Old 02-28-2013, 06:20 AM   #1
Bullamakanka OP
Oddometer: 24
Indicator/turn signal help - KLX 450R
Fitted a set of LED indicators to my 2008 KLX450R. Also fitted a Kawasaki LED flasher relay as the led's were not drawing enough current to work.
Now the rear LED indicators work fine however the front indicator just lights up and doesn't flash. Does the same left or right.
Worked fine when original indicators were fitted before the were forcibly removed
Searched online but not much luck so far.
Any ideas?
Bullamakanka is offline   Reply With Quote
Old 02-28-2013, 06:01 PM   #2
Bullamakanka OP
Oddometer: 24
Anyone?
Old 02-28-2013, 06:30 PM   #3
YAHBO
Grip and rip since 1983
YAHBO's Avatar
Oddometer: 802
Do they begin to flash when you rev the motor?
If so, ride faster.
I'm an asshole and I approve this message.
YAHBO is offline   Reply With Quote
Old 02-28-2013, 06:36 PM   #4
Bullamakanka OP
Oddometer: 24
makes no difference
Old 02-28-2013, 06:45 PM   #5
CSF
CSF's Avatar
Oddometer: 164
Do you have LED resistors on the wire to the blinkers? Like these:
http://www.ebay.com/itm/2X-6ohm-50W-...d14999&vxp=mtr
Are all four blinkers LEDs?
CSF is offline   Reply With Quote
Old 02-28-2013, 06:46 PM   #6
Bullamakanka OP
Oddometer: 24
Originally Posted by CSF View Post
Are they LEDs?
LED's and also have fitted a LED flasher relay for Kawasaki bikes.
Old 02-28-2013, 06:50 PM   #7
CSF
CSF's Avatar
Oddometer: 164
what about resistors?
Old 02-28-2013, 06:54 PM   #8
Bullamakanka OP
Oddometer: 24
Apparently shouldn't need resistors with the LED flasher relay fitted. May have to just rewire the front on each side direct to the rear and see if that changes. Rear flash nicley while the front glows. Wiring diagrams in the manual doesn't show indicators existing at all from what I can see.
May have to visit an auto electrician I'm thinking.
Old 02-28-2013, 08:20 PM   #9
Beezer
Oddometer: 5,734
no resistor needed. wire the front to the same place as the rear indicator if it isn't that way already
Beezer is offline   Reply With Quote
Old 02-28-2013, 08:29 PM   #10
Bullamakanka OP
Oddometer: 24
Thanks mate, that's the plan now
Times are GMT -7.   It's 04:42 PM.
