Old 10-13-2013, 02:50 PM   #1
JustinP OP
JustinP's Avatar
Oddometer: 1,905
LEDRider - Quality LED aux lighting
Update 2/15/15: Current Special - $10 dimmer with our high performance LR35 and LR40 lights! See this post for details. Same deal on our LD35 lights! See this post for details.
A lot has changed at LEDRider over the last year and a half since we started this thread. We're constantly working to bring quality, high performance LED lights to market, at great prices. One thing that hasn't changed is our devotion to amazing customer service - and - we back every purchase with a no BS warranty and return policy.
Since the launch of our popular LR4, we've added a number of great units to our product line.
The LR35/LR40 Series:
http://ledrider.com/shop/?model_number=LR3540
The LR35/LR40 series of lights are the next generation of high quality multi-emitter aux lighting in our line up. These lights are built to extreme standards and feature state of the art designs. From their massive cooling fins that allow massive output, to custom engineered 3D optics for a focused beam, everything about these lights was designed to perform to the highest levels. The LR35 uses 7 Cree XT-E chips to deliver 3640 Lumens, while the LR40 uses 4 Cree XM-L2 chips for a staggering 4160 Lumens, both from a ~3 inch package! These lights offer great range and width, as the 3D optics provide a tight 10 degree center beam, with a wide angle secondary pattern.
Price: LR35 is $200/pair and LR40 is $210/pair before ADV15 coupon code
Product Specifications
Model: LR35
7x Cree XT-E LEDs
3640 Lumens
2.6 Amps @ 12 Volt DC (~31 watts)
Model: LR40
4x Cree XM-L2 LEDs
4160 Lumens
3.0 Amps @ 12 Volt DC (~36 watts)
LD35 Spot:
http://ledrider.com/shop/?model_number=LD35
Our LD35 spot couples a Cree Mt-G2 Emitter with a large reflector to provide long distance lighting, and a wide field of view, from a 3 and 1/4 inch light that only uses 22 watts of power. The LD35's reach out over 803 feet at 1 Lux (1607 feet at 1/4 Lux), while also providing a wide field of view to illuminate the sides of the road. Not only does the LD35 provide amazing range, the Cree MT-G2 chip peaks at 5000 Kelvin, with a wide spectrum, to provide light that creates greater definition at night.
Price: LD35 is $200/pair before ADV15 coupon code!
Model: LD35
Cree MT-G2 LED
1800 Lumens
1.8 Amps @ 12 Volt DC (~22 watts)
LR5 High Output 5000 Lumen Light:
http://ledrider.com/shop/?model_number=LR5P
Our LR5 has been incredibly popular with bikes with big alternators :). The LR5 Hybrid Flood light uses 5 Cree XM-L LEDs to put out over 5000 Lumens, in a package that is only 4.3 inches. The LR5 series are built to take a beating, using polycarbonate lenses, polyester UV resistant powercoat, rugged metal wire inputs and sealed Deutsch connectors. The advanced optics turn night into day at the flip of a switch.
Short Web Review: http://www.doctorschierling.com/blog...ts-on-a-gl1800
Price: LR5 is $230/pair before ADV15 coupon code. That's under $200 for 10,000 Lumens of light for ADVriders!
The two pictures below show two LR5's compared to two H4 Silverstar highbeams. These were taken with a DSLR with the same manual settings. The farthest trees out on the tree line are roughly 500 feet. These lights literally turn night into day and rip through the trees! Unfortunately the trees were in the way so the full potential can't be seen.
Two H4 Silverstars: https://dl.dropboxusercontent.com/u/...1/IMG_6204.JPG
Two LR5's: https://dl.dropboxusercontent.com/u/...1/IMG_6205.JPG
Model Number: LR5 Flood
5x Cree XML U2 LEDs
Custom Engineered Reflectors for 25 Degree hybrid pattern
5000+ Lumens
3.8 Amps @ 12 Volt DC (~45 watts)
LR5's mounted on a Goldwing - From the owner, "I was able to test my new LR5's on my last BBG run and wow, they are great. The really turned the night into day. They are a great addition to my HID low beams. Of course they can only be used when there is no oncoming traffic. :)".
