Old 03-03-2013, 05:44 PM   #1
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,510
I want to make my shiny thing shiny. Help?
My "new" house came with a hot tub. The POs didn't keep the "scale" from building up around the top where the water evaporated and left behind what I think is probably calcium scale.
I have tried a number of things (including vinegar and baking soda), CLR and scrubbing with a green pad and Bartender's Friend - the latter seemed to help a little, all the others seemed to have no effect.
I scrub and scrub and scrub, but at this rate it isn't doing much good. When the "scale" gets wet much of it fades and then when it dries it comes back (it isn't left over cleanser - just wetting it with pure water makes it fade). It is especially hard to clean where the tub surface is not smooth, which is where most of it is.
I had hoped CLR would just dissolve it, but it didn't seem to do anything.
Anything else I can try?
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 03-03-2013, 05:47 PM   #2
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,777
goof off
Learn to ride. Ride to learn.
a1fa is offline   Reply With Quote
Old 03-03-2013, 05:50 PM   #3
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,196
Vinegar works wonders, but you need to let it sit on there wet for quite a while.
My suggestion is to fill the tub to the brim/overflow, and dump in a few gallons of vinegar and leave it overnight. Next day, scrub the hell out of everything and drain it.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 03-03-2013, 05:56 PM   #4
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,510
Everything I have tried, including vinegar, I have left sit on some scale for over an hour - there are flat spots to try this on. Vinegar did nothing, CLR did nothing.
'09 Husaberg FE570
'99 Beta Alp
Old 03-03-2013, 06:00 PM   #5
LuciferMutt
Oddometer: 11,196
Good old fashioned Ajax/Borax? Still need to scrub the everliving shit out of that stuff, but it works pretty well.
Old 03-03-2013, 06:02 PM   #6
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,777
Goof off.. That shit removes everything!
Old 03-03-2013, 06:13 PM   #7
Rainier_Rider
Gone
Oddometer: 1,560
[MOD EDIT: DELETED SUGGESTION. IF YOU MIX AMMONIA WITH BLEACH YOU CREATE POISONOUS GAS.
Mixing bleach and ammonia is extremely dangerous, since toxic vapors will be produced. The primary toxic chemical formed by the reaction is chloramine vapor, with a potential for hydrazine formation. Here's a look at the chemical reactions involved in mixing bleach and ammonia, as well as some first aid advice if you accidentally become exposed to a bleach and ammonia mixture.
http://chemistry.about.com/od/toxicc...d-Ammonia.htm]
Delete account.
Jarvis screwed with this post 03-04-2013 at 09:14 AM
Rainier_Rider is offline   Reply With Quote
Old 03-03-2013, 06:31 PM   #8
Big Bird 928
Oddometer: 2,479
Originally Posted by Rainier_Rider View Post
I hear ammonia mixed with bleach works well.
Do not try this. For those of you who may not know that is a recepie for Chlorine gas, a cousin of Mustard gas. It can / will make you sick, and can kill you.
Big Bird 928 screwed with this post 03-03-2013 at 06:42 PM
Big Bird 928 is offline   Reply With Quote
Old 03-03-2013, 06:38 PM   #9
Rainier_Rider
Gone
Oddometer: 1,560
You can?
Originally Posted by Big Bird 928 View Post
Do not try this. For those of you who may not know that is a recepie for Chlorine gas, a cousin of Mustard gas. I can / will make you sick, and can kill you.
Delete account.
Old 03-03-2013, 06:43 PM   #10
Big Bird 928
Oddometer: 2,479
You can?
Yep, I can, you just have to look at my ugly mug. Thanks for pointing that out.
Old 03-03-2013, 07:14 PM   #11
koncha
Oddometer: 10,044
Have you tried scrubbing with melamine foam, aka Magic Eraser?
koncha is offline   Reply With Quote
Old 03-03-2013, 07:16 PM   #12
It'sNotTheBike
Oddometer: 704
************** DO NOT DO THE ABOVE !!!!!! *******************
The fumes which are created from the above mixture
can damage the lungs of someone who breathes it,
and can cause rapid loss of consciousness which may end
in death if the victim is not evacuated quickly from the source
of the gas.
It's not clear whether you knew this when you wrote your post
( in which case you are a sick individual who needs serious mental health
in-patient treatment, mandated by court order ) or if you are just an
uninformed idiot, but either way you should be more careful before you make stupid
recommendations that might result in serious harm or worse to someone
who might be unwise enough to take your incredibly bad advice.
It'sNotTheBike screwed with this post 03-03-2013 at 07:24 PM
It'sNotTheBike is offline   Reply With Quote
Old 03-03-2013, 07:18 PM   #13
SimpleSimon
Aspiring advrider
SimpleSimon's Avatar
Oddometer: 3,393
Originally Posted by it'snotthebike View Post
the fumes which are created from the above mixture
of the gas.
( in which case you are a sick f*ck ) or if you are just an uninformed idiot,
recommendations that might result in harm to someone.
+2
5f? Is that like riding down a 90 degree cliff face into a lake of fire? I thought 4f was bad. Abdelhub
"Assembled Spectator Scoring With Incriminating Photographic Evidence" or A.S.S.W.I.P.E. - Granparacer
SimpleSimon is offline   Reply With Quote
Old 03-03-2013, 07:34 PM   #14
Kamala
Kamala's Avatar
Oddometer: 12,659
The trick is to keep the vinegar in contact with the Lime scale for as long as possible. Soak tissue or paper towels with the (white) vinegar and drape them over the area. Cover the vinegar soaked paper with a plastic wrap so that the plastic extends beyond the paper and seals it to the surface and keeps it from drying out. Tape it in place if you have to. Let it sit for a day or 2 and its should come off on the paper or be easily scrubbed off afterwards. Agricultural Vinegar (if you an get it) will work better.
I survived the Great Folk Music Scare of the 1960s (when it almost caught on) !
Kamala is offline   Reply With Quote
Old 03-03-2013, 07:38 PM   #15
a1fa
Riding Nomad™
a1fa's Avatar
Oddometer: 13,777
Seriously, delete that post.
Thread Tools
Times are GMT -7.   It's 09:40 AM.
