Old 03-02-2013, 09:11 AM   #1
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
2000 XR650R Build/Rebuild/Farkles
I finally got the ambition to tear apart my bike and prep it for year, and years to come.
Stock seller photo
Backstory: Got the bike in 2009 with unknown knowledge of miles, wear and tear, or anything. The bike did have the uncorking done to it though. The first summer i took it to Colorado for my 6 week internship and had a blast up there, remember, i'm from eastern South Dakota where there are only two types of roads, gravel and paved. Later that year (2009) the engine started getting louder and louder, ticking sound up top. I read this is normal of the bike and ignored it. I took very good care of the bike maintenance wise, but i think the bike was wearing out. Winter 2009/2010 took the head cover off and discovered a disaster, rockers and stock cam were destroyed.
Rockers Toast
So in went the Hotcams Stage 1 along with all new parts in the head cover.
Keep in mind this is winter now and in Iowa (i moved for a few years) so after Install i managed to break in the cam properly in an open field behind our apartment.
Spring came and got to riding more and the bike never performed properly. like jetting was way off or something. i struggled with it all summer long and barely rode the damn thing. Well i thought for sure a mikuni TM40 would remedy this, So i bought one up and stuck that baby in there and no go. dang. but it did run better! so i rode it, it would die at stoplights and stumble, but i was riding it. Only got to ride it for about a month in 2010.
2011, Moved back to South Dakota. I rode it to work for quite a while in 2011, but it was always raining, so not that much really.
2012, we bought a house so i got a three stall garage to work on all my projects! a guy at work mentioned that it sounds like a timing issue, well after it took two tries to get the head cover to seal properly, i wasn't too keen on taking it off again, but i did, OH what do you know, when i installed the cam somehow it had slipped a tooth and the timing was off!! the rest of 2012 was good, the bike burned some oil, but not too bad. then it got worse, i have a 18 mile commute total everyday, and i rode it everyday after i fixed the timing for about a month, then it started drinking more oil, about a quart in a weeks time. that's a quart every 90 miles roughly. not good, but i took it to the western side of the state for a weekend with my cousin and had a blast.
And Now:
Wednesday i started tearing down bike top end. I wanted to tear it all down so i could figure out what i need and make one large parts order instead of several and paying more for shipping. I went out on a limb and got a standard bore standard compression Wiseco piston because it was on sale for $110 and i thought it was a steal. so i snagged it.
Here are some dis-assembly pictures thus far.
Bore is smooth and no signs of wear (i think standard bore piston will be just fine)
Intake ports
Exhaust ports (both look similar)
All cleaned up
Cleaned up good enough for now as new valves will be installed.
Intake Left Side
Intake Right Side
Exhaust Right side
Exhaust Left Side
Right Exhaust Valve
Left Exhaust Valve
Right Intake Valve
Left Intake Valve
This is all i have done so far. I anticipate this build to take several months because my wife and I are trying to get out of debt (only cars left) so we can start a family, so I only get and see $200 every two weeks, and I drive a Dodge Hemi, so half of that goes toward fuel every pay period.
I'll do my best to keep this all updated and i will have some questions as i progress along. i'll take some measurements this weekend of all the parts and post them later.
Any Tips/Suggestions/Comments are welcomed! Wish me Luck!!
2000 Honda XR650R (Sold) LINK
2014.5 Kawasaki KLR650 NE
mitchn06 screwed with this post 03-02-2013 at 09:25 AM
mitchn06 is offline   Reply With Quote
Old 03-04-2013, 10:19 AM   #2
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
any recommendations on where to send the head off to have the seats cut? i'm gonna call around to some shops here to get pricing, but just thought i'd ask. maybe a fellow adv guy does them? Thanks
Old 03-04-2013, 12:19 PM   #3
crypto666
Oddometer: 1,276
I sent mine to JR at XRSonly and he took care of everything. My head and jug were returned new and improved with my name engraved on them.
I had the head opened up, I think +3 on the intake and ex.
crypto666 is offline   Reply With Quote
Old 03-04-2013, 01:30 PM   #4
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
curious what this would cost, ballpark even. PM me if you care to.
