Old 03-07-2013, 02:10 AM   #1
mas335 OP
xendurist
Oddometer: 1,998
Tachometer problem
I have a 1988 Honda NX650 speedo/tach assembly that has worked fine until recently. The tach is electronic.
When at idle it reads about 800-1000 rpms high, at road speeds ( 65-70mph ) the tach reads about 2,000-2,500 rpms too high. I have temporarily installed another NX speedo/tach assembly just to be satisfied that the problem is in this tach itself and it is, the substitute tach worked perfectly. Other than the hi rpm reading everything else works as it should but the screwed up tach reading is just not acceptable.
I have owned 4 NX650's and worked on a few more plus many other Hondas of that era and this is the only problem of this kind that I have seen or heard of. Anyone else heard of this issue and is there a solution.
Thanks,
Transalps
mas335 is offline   Reply With Quote
Old 03-09-2013, 06:33 AM   #2
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,391
Have you had the instrument cluster circuit board out for any reason before this problem started? Some tachs have little dip switches on them for number of cylinders, etc. I have no experience with the NX650, but it might be possible a switch got moved?
Where does the tach get the signal -- from the coil packs?
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 03-09-2013, 12:49 PM   #3
mas335 OP
xendurist
Oddometer: 1,998
Keep in mind that the tach worked perfect one day and the next time I fired it up this issue appeared.
I did take it apart to clean the back side of the lenses but there is no such switch inside and not a "real" circuit board. The NX650 (single cylinder) does not share this tach configuration with any other model that I am aware of. Yes, it is wired in to the coil.
The back up NX tach works perfectly but reads in KM which is just annoying.
Thanks for the input.
Transalps
Times are GMT -7.   It's 08:04 AM.
