412
That's a crazy-heavy spring for your weight. 56x13.0 was a good call...
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 08-21-2013, 07:44 AM   #22
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 184
Think so?
Im not having any issues with the .64's. It still corners like a champ and is much more capable offroad.
I do have stock shim stacks and what not. Maybe the extra heavy spring is making up for that? I dont know really. Im no suspension guru
Kyle Montagne #141K
Old 08-21-2013, 10:23 AM   #23
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 864
.64 is far from a heavy spring for the front end on a 990. What do you weigh fully geared up?
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 08-22-2013, 12:15 AM   #24
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,847
At the very most I would say 175 with gear and what not. I'm a little dude man!!! ""
Copied from the 1st page - about 1/2 way down
Pete
Turtleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 08-22-2013, 07:40 AM   #25
KEELAYMONSTER OP
BRRAAAAPPP!!!
Oddometer: 184
What he said...
Kyle Montagne #141K
Times are GMT -7.   It's 06:53 AM.
