Old 03-02-2011, 06:37 AM   #1
Murf2 OP
Oddometer: 834
iphone charging ?
Hi all, Can you help out an electron challenged fellow rider, please? The wife just got a new iphone, pretty cool device. We want to take it on our travels.
My question to you guys, Is there a ready made adapter to charge it off the SAE connector I use for my battery tender? I searched around the net some but maybe I don't know what I'm looking for. Maybe that's not a good idea using the SAE connector?
As a second thought, Would I need a different set up to charge and ipad? That is the wife's next toy on her list. I read about different voltage and amperage and I get very confused.
Thanks for your help!
Murf2
Thanks,
Murf2 is offline   Reply With Quote
Old 03-02-2011, 06:49 AM   #2
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
You can use this from a Powerlet port... And just use an SAE-Powerlet conversion cable between the two.
http://www.powerlet.com/shop-by-appl...-cable/422/477
You definitely need a different one for the iPad though; I don't remember the numbers, but it does draw more power than the iPhone. Your best bet for that would be to buy a car charger for the iPad and then use an SAE-cigarette lighter conversion cord.
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 03-02-2011, 07:16 AM   #3
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,462
This is the item that you need,,,,
http://www.advrider.com/forums/showthread.php?t=569860
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 03-02-2011, 07:43 AM   #4
dendrophobe
Motorbike Junky
Oddometer: 859
Originally Posted by Boatman View Post
I have one of those that I installed in my Jeep, and it works nicely. The OP had just asked to use the SAE connector he already has. If he's willing to install something new, Powerlet also makes a direct-to-battery iPhone specific charger.
Doug
Semper Fi
Old 03-02-2011, 10:30 AM   #5
scapegoat
Pushin forward back
scapegoat's Avatar
Oddometer: 2,896
Powerlet has some cool stuff but if you have a spare cable from your battery tender you can buy two of the same female plugs off ebay for $5. Just unscrew the halves and solder your tender cable to the socket.
No, I dont own a KLR
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 03-02-2011, 10:39 AM   #6
antonv
Oddometer: 210
i use sae(from battery) to tankbag. Sae to cigarette (female). Griffin powerjolt dual usb cigarette (male). then i just use my iphone wire.
2005 BMW F650GS - Mandarin Yellow - Farkled
2009 BMW 135i - Sedona Red Metallic - ///M Sport
antonv is offline   Reply With Quote
Old 03-02-2011, 10:47 AM   #7
MoxNix
Stuttgart Germany
MoxNix's Avatar
Oddometer: 1,167
Belkin F8Z445
http://www.belkin.com/IWCatProductPa...uct_Id=489767#
Hope is not a course of action.
MoxNix is offline   Reply With Quote
Old 03-02-2011, 07:34 PM   #8
Murf2 OP
Oddometer: 834
Thanks for all the help, guys!
Boatman, that looks like what I need. Don't know how I missed that thread in my search. Thanks.
Murf2
Old 03-02-2011, 07:55 PM   #9
ThatGuy
Brownie
ThatGuy's Avatar
Oddometer: 5,350
I picked up all my SAE/Powerlet cords and fittings from Burnsmoto over in the vendor section. Fast shipping as well. Check him out.
Disclaimer: The writer does not represent any organization, employer, entity or other individual. The views expressed are those only of the writer. In the case of a sarcastic, facetious, nonsensical, stirring-the-pot, controversial or devil's advocate-type post, the views expressed may not even reflect those of the writer.
ThatGuy is online now   Reply With Quote
Old 03-02-2011, 08:01 PM   #10
doublen
doublen's Avatar
Oddometer: 260
Originally Posted by MoxNix View Post
Yup, got one of those too since my phone uses USB to charge as well. Found a 12v (Cigarette lighter type) sae adapter cable to hook up to the lead from my Battery Tender. Works a treat.
Stay tuned for ride reports ... Idaho to Arizona in May and Idaho to The East Coast in September.
-09' Triumph Street Triple R
I am The Stig...
doublen is offline   Reply With Quote
Old 03-03-2011, 03:23 AM   #11
Murf2 OP
Oddometer: 834
OK, I've got another question. Since people keep post cigarette & Powerlet suggestions, is there some reason not to go from SAE direct to the USB charger? Seems like the more connections & adapters used the more possible problems I could have. Rember, I do not know what I'm doing!
Murf2
Old 03-03-2011, 06:58 AM   #12
worwig
Oddometer: 1,278
Murf2
The fewer connections, the less chance of failure.
Hog mountain Weather
worwig is offline   Reply With Quote
Old 03-03-2011, 08:43 AM   #13
Yakima
DL 650
Yakima's Avatar
Oddometer: 394
contact this guy:
Ray Bowers
Bohemian Biker LLC
302-562-1706
I found him on ebay. Quick responses to questions. All the attachments/adapters you'd need. Not expensive. Check him out.
Yakima is offline   Reply With Quote
Old 03-03-2011, 09:09 AM   #14
antonv
Oddometer: 210
I like breaking it up into a cigarette adapter, because I can run all sorts of stuff from it......not necessarily at the same time. compressor for tires, radar detector, charge my sena bluetooth unit, cigarette flashlight.....etc
Old 03-03-2011, 09:44 AM   #15
jamesdemien
jamesdemien's Avatar
Oddometer: 609
The iPhone/iPad won't charge from a standard usb power socket. they both need a special little internal jumper on the usb side to realize they've been plugged in. The belkin product posted earlier will do the trick. I bought one of those and soldered a coax plug to it and wrapped the entire thing in shrink wrap.
The iPad does require more power to charge but will still charge slowly from a standard wattage plug. It will report that it is not charging while you've got it on because there's not enough juice to run the screen and charge the battery at the same time. However, if it's sleeping it's charging.
This is testing before the heat-shrink but you get the idea...
If you don't fall you're not going fast enough?
Gateway BMW Motorcycles St. Louis | Vimeo
jamesdemien is offline   Reply With Quote
Times are GMT -7.   It's 09:39 AM.