And of course, our original, and very popular, LR4 light that delivers tons of punch from a small package (2.15 inches diameter)
LR4 features listed below:
4x Cree XML U2 LEDs
Custom Engineered Mirrored Reflector for a Focused Beam
3500+ Lumens
2.2 Amps @ 12v
12-36 Volts DC Input
Thermal Protection
Heavy duty mounting hardware is included at no cost. These lights are well built, with an extremely solid feel; and amazing performance.
Order Link: http://ledrider.com/shop/?model_number=LR4
Side View:
Front View:
Front view mounted on Super Tenere
Mounted on FJR with WynPro brackets:
Any questions, please post or PM. Special coupon code for ADVRider Forum members is "ADV15" - you can order using the store URLs above.
FAST: 2004 non-ABS "Silver Bullet" FJR - FASTER: 2008 Touring/Endurance Hayabusa - SLOW: 1997 R1100GS
Quality LED Lighting - ADV Discount inside:) - LEDRider LED motorcycle lights
JustinP screwed with this post 03-02-2015 at 09:48 PM
JustinP is offline   Reply With Quote
Old 10-13-2013, 03:12 PM   #2
Olas
the darkness
Olas's Avatar
Oddometer: 4,023
Just bought a pair of these from Justin. I was very impressed with the feel and quality look of these lights right off the bat. The mount they come with is beefier than what I've seen on other brands. As a bonus, you cannot beat the price either.
I'll get around to installing them this week hopefully, will report back.
Rebuild threads:
'92 XT600, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 10-14-2013, 10:21 PM   #3
JustinP OP
JustinP's Avatar
Oddometer: 1,905
Thanks for your business! Looking forward to seeing your install :)
Old 10-21-2013, 03:01 PM   #4
JustinP OP
JustinP's Avatar
Oddometer: 1,905
FYI Folks - We're back in stock on the LR4's. Had a few inmates waiting to order, but were out of stock on the LR4's
Here's some shot's I was able to grab the other night. Bike is on center stand. The fence is @150 feet from bike. Farthest tree in the background is between 400-500 feet. Crappy camera, non scientific 3 foot per pace measuring, for comparative purposes only. Still working on getting some more "professional" photos. The limited exposure on my camera just doesn't capture enough light for an accurate representation.
Stock FJR Low Beam (55 watt halogen)
Stock FJR High Beam (65 watt halogen)
FJR Low Beam + 2 LR4 Floods
Remember to use ADV10 coupon code for 10% off
Old 11-05-2013, 10:00 AM   #5
JustinP OP
JustinP's Avatar
Oddometer: 1,905
Here's some pictures showing the real world performance of a pair of LR4 Quad Cree XM-L U2 flood lights at 1000 feet. Compared to similar quad Cree XML lights, the LR4 has less light scatter and close in glare, and more range. The reflector design throws a beam like that of a high end flood flashlight; tight beam in the middle for range, with a secondary flood beam for a wide field of view.
Bike was in turnout on right side of road on center stand. Camera was on tripod on the left side of road. 1st tree is at 750 feet, second tree is at 1000 feet. Bike GPS was reset at the farthest tree out and ridden back and turned around where we took the pictures: https://lh5.googleusercontent.com/-c...102_235944.jpg
Note: you can click on the pictures on drop box to zoom in to full size.
