Old 03-27-2013, 08:25 AM   #31
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,454
So silly me went to the store to get one of these, thinking they had the built in slime injector thing.
My Flex came with a compressor that does this, and it works great.
Oh well.
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 03-27-2013, 08:38 AM   #32
8lives
Dharma Bum
8lives's Avatar
Oddometer: 1,979
I have a pump I gutted outta 1 of those battery jumper things,probably similar to the slime pump it works good used it the other day,but I always have a small hand pump and a regular guage with me also.
What would you do if you weren't afraid?
Perimeters suck!
I used to do drugs,I still do drugs,but I used to too!Mitch Hedburg
8lives is offline   Reply With Quote
Old 03-27-2013, 04:49 PM   #33
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 407
Anyone has pics of the AIRMAN stripped to the bare pump?
I had two generic pumps stripped and they lasted for a while and would not mind tweaking another one but rather do it with a good base unit. It is hard to tell the quality of the pump peeking though the plastics.
I wander what is inside the AIRMAN.
Pre thanks,
Eduardo
XR650R
KTM300
Simplicity is the ultimate sophistication.
EduardoMas is offline   Reply With Quote
Old 03-27-2013, 05:08 PM   #34
mac10
Oddometer: 68
I have a couple.I have a small slime version for backup. I especially like the airman, but my favourite is a bigger one gutted out of its housing. I hang it off the rack or the bars when in use so I don't have to handle it. It gets quite hot.
Rotating through two small pumps means they don't overheat and need a cool down between cycles. Saves time.Keeping them out of the dirt makes them last.
mac10 is offline   Reply With Quote
Old 03-28-2013, 01:46 PM   #35
acejones
acejones's Avatar
Oddometer: 5,159
Pre thanks,
Inside the AIRMAN is air waiting to be let out
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 03-28-2013, 10:29 PM   #36
MiteyF
MiteyF's Avatar
Oddometer: 1,990
I bought one and bent up an aluminum housing for it. Fits perfectly under the seat of my Wee
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 03-31-2013, 09:26 PM   #37
thorinoakenshield
ya mo be there
thorinoakenshield's Avatar
Oddometer: 448
Looks great!
You should make more and sell it for a huge markup ...oh, wait...somebody's already done that....
But srsly, I think I'll do that for my slime pump. I have a bunch of thin computer cases I could use.
Thx for the idea!
thorinoakenshield is offline   Reply With Quote
Old 04-01-2013, 11:10 AM   #38
racer1735
Oddometer: 358
I recently purchased one of the Slime pumps. It plugs into the SAE connector on my Powerlet outlet. Decided to test everything out, so deflated one of my tires (street bike) down to about 32 psi, then turned on the mini-compressor. Waited 2 minutes and turned it off, checked my tire pressure and it was up to 52 psi! So the little thing can crank out the air pretty rapidly.
Just doing this experiment didn't cause the unit to get anything more than simply 'warm' to the touch. The brass outlet nozzle was extremely hot, but the unit itself...at least the case...wasn't an issue.
racer1735 is offline   Reply With Quote
Old 04-01-2013, 01:54 PM   #39
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,527
Did an actual rescue with mine on Saturday
Laconic is offline   Reply With Quote
Old 04-19-2013, 06:43 AM   #40
seniorasi OP
Oddometer: 816
Originally Posted by Laconic View Post
More pics?
seniorasi is offline   Reply With Quote
Old 04-19-2013, 08:34 AM   #41
8lives
Dharma Bum
8lives's Avatar
Oddometer: 1,979
Ouch that's a big 1,a plug and tiny compressor probably made quick work of that,onward to your destination!
Perimeters suck!
Old 04-20-2013, 09:22 PM   #42
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,527
Originally Posted by seniorasi View Post
More pics?
See post # 493;
http://advrider.com/forums/showthrea...803348&page=33
Old 04-20-2013, 09:41 PM   #43
seniorasi OP
Oddometer: 816
Awesome thread and thanks for sharing. How many strips of plug were required for the hole in the tire? It looked way bigger than the averade screw.
Old 04-20-2013, 10:36 PM   #44
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,527
It just took one plug; the screw was long but only 1/4" OD.
Old 04-21-2013, 10:39 AM   #45
seniorasi OP
Oddometer: 816
Glad to hear only one took care of it. Never had a flat on a tubeless tire so just wondering what to expect if the inevitable is encountered.
Times are GMT -7.   It's 01:20 PM.
