Old 02-28-2013, 08:40 PM   #1
kellymac530 OP
motorcycle addict
kellymac530's Avatar
Oddometer: 926
Rox risers?
Has anyone ever used the ROX risers facing in a rearward direction?
My front frame is all welded and the bike is partly assembled and on the wheel. I am fitting a tank and playing with seats and I keep getting frustrated with how high and far forward the bars are.
I realize that rolling the risers 90* or so will affect steering a bit in the way the bars arch to turn, but i do not see any other option other than custom fabing up a new triple tree or at least a new bar clamp system on a billet clamp.
{sorry if you are not aware of what bike this is...I need to get a thread started with pics...96 R1100RT with a KYB fork conversion and 21" front wheel}
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 03-01-2013, 08:49 PM   #2
kellymac530 OP
motorcycle addict
Oddometer: 926
I must have forgotten to shower today...
Old 03-02-2013, 05:06 PM   #3
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 1,459
I am not entirely clear as to what you are asking.
AFAIK there is no reverse. Yes you can pull them back towards you with no ill effect (as long as there is clearance on the tank), and in fact this is what some (shorter) riders use them for.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 03-02-2013, 07:07 PM   #4
kellymac530 OP
motorcycle addict
Oddometer: 926
Thanks, That is what I was asking. I have only seen them mounted as risers in an up ward angle, or maybe slightly rearward angled.
I need to pull them back as far as possible and not raise the bars, even lower the bars.
I may have not worded it clearly. Sorry.
I just wanted to make sure there was not something in the instructions or directions that they could not be used past a certain angle rearward or forward maybe because of slippage or cracking or something.
Old 03-15-2013, 07:36 PM   #5
AtLarge
AtLarge's Avatar
Oddometer: 115
Angle 'em any way you want.
1973 CL70-K3
1983 KZ750-K1
2008 GSX1300-BKK8 #1120
Cardo Scala rider G4 PowerSet
AtLarge is offline   Reply With Quote
Old 03-16-2013, 11:21 AM   #6
kellymac530 OP
motorcycle addict
Oddometer: 926
I should have updated. I did buy a pair online and fit them pulled all the way back and it fixed my handle bar fit issue.
Build thread and pics to come
Times are GMT -7.   It's 09:40 PM.
