Old 05-02-2013, 11:10 AM   #91
ABuck99
0.0
ABuck99's Avatar
Oddometer: 626
Im am going to reverse it and put the snorkel back on and see if it makes any difference. And double check that I didn't disconnect/knock a vacuum hose off somewhere. Engine also idles a little high (1600 ish) when its fully warmed up.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 05-06-2013, 11:43 AM   #92
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Update
I did roughly 300 miles yesterday with the Uni 1426 main filter and the Uni prefilter installed. Rode mixed gravel and slab. Works great. Power is just fine. I can't feel a difference between this setup and stock. Kudos to Uni. Cheers.
Old 05-06-2013, 02:07 PM   #93
MudratinOz
Adventurer in training
MudratinOz's Avatar
Oddometer: 913
Originally Posted by boulder View Post
Some pic's of the panel filter that Unifilter Aus have made for the 990.
Sorry about the quality, pictures taken from phone.
These will not be ready for sale for 4 to 6 weeks.
any word when these will be available ??
KTM 2012 990 ADV ABS - BLUE
The orange does grow on you. You will not notice it at first..but it starts with a few innocent KTM stickers,.progresses to a KTM key ring, to KTM coffee mug and next thing you know, you have gone completely mad and start wearing orange tee shirts.It is a very bad infection..is this yeast infection (Bronx)
MudratinOz is offline   Reply With Quote
Old 05-06-2013, 03:24 PM   #94
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 4,051
I looked at those and thought they may be too restrictive so we bought this
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is online now   Reply With Quote
Old 05-06-2013, 03:56 PM   #95
MudratinOz
MudratinOz's Avatar
Oddometer: 913
No more restrictive than the prefilter I'd guess, and for me its about easy servicing and clean air.
the filter in your pic looks mighty thin, going by the picture, how thick/dense is it in reality
Old 05-06-2013, 06:18 PM   #96
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,051
Will photograph our pre cleaner and snorkel on the weekend, not sure of the filter thickness yet, will photograph that too.
All other foam filters we have used on other bikes are not really thick, time will tell I guess.
Old 05-07-2013, 04:13 AM   #97
Filterman
Oddometer: 47
This will be available in the next few weeks. I am putting the final touches to the die to manufacture them this week. In regards to the filter, the is foam is actually 50mm high with hollowed out pockets to increase the surface area. The surface area is actually slightly larger than the original paper. We will have two versions. One for street use and one for dirt use.
Cheers
Filterman is offline   Reply With Quote
Old 05-07-2013, 06:03 AM   #98
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,453
Originally Posted by ABuck99 View Post
Thanks, yes 950. I looked back & saw the post from Boatman.
Boatman: what jetting/adjustments changes are required for the prefilter?
Found my paper finally and after figuring out my chicken scratches realized I'm fairly close to stock. I installed the Uni prefilter after I had done a custom exhaust (2-1 out the left side with a free flowing Neptune can).
This where I'm at right now...
Needles #3 from the top
Fuel screws 2 1/4
Floats at 3.5mm
Mains, front 147.5; rear 150
Idle jet (pilot) 45
Idle air 70
Runs perfect all the way from idle to full. No flat spots or hesitations.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 05-07-2013, 07:00 AM   #99
MudratinOz
MudratinOz's Avatar
Oddometer: 913
Cheers
Thanks for the update
Old 05-07-2013, 07:17 AM   #100
Two Moto Kiwis
Homeless Somewhere
Oddometer: 4,051
Fuel screws 2 1/4
Floats at 3.5mm
Idle jet (pilot) 45
Idle air 70
Interesting settings Boatman
So you have gone down in the main jet size and up one needle setting, really interested in this as we have very small flat spot in transition between pilots and main, most others tend to go up and fuel the crap out of it.
We have factory pilots and she runs fine here, we are about to fit the MW-R foam filter and a precleaner and we run 2 into 1 with baffle in (at least while travelling)
I also have flexijets to put in as well.
I am guessing maybe a needle clip setting change may be required.
Any of your good input would be welcomed so I don't have to try and reinvent the wheel.
Old 05-07-2013, 07:30 AM   #101
ABuck99
0.0
ABuck99's Avatar
Oddometer: 626
Thanks Boatman- Would you say those carb settings apply to sea level to 3000ft?
BTW I removed the pre-filter, put the snorkel back on and hard start problem solved. Seems the combination of the pre-filter opening being smaller than the snorkel & and oiled foam restricts enough airflow to requiring jetting to compensate.
For now, I'm not going to re-jet, and I think I will leave the snorkel on, and simply ziptie some UNI universal foam over the snorkel opening when I get in super dusty conditions-
btw I have 2 new prefilters in the packaging I'd sell $20ea
Seems to me that replacing the paper filter and upgrading to the full UNI set up - and running with out the top of the filter box on would produce best performance. When you look at all the hardware the air has to pass by in the airbox before it gets to the paper filter- sure seems that airflow would be less than optimal.
Fuel screws 2 1/4
Floats at 3.5mm
Idle jet (pilot) 45
Idle air 70
ABuck99 screwed with this post 05-07-2013 at 07:39 AM
Old 05-07-2013, 06:01 PM   #102
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Cheers
Will either of the two versions require remapping of the FI system on the 990? Or can I just install and go?
Old 05-07-2013, 06:16 PM   #103
Filterman
Oddometer: 47
On a standard bike with no other modifications you should not need to remap the bike when using the off road version. On the road version you may need to adjust the settings slightly as the air flow will be improved over the standard filter.
Old 05-07-2013, 08:39 PM   #104
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,453
Going down on the mains was actually the change I made when I installed the pre filter.
I'm at around 1200' and been sea level to probably well over 3000'.
Old 05-08-2013, 01:11 PM   #105
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,787
Nice! Count me in! I want one of these now too (off road version)!
Times are GMT -7.   It's 12:19 AM.
