Old 03-04-2013, 08:03 PM   #16
manic mechanic
manic mechanic's Avatar
Oddometer: 107
When the shop I work at bought a new box van to haul their 26ft trailer to races, I was tasked with insulating and wiring the box, and also dividing it into a sleeping section and work space. Used Styrofoam in the walls and overhead after installing the wiring and receptacles. Installed a 220V covered outlet to provide separate circuits for lights and convenience outlets. The box has a roof-mounted heater/AC unit. Both the truck box and trailer are supplied by one generator. The "living" space has fold-up bunks that double as seating, along with a TV, microwave, and VCR.
Prior to doing all of this the owner had a side door and folding steps mounted on the right side of the box, into the living area. There is also a pocket door between the two areas of the box.
'76 R90/6, '07 K1200GT
Rounder #6
MOA Ambassador, Biergarten co-chair
RA WI Regional Rep, rally security chair
manic mechanic is offline   Reply With Quote
Old 03-04-2013, 09:19 PM   #17
KLR04
Oddometer: 162
I've rented such trucks in the past and was wondering if there was a way to smooth out the suspension, the ones I drove had rock solid suspension, I really took a beating with the box empty. How's fuel consumption? I was also wondering if it was possible to remove the spacers between the frame and the box, no need for loading dock height, easier access, smaller frontal area?
KLR04 is offline   Reply With Quote
Old 03-04-2013, 10:17 PM   #18
dirtydeeds OP
I'm alive.
dirtydeeds's Avatar
Oddometer: 1,814
Send a message via Skype™ to dirtydeeds
I haven't driven it enough to know how much fuel it goes through. I was told they get around 17mpg when empty.
I imagine it could be smoothed out a bit with air suspension. That's not going to happen on this truck though.
I was under the truck today looking at the steel holding the box up. There's a lot of weld on there. I certainly don't need it as high as it is. I might get to it eventually. Not a priority yet.
dirtydeeds is offline   Reply With Quote
Old 03-04-2013, 11:21 PM   #19
KFhunter
Oddometer: 33
I wouldn't mind a quad cab 4x4 diesel
pretty rare though
KFhunter is offline   Reply With Quote
Old 03-05-2013, 07:35 AM   #20
dirtydeeds OP
I'm alive.
dirtydeeds's Avatar
Oddometer: 1,814
pretty rare though
I'm also keeping my eyes open for tire chains. They're required in winter, by law or common sense, on some roads in AB and BC.
Old 03-05-2013, 09:11 AM   #21
SchizzMan
del siglo XX
SchizzMan's Avatar
Oddometer: 5,809
Four air bags on the rear might get it done. Not cheap but necessary for an RV conversion.
'09 WR250R, '12 R1200GSA
"As long as there's a horizon and I can see it, then I want to know what's there, mentally, physically and visually" - rtwpaul
SchizzMan is offline   Reply With Quote
Old 03-05-2013, 11:01 AM   #22
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,139
I assume it's leaf suspension on the rear, why not just take out a couple of leaves? I'm no truck expert but it's just a stack of bent steel, remove a few and the stack gets weaker, suspension gets softer?
Nice conversion, the truck is bigger than my workshop so I'm mildly jealous.
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 03-05-2013, 12:21 PM   #23
dirtydeeds OP
I'm alive.
dirtydeeds's Avatar
Oddometer: 1,814
Absolutely correct. Not doing it though. I'm ok with it as is.
(Also, changing to more leafs, that aren't as thick changes ride quality.)
You and I have different meanings of the word "necessary". The next one might be bigger, on air. I want to see if I like the whole box van idea, first.
Old 03-05-2013, 12:43 PM   #24
SchizzMan
del siglo XX
SchizzMan's Avatar
Oddometer: 5,809
That may very well be. For a full RV conversion that sees a lot of miles I do consider it necessary. Unless the spring leaf suspension can be adequately lightened up all the expensive stuff you put in the box will take a beating over time. That costs money, too.
For a bare-bones toy box/sleeper it's probably not necessary. Maybe I'll find out one day. Meanwhile I'm enjoying y'all's projects.
Old 03-05-2013, 01:43 PM   #25
Dysco
caddis muncher
Dysco's Avatar
Oddometer: 14,755
How are you getting bikes into it? Ramp, liftgate?
Dysco is offline   Reply With Quote
Old 03-05-2013, 03:12 PM   #26
groop
So much to ponder
groop's Avatar
Oddometer: 2,551
Are you going to have to pull over for every weigh station with this thing?
Originally Posted by DR. Rock
once you leave the pavement, it's like entering a parallel universe... a wormhole in both space and time... sometimes you won't believe you're still in the United States, or in this century.
groop is offline   Reply With Quote
Old 03-05-2013, 03:49 PM   #27
GP640
GP640's Avatar
Oddometer: 2,944
Weigh stations
He's in Alberta so I'd bet no because he can probably plate it as a personal
vehicle/rv.
GP640 is offline   Reply With Quote
Old 03-05-2013, 08:04 PM   #28
dirtydeeds OP
I'm alive.
dirtydeeds's Avatar
Oddometer: 1,814
Right you are. All the scales I've seen here are for commercial vehicles. Most of the ones in the 'States that I've driven past, too. Between Red Deer and Phoenix I only remember one that didn't specify it was only for commercial vehicles. I'm told that I have to put "Not for hire" on the side of it for the DOT. I'll be in contact with them to see if there are any other rules/regs that need to be addressed.
I can put passenger vehicle insurance on it. Just did today as a matter of fact. There were a few questions to answer buf no problems. I can't call it an RV because it needs a bunch of stuff for that. It's costing me $36/month, as a second vehicle. Regular plate.
I took it out for its first real trip. Went to Lacombe to pick up a futon. :)
I think it may need a tie rod. Steering felt a bit loose. Hard to tell for sure as I had a pretty good cross wind and there was occasionally ice on the road.
Old 03-06-2013, 06:19 AM   #29
MotoChris521
MotoChris521's Avatar
Oddometer: 338
So , How do you get to the front of the box with bikes loaded sideways ?
dreaming of moist soil
MotoChris521 is offline   Reply With Quote
Old 03-06-2013, 04:49 PM   #30
dirtydeeds OP
I'm alive.
dirtydeeds's Avatar
Oddometer: 1,814
Hoping to find a door for the front. I don't want to have to roll up the door for access/egress.
Thread Tools
Times are GMT -7.   It's 05:31 AM.
