Old 03-03-2013, 05:27 PM   #16
theloop
Oddometer: 458
Off topic, but the 650 v strom was on my short list for my next bike, but after reading over $200 for a fuel filter, and over $700 for a fuel pump, the 650 v strom might be moving more towards the bottom of my short list.
theloop is online now   Reply With Quote
Old 03-03-2013, 05:46 PM   #17
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
What's your list look like?
Old 03-03-2013, 05:47 PM   #18
Big Toe
Big Toe's Avatar
Oddometer: 219
Don't worry the V-Strom is about the most realible bike out there. I know many people with over 100,000 mi. with no problems.
Art in Peterborough
2014 Suzuki DL650
2008 KTM 250XCF-W Woods & Ice Bike
Big Toe is offline   Reply With Quote
Old 03-03-2013, 05:50 PM   #19
Jamie Z OP
Jamie Z's Avatar
Oddometer: 7,702
FWIW, my understanding is that the fuel pump itself has a very low rate of failure.
However, my reading shows that the integrated high-pressure fuel filter inside the pump assembly often gets clogged. Replacing the (expensive) filter, or bypassing it and using an external automotive filter solves the low-flow problem.
I should be able to fix it tomorrow for ~$50.
Jamie
I'm the Tent Space Guy Sign up to host fellow travelers here.
Budget Travel the Jamie Z Way
Jamie Z is online now   Reply With Quote
Old 03-03-2013, 06:24 PM   #20
Jamie Z OP
Jamie Z's Avatar
Oddometer: 7,702
You did read that I have over 116,000 miles on my bike right? Factory fuel pump. Factory fuel filter.
The problem is that the filter is not easily replaceable. There are instructions floating around the web on how to bypass the filter and replace it with an automotive inline type.
But I can understand your hesitance. I'm going to have trouble trusting this POS after letting me down this one time.
Jamie
Old 03-03-2013, 06:54 PM   #21
theloop
Oddometer: 458
The cb500x (w/ABS) was number one after I sat on one at the north american motorcycle show Number two was the 650 v strom, sat a little high, but that can be corrected, and it has better wind protection than the cb500x, and should be better if I ever have to jump on the freeway. Number three is the NT700v, but do not like the idea of side loading plastic bags. And number four is the NC700x, I will have to go take a second look, but sitting on the bike, something just felt off that I could not put my finger on (plus no ABS with the standard shift). I will be replacing a 2003 750 honda ace, I just want to get my feet back under me, and let my legs take some of the bumps in the road, other than my lower back.
Old 03-03-2013, 07:26 PM   #22
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
Can't go wrong with any of those. I'd price out a replacement fuel pump on one of the Hondas before I passed judgement. The Strom pump is not a typical point of failure, even in this thread it seems to me Jamie has some bad gas, not a bad pump.
Old 03-03-2013, 08:50 PM   #23
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,579
Just ride down to the burger joint and back, or what?
Jamie, you might try just pulling the tank, draining the fuel, and putting 1 good gallon of fuel in the tank to see if it goes. Water in the fuel sits on the bottom, where bikes pull from...
Flashmo is offline   Reply With Quote
Old 03-03-2013, 09:18 PM   #24
Jamie Z OP
Jamie Z's Avatar
Oddometer: 7,702
Well, even the fuel flow rate was well below spec, and the high-pressure filter is known to clog up.
Bad fuel or no, it's pretty clear that I need a new filter.
So... what do I do with the bad gas. Everyone says to drain it. Where?
Jamie
Old 03-03-2013, 09:21 PM   #25
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,785
Jamie
Set it on fire. Somewhere safe.
Hate gets you nowhere.
Old 03-03-2013, 09:40 PM   #26
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,579
You are correct, I just had that photo burned into my head. I would be changing the filter as well. Wish mine was a candidate for the bypass...
Old gas gets metered into a V-8, with fuel injection, so it does not care if it is not like new. Gas like your photo goes into a large bowl, set outside and allowed to evaporate. I wish the places that accepted hazardous wastes (like old paint) would take it.
Old 03-03-2013, 09:41 PM   #27
Jamie Z OP
Jamie Z's Avatar
Oddometer: 7,702
That'll be fun.
I live in an apartment complex.
I just filled it with five gallons of fresh gas... seems that most of that should be fine if I siphon it carefully.
Jamie
Old 03-03-2013, 11:09 PM   #28
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,504
That'll be fun.
Jamie
Get two 5 gallon buckets. Dump as much as you can of your tank into one of the buckets. Water settles to the bottom so you should be able to pour the good fuel off the top into the other bucket. Then pour the rest of your tank into the bucket the with water and pour as much of that into the other before the water starts to go over the the lip. You can put the good bucket back into the bike.
It will probably be hard starting at first because you've got the fuel lines filled with water. You could pull the fuel rail and drain it. (you might need to pull the throttle bodies to do that though, I can't remember)
Don't forget to drill the high pressure filter and do the external filter mod and you should be as good as new.
Old 03-04-2013, 06:34 PM   #29
theloop
Oddometer: 458
[QUOTE=Flashmo;20858657]Just ride down to the burger joint and back, or what?
Sometimes Ya got to leave work on friday and try to make it to the campgrounds where the good riding is before it gets to late, but always seem to set up camp in the dark, or have to jump on I-75 to get across the Big Mac.
Burger King, I'll build a fire and cook over it.
Getting ready to cross the Big Mac.
theloop screwed with this post 03-04-2013 at 06:42 PM
Old 03-04-2013, 06:50 PM   #30
theloop
Oddometer: 458
Jamie
Thanks Jamie, I didn't notice that you had that many miles on your bike, I could wind up with the v strom since it is sounding like the cb500x may be in short supply on early production.
Times are GMT -7.   It's 12:42 PM.