First shot is stock FJR (H4) low beams with +80 Halogens:
https://www.dropbox.com/s/6u9bfo4i5q9ohd6/1low.jpg
This is stock FJR (H4) highbeams, +80% halogens:
https://www.dropbox.com/s/kkdv8k420lwq46d/2high.jpg
This is low beams plus 2 LR4 floods:
https://www.dropbox.com/s/55exx1h6o4fhgc9/3LR4.jpg
In other news, WynPro has designed let brackets for the Gen2 FJR, more info here: http://ledrider.com/lr4-light-bracke...-the-gen2-fjr/
LR4 installed on FJR with WynPro Brackets:
We are also working on developing a quality, low cost, rotary dimmer that can be used with our LED lights (and just about any other LED that does not have it's own built in dimming circuitry). We opted for the rotary design as it's simple, and does not require the use of a RF dongle that can be lost or have a dead battery. There will be a high beam over-ride on the dimmed setting. At first it will be available in a single 7 amp channel. Once we are happy with the results, we'll expand to a dual channel as well, with independent over-rides, to control multiple lights with there own settings (for example, you could set your left light to 0% with low beams, and your right to 20% - or control multiple sets of lights). We'll post up more details as they become available.
As always, coupon code ADV10 is good for 10% off for inmates :)
Old 11-06-2013, 05:28 AM   #6
Chuck35
Chuck35's Avatar
Oddometer: 35
I installed a pair of LR4's and mini's on my FJR this weekend. They are managed by a Skene controller. These things are awesome! You could land aircraft with them. Justin was great to deal with and even shipped before he was paid when my money ended up in a Paypal loop.
Caution advised when aiming and setting up power levels. These things can be hazardous to other drivers.
2008 Yamaha FJR1300
Chuck35 is offline   Reply With Quote
Old 11-09-2013, 02:34 PM   #7
zgfiredude
Oddometer: 847
Any progress on the dimmer?
DRZ440E, KLX440R, DRZ250, KTM 950S Adv, F650GS, & F650GS Dakar
zgfiredude is offline   Reply With Quote
Old 11-09-2013, 03:34 PM   #8
JustinP OP
JustinP's Avatar
Oddometer: 1,905
It's moving along. I should have prototypes within two weeks. Once I sign off on the design, will be another week or two for the first shipment to come.
Old 11-29-2013, 03:57 PM   #9
Olas
the darkness
Olas's Avatar
Oddometer: 4,023
It took me a while to get to them, but I finally did the install. It was a very simple process. I am powering them through a relay that uses the high beam as its 12V switched power source. Luckily the V-strom has plenty of room for extra wiring, so you can barely it's there.
First impression is that they are super bright, even during the day. I still need to try them out in the dark, and get them aimed correctly.
Low beam on:
High beam:
Rebuild threads:
Old 11-29-2013, 06:59 PM   #10
JustinP OP
JustinP's Avatar
Oddometer: 1,905
Thanks for the install pics. I think you may find them too bright at night mounted low on your forks and move them up higher, due to the road glare.
Old 12-02-2013, 03:28 PM   #11
JustinP OP
JustinP's Avatar
Oddometer: 1,905
Happy and Safe Holidays from LEDRider to the ADVrider community :). To show our appreciation we have some good news and some holiday specials .
First, the good news: We've bumped our permanent ADV discount code to 15% for the ADVRider community! Use ADV15 when ordering any product from our site.
Holiday Special: Holiday special is wrapped up :)
JustinP screwed with this post 12-10-2013 at 08:37 AM
Old 12-09-2013, 05:50 PM   #12
JustinP OP
JustinP's Avatar
Oddometer: 1,905
Folks - pulling the plug on this sale tomorrow. Last chance to get in on this amazing pricing. :)
Old 12-09-2013, 08:13 PM   #13
ttime4four
ttime4four's Avatar
Oddometer: 259
Thanks for the discount - order just placed.
'14 KTM 690 Enduro R
'14 BMW R nine T
'06 Husaberg FE450e (Oregon Plated)
ttime4four is offline   Reply With Quote
Old 12-10-2013, 08:38 AM   #14
JustinP OP
JustinP's Avatar
Oddometer: 1,905
Thanks for your business. :)
Apparently everyone else waited till the last day too, I'm going to have a busy day .
Old 12-10-2013, 10:13 AM   #15
speedbird
Oddometer: 6
Ordered just now to take advantage of the holiday special. Thank you. Cheers.
speedbird is offline   Reply With Quote
Times are GMT -7.   It's 06:26 PM.