Old 03-04-2013, 02:49 PM   #5
crypto666
Oddometer: 1,276
Oh lord, I don't remember. I would give them a call. Costs will vary depending on what you get, such as the bigger valves (probably not needed unless you are doing other things), port and polish, etc.
A ballpark I would guess at $500, because everything you do to a thumper motor is $500, and because I have been shopping around for prices on doing a CRF head. A good way to estimate it also is to price the parts (Valves, springs, etc) and double it.
I chose them because I know they have done this motor many many times before.
Old 03-04-2013, 03:24 PM   #6
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
i agree with this, a local shop here quoted me
$20 to clean the head
$40 to grind the seats
$40 to mill
i was astounded by the prices, and wasn't sure what the difference was between grinding and milling, but i'm guessing the mill takes out more material? not really sure, so i didn't ask.
but like you said, you trust a reputable source that has the experience with the particular head you are using.
Old 03-04-2013, 06:02 PM   #7
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
Valve/Head results are in:
looks like i will have to add some parts to my ever-growing list
Old 03-05-2013, 06:15 AM   #8
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
i think i was getting a bit tired last night while doing these measurements as i see that the valve guide ID magically shrunk from factory. it was a bit difficult with my caliper to get a good inside reading, so its wrong.
Old 03-05-2013, 11:00 AM   #9
crypto666
Oddometer: 1,276
The milling is the also called decking and its basically machining the contact point with the cylinder and makes sure its flat, not warped.
The grinding is the cutting of the valve seats.
Just know that if you decide on oversized valves, don't go too big so you leave room for another cutting.
Old 03-08-2013, 09:57 AM   #10
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
decided to take the piston out last night and found that the wrist pin and rod small end were slightly scored. I was wondering if this meant that i will need a new connecting rod, or if i can just run it(maybe run some 400 grit paper over it?). depending on how bad it really is. I could barely feel it with my fingers, but i certainly can see it. I'll post up some pictures tonight.
Old 03-08-2013, 10:52 AM   #11
crypto666
Oddometer: 1,276
The only way to fix that without some really expensive processes, is to replace it.
Make sure to find a rod with roller bearings on both ends. I used a Falicon, but there are some cheaper units out there. I had a local shop press the new one together along with the crank bearings. Cost like $40 for the labor.
Small end failure seems pretty common.
Edit: I am not sure if any rod has bearings on the small end. All I know is the cost of the falicon made me poop my pants, but I got it anyhow.
Old 03-08-2013, 03:22 PM   #12
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
here are the pics:
Old 03-08-2013, 07:37 PM   #13
XR650Gnar
Oddometer: 14
Im in the middle of pretty much the exact same build, well, similar parts, swapping everything into a new case after I s'ploded it last May.. Just sent my head, cylinder and crank out to XRs Only for a rocker face hard weld, valve job (new everything), and the crank pressed with the new rod. (didnt go falicon, though I feel I should have bit the bullet.) Im also doing a stage 1 hot cam. Curious what elevation you are at? Maybe we can compare notes on jetting with the new cam when we both get to that point.
Its looking like Ill be a couple weeks out at the moment, waiting on all new bearings and seals.
XR650Gnar is offline   Reply With Quote
Old 03-09-2013, 03:19 AM   #14
mitchn06 OP
mitchn06's Avatar
Oddometer: 547
Yep. Gonna have a pretty tight engine when it's all said and done. Did you go pro-x or oem the. All I can find so far for options is carillo, falicon, pro-x, and oem and the only one in my price range is the pro-x. The wife has this great idea to get out of debt and start a family, so I only have $100 to work with every two weeks. It sucks. Gonna take me 3 months to finish this damn bike.
Old 03-09-2013, 12:28 PM   #15
XR650Gnar
Oddometer: 14
I decided to go with the pro x mostly because with all the associated costs (hidden and otherwise) of a pretty much 100% complete rebuild $300 just for the rod is rough. I stayed with the stock bore and compression more for reliability than anything. I think a falicon is bling for this application but shifts more to mandatory when you go high compression, bigger bore, stage 2 cam etc.
Times are GMT -7.   It's 02:06 PM.
