Old 03-03-2013, 06:44 PM   #16
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Originally Posted by CodeMonkee View Post
My "new" house came with a hot tub. The POs didn't keep the "scale" from building up around the top where the water evaporated and left behind what I think is probably calcium scale.
You think it's "calcium" huh?
I am a conservative, not a Republican. There is a difference.
JamesG is offline   Reply With Quote
Old 03-03-2013, 07:25 PM   #17
JOKER650
JOKER650's Avatar
Oddometer: 1,586
Go to a boat shop and get some hull cleaner. Careful though....some of that stuff is pretty wicked on clothes and lungs.
Read and follow directions.
Life's short...ride far
Over 2000 plated dirt riders...Digg'n up the dirt every other day, all over BC
http://www.dualsportbc.com/
JOKER650 is offline   Reply With Quote
Old 03-03-2013, 07:40 PM   #18
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,318
Originally Posted by Rainier_Rider View Post
I hear ammonia mixed with bleach works well.
I know this is Jo Momma, but that's fucked up dude. Not everyone knows that this makes chlorine gas.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 03-03-2013, 07:56 PM   #19
Big Bird 928
Oddometer: 2,623
...Actually this is Fluff, not Jo Momma.
Big Bird 928 is offline   Reply With Quote
Old 03-03-2013, 08:04 PM   #20
green hell
yawning or snarling
green hell's Avatar
Oddometer: 19,959
we'd kind of let ours go for a bit, then had to pick up something from the local hot tub shop. dumped it in and let it go for a day or so. cleaned everything up quite nicely.
sadly, i don't remember what it was.
but i'm pretty sure if you call a dealer they can point you in the right direction.
it was not the normal baqua spa stuff, but a powder that comes in a large foil package.
lookin' for a place to happen;
makin' stops along the way - the tragically hip
needless dickery
green hell is offline   Reply With Quote
Old 03-04-2013, 04:48 AM   #21
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,589
Originally Posted by koncha View Post
Have you tried scrubbing with melamine foam, aka Magic Eraser?
yes - totally ineffective
'09 Husaberg FE570
'99 Beta Alp
'04 Ducati MTS - sold
Not all who wander are lost
CodeMonkee is offline   Reply With Quote
Old 03-04-2013, 04:49 AM   #22
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,589
Originally Posted by Big Bird 928 View Post
Do not try this. For those of you who may not know that is a recepie for Chlorine gas, a cousin of Mustard gas. It can / will make you sick, and can kill you.
Don't worry - I already knew not to do this.
'09 Husaberg FE570
'99 Beta Alp
Old 03-04-2013, 04:52 AM   #23
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,589
There was some gel coating polish the POs left behind, but it was totally ineffective also. Maybe a boat shop has something more effective.
'09 Husaberg FE570
'99 Beta Alp
Old 03-04-2013, 04:53 AM   #24
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,589
Not sure it is calcium, but it is white not brown.
'09 Husaberg FE570
'99 Beta Alp
Old 03-04-2013, 05:04 AM   #25
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,589
I go by a spa shop every day on my way home, maybe i will stop in there.
thanks everybody.
the bartender's friend has oxacilic acid and it seems to be the most effective of what i have tried (i also tried various cleansing powders including ajax and clorox) but it doesn't make much of a dent and i will be scrubbing for months using it if that is all i try.
As for Goof Off - I looked at the active ingredient and I think it might damage the tub which probably acrylic.
there are three reasons there is "scale" in the hot tub:
1) they left it on all the time year round
2) they had no kind of water conditioner for the house water and the water comes from a well. they did use a little chlorine for the tub and it has both an oxygen generator and a UV light for purifying the water. I intend to get a water conditioner eventually - the water isn't bad but this shows me that it would benefit from a conditioner.
3) they had a small leak in the piping so the water level would go down over time.
All that with the tub cover on it caused a the level to be about 6 inches or more down from the top and most of the "scale" is at that level. Before I started scrubbing it was pretty bad even when the water covered it - not something i would want to get into much less invite someone else to join me.
But spring is coming and I wouldn't mind using it once it gets to the point where i don't have to sit in the rain to use it. Eventually I want to cover that deck so I can use it in the winter, but one thing at a time.
'09 Husaberg FE570
'99 Beta Alp
CodeMonkee screwed with this post 03-04-2013 at 05:40 AM
Old 03-04-2013, 06:26 AM   #26
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,084
I have used CLR successfully in the past when nothing else worked. Put it in a spray bottle & give it a good coating every 10 to 15 minutes for about an hour. Take it off with a mild scrub pad & repeat. It may seem excessive, but it sure beats the countless hours I wasted trying everything else first including a power sander (desperation move).
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is online now   Reply With Quote
Old 03-04-2013, 06:45 AM   #27
sealsam
Sam...I am.
Oddometer: 1,975
oven cleaner.
sealsam is offline   Reply With Quote
Old 03-04-2013, 12:00 PM   #28
KungPaoDog
Oddometer: 465
I spent a few summers working for a pool maintenance company, and we used a lot of muriatic acid to clean pools. You could pour it in until the Ph was high enough to scrub away the crap, and then neutralize it with soda ash. I'd ask someone better acquainted with hot tubs if this would be a good idea or not. Depending on your plumbing this could go very poorly.
2010 Honda NT700V-Red
KungPaoDog is offline   Reply With Quote
Old 03-04-2013, 05:25 PM   #29
CodeMonkee OP
Geek Adventurer
CodeMonkee's Avatar
Oddometer: 5,589
Muriatic acid should not be used on acrylic surfaces, which my hot tub is.
'09 Husaberg FE570
'99 Beta Alp
Old 03-04-2013, 05:26 PM   #30
Big Bird 928
Oddometer: 2,623
I don't think that oven cleaner is a good idea either.
Thread Tools
Times are GMT -7.   It's 04:59 AM.
