Old 03-02-2013, 07:31 AM   #1
WIsixfitty OP
ceiling unlimited
Oddometer: 2,251
Question fabricators and builders I need big HD bar clamps
I need some big heavy duty bar clamps for work to pull 1.25" thick steel housing plates together for the mfg of wind turbine gen housings.
Not the el-cheapo kind that thread on to 3/4 pipe.
I've searched but just keep coming up with the same clamps.
Anything bigger that would thread on 1.5 to 2.0 pipe would be ideal.
Halp!
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 03-02-2013, 10:17 AM   #2
Strong Bad
n00balicious
Strong Bad's Avatar
Oddometer: 4,256
Inch and a quarter plate may require some sort of hydraulic ram type of clamp to get it to safely move
"I couldn't wait for success, so I went ahead without it."
Strong Bad is online now   Reply With Quote
Old 03-02-2013, 10:28 AM   #3
WIsixfitty OP
ceiling unlimited
Oddometer: 2,251
The plates are just tacked in. It's for tweaking for some warpage from cutting and squaring up.
We get away with the cheap ones now it's just in the shop setting they don't last long.
I did find some of these just this morning.
Carver Bar-Style Clamps
http://www.destaco.com/bar-style.html
up to 6000lbs of pull.
Old 03-02-2013, 10:58 AM   #4
jasonmt
Oddometer: 544
Bessey Clamps, 8500#'s and down clamping force.
http://www.besseytools.com/en/produc...01f07600030023
8500HPC-14:
For comparison the left clamp is a 12" S4800 (4800# Clamp), the right clamp is an 8" S2400 (2400# Clamp) on a Toyota truck frame rebuild:
Otherwise build something (1" B7 studs,2H HH Nuts, 1" Plate):
jasonmt is offline   Reply With Quote
Old 03-02-2013, 11:41 AM   #5
WIsixfitty OP
ceiling unlimited
Oddometer: 2,251
I've got some Bessy's. Good shtuff.
Except we need 3 to 5 foot lengths.
Old 03-02-2013, 12:07 PM   #6
jasonmt
Oddometer: 544
Can you sketch what you are trying to do? Strongbacks / Dogs / Cleats will not work easier than clamps?
Old 03-02-2013, 01:35 PM   #7
panhead_dan
motorcycle addict
Oddometer: 852
dogs and wedges
Think
Love
Live
panhead_dan is online now   Reply With Quote
Old 03-02-2013, 02:04 PM   #8
fxstbiluigi
crash test dummy
fxstbiluigi's Avatar
Oddometer: 12,096
+1
if there is much pressure involved clamps won't survive and a porta-power
can get quite cumbersom and messy.
Cut some wedges from 1" or heavier plate and the dogs can be cut from 3/8" or 1/2" plate.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin.
"Politicians are always interested in people.
Not that this is always a virtue.
Fleas are interested in dogs." -P.J.O'Rourke
fxstbiluigi is online now   Reply With Quote
Old 03-03-2013, 08:45 AM   #9
WIsixfitty OP
ceiling unlimited
Oddometer: 2,251
I would post a pic but I'm not sure I can show this publicly.
dogs and wedges would work but they take time. Where as a bar clamp is pretty darn quick.
agreed porta power is just clumsy.
Time is crucial. We have to do one of these housings a day. About 5 hours for prep and tack and 20 to weld.
Old 03-03-2013, 01:39 PM   #10
Beezer
Oddometer: 5,796
you don't say the configuration of the gussets or if the weld plates are all the same, but how about a plate with holes drilled so you can use 2 pipe clamps together, then they can't spread. maybe 2 plates with holes. or instead of screw clamps 2 plates, pipes & a hydraulic jack
Beezer is offline   Reply With Quote
Old 03-03-2013, 08:13 PM   #11
fxstbiluigi
crash test dummy
Oddometer: 12,096
Sounds to me like it's time to educate those that think everything in the welding world happens without complications, and that it dosen't always happen in a problem free manner and sometimes steel can be quite uncooperative and that the DAMN thing will be welded when we get a good fit-up and get done welding it. AND if they don't like that they should have hired someone with some welding experience to bid that part of the job.
Old 03-04-2013, 01:49 PM   #12
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,456
A good t-bar sash clamp would be a good measure stronger than those 3/4 pipe ones. If you need stronger again the Carver clamps would be the tool.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is online now   Reply With Quote
Old 03-04-2013, 02:27 PM   #13
WIsixfitty OP
ceiling unlimited
Oddometer: 2,251
your preaching to the chior.
I'm the lead just trying to keep both sides happy.
Old 03-04-2013, 03:11 PM   #14
gsweave
Yinz, blinkers are on.
Oddometer: 11,509
Hell use a chain fall come along to draw it to place, and these Besseys to hold it for tack up.
Bessey B-HS8 4-1/8" x 8-1/4" Heavy Service C-Clamp
PRICE:
$221.97
This clamp has the clamping force up to 40,000 lb and drop forged, heat treated frames for strength
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 03-04-2013 at 03:26 PM
gsweave is offline   Reply With Quote
Old 03-04-2013, 04:19 PM   #15
fxstbiluigi
crash test dummy
Oddometer: 12,096
Once everything is fit up and tacked what type and size rod are you using to make the weld? Fillet or ?
Times are GMT -7.   It's 04:07 PM.
