Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 03-01-2013, 10:31 AM   #1
svs OP
All Hands on Deck!
svs's Avatar
Oddometer: 24,877
Rebuilding my VW Type One 1600cc motor
I'm going to rebuild my VW Air cooled Type 1 engine. Currently it has single port heads and is running with a 30-PICT carburetor. The vin on the motor starts with AH so it's dual relief 1972 case and should be a good to use if it all checks out at the machine shop. RIMCO is in my area and they know the VW motor better than about anyone and they are the machine shop I plan on using for parts inspection and I'm leaning towards them assembling the long block when I get the parts sourced and together.
Around $2500 is my budget... Used parts, New parts, keep the heads, use DP heads, single carb, dual carbs, turn key motor.....??
I'm entertaining thoughts and opinions. Not looking for HIGH horsepower, but strong, reliable and semi-good gas mileage. Old motor revved to 4k and I want a more usable power band.. at least rev to 5k with power would be fine.
Swing Axel, stock drum brakes and it's a BAJA BUG... low end torque and gas mileage work great when off road... Pleasure vehicle not a race vehicle.
Parts, thoughts, crass humor... what ya got?
If a physical fact can produce a psychological state, a psychological state can produce a physical fact... The whole of creation is asleep within the deep of man and is awakened to objective existence by his subconscious assumptions.
svs is offline   Reply With Quote
Old 03-01-2013, 10:38 AM   #2
Heyload
Remastered Classic
Heyload's Avatar
Oddometer: 8,383
I'm pretty sure something about a "TDI" will surface soon enough...
"Would you care for some left-over bacon?"...said no man, ever.
When life gives you melons, you might be dyslexic.
Heyload is offline   Reply With Quote
Old 03-01-2013, 10:50 AM   #3
d mc gee
d mc gee's Avatar
Oddometer: 803
Definitely go with DP heads. Theres lots of info out there on which ones are good and which are not. Hell there was a two part artical a couple years ago in Hot VW's that was a good read. Have you talked your plans/needs over with RIMCO? they may have some pretty good ideas.
If it wasn't for my graceful wife, my dumbass would be banned already
Doug Mc Gee
01 1150 GS
84 R100RS
74 XL350
d mc gee is offline   Reply With Quote
Old 03-01-2013, 10:54 AM   #4
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,427
This is probably a little tail happy though.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 03-01-2013, 11:06 AM   #5
bobfab
bobfab's Avatar
Oddometer: 1,425
Im in, i love an old aircooled!
CRF250L | KTM200SX
bobfab is online now   Reply With Quote
Old 03-01-2013, 11:19 AM   #6
svs OP
All Hands on Deck!
svs's Avatar
Oddometer: 24,877
The red one is nice... A Factory convertible like mine...Not a CHOP.
I have spoke with RIMCO and they want me to tell them what I want.. So many choices most of which are dictated by budget...as with most things in life.
Most likely use the stock crank and rods, which means 1776, 1835 or 1915.. Will keep the compression low so I can run 87 octane. Had a friend who's an off-roader and fabricator said keep the single ports, 30-PICT and go to 1915cc's with the piston and cylinders...run a 110 long duration cam. Torque monster and real good gas mileage...
Not sure, most everyone else says DP's and that means new carburation..
Old 03-01-2013, 11:35 AM   #7
FPGT72
Oddometer: 5,955
This one is a 1776 and has plenty of power, I am doing a 1300cc bug right now.
I understand the rail is quite a bit lighter, but after the snow melts it is going to get driven to work from time to time....quite often I think.
[FONT='Arial','sans-serif']Calling an illegal alien an 'undocumented immigrant'
is like calling a drug dealer an 'unlicensed pharmacist
[/FONT]
FPGT72 is offline   Reply With Quote
Old 03-01-2013, 11:48 AM   #8
Chuck Pryce
Oddometer: 244
The sanba,is a good site for VW info.
Chuck Pryce is offline   Reply With Quote
Old 03-01-2013, 12:11 PM   #9
vtwin
vtwin's Avatar
Oddometer: 7,427
That VW was in Laguna Beach a few years ago, so not too far from you. If on a budget, just a light going over would probably give you the most bang for the buck. I don't know anything about bugs though. Closest I ever came to owning one was when I bought a Corvair. Try Bugformance.
http://bugformance.reachlocal.com/?s...r_id=182866790
Monroe.
unknown
Old 03-01-2013, 12:13 PM   #10
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,838
Upgrade to 2.3L Type4, turbo, and never look back.. I use Adiran at Headflow Masters for my Type4 rebuild... He was reasonable.. I wanted bigger valves (42x36), and in hindsight, I should've ordered different cam..
Learn to ride. Ride to learn.
a1fa is online now   Reply With Quote
Old 03-01-2013, 01:46 PM   #11
d mc gee
d mc gee's Avatar
Oddometer: 803
Keeping the SP heads may be best for you. Especially if you can save or re purpose your funds in other areas of the engine. You were happy with them before? You will most likely be happier with them freshened up, and the rest of the motor upgraded.
Doug Mc Gee
01 1150 GS
84 R100RS
74 XL350
Old 03-04-2013, 09:23 AM   #12
svs OP
All Hands on Deck!
svs's Avatar
Oddometer: 24,877
Pulled the heads and cylinders off...
Old 03-04-2013, 12:49 PM   #13
Toadady
Push'n parts
Toadady's Avatar
Oddometer: 3,968
at first i thought you were wierd for leaving it bolted up to the trans, then i realised you are using it for a motor stand
Get to work, millions on welfare are depending on you
Toadady is online now   Reply With Quote
Old 03-04-2013, 07:03 PM   #14
Speedo66
Transient
Oddometer: 6,778
Always amazed they don't use head gaskets.
Oh I used to be disgusted, but now I try to be amused-E.Costello
'01 Kawasaki W650, '05 Yamaha XT225
Speedo66 is online now   Reply With Quote
Old 03-05-2013, 02:51 AM   #15
Maccoul
Bam Bam
Oddometer: 102
I would look at building a 85.5x76 stroker motor. No need to fly-cut case and heads but you will need to clearance the case. Single port heads will limit your rpm but on a stroker its all about grunt and gas milage. I will be doing this to my manx clone when the time comes.
Maccoul is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 06:22 PM.
