Old 03-07-2013, 06:46 PM   #1
SantaFeTrailer OP
Stromtrooper
SantaFeTrailer's Avatar
Oddometer: 325
Hack Newb Technical Assistance Needed
Hi
I picked up an XT225 that I would like to hack. This is a strictly around the neighborhood and up to school (1.25) mi. rig. The bike is light (267 lb wet) and the sidecar will be too, since with 3 up the little XT might have some trouble making it the hill we live on. I am planning a simple square tube frame with bench seat for 2 monkeys, riding on a torsion axle.
First a mock up of my car idea. I am thinking I can install three point belts to hold the monkeys in place.
Here are some shots of the bike. It does not have a perimeter frame (the engine is a stressed member to some degree) and there are not many mounting points. This is a small bike.
So, what say your collective wisdom on mounting points/subframe (or the car design)? The footpeg is mounted solidly, so that is one definite point. working something in to the engine mount seems like another good possibility.
Thanks in advance for the suggestions.
SantaFeTrailer screwed with this post 03-07-2013 at 06:54 PM
SantaFeTrailer is offline   Reply With Quote
Old 03-07-2013, 07:16 PM   #2
Qwik
Adrenaline Addict
Oddometer: 6,865
Im a newb to this as well but I am seeing multiple mounting points. The Front of the downtube where the motor plate is located is one and the bolt behind the motor (Right by the Yamaha "Y") is another. as well as the Peg mount. Maybe a fourth one clamped the the frame tube?
Topes never seem to make me go any faster.
Qwik is online now   Reply With Quote
Old 03-07-2013, 11:15 PM   #3
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
Some quick thoughts
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-08-2013, 07:40 AM   #4
SantaFeTrailer OP
Stromtrooper
Oddometer: 325
Thanks BMWe
From this pic it seems as if you are thinking 3 point mount? I had it in my head that might be adequate for such a light rig that will probably not see the north side of 25mph.
[/QUOTE]
When you say "build 2 piece clamp" that is the strap-and-anvil type thing?
So, basically, just use the points I have, and as many of them as possible?
Thanks.
Old 03-08-2013, 07:49 AM   #5
Qwik
Adrenaline Addict
Oddometer: 6,865
Fourth point up by the top pillion peg mount
Old 03-08-2013, 10:01 AM   #6
claude
Sidecar Jockey
Oddometer: 3,842
Great diagrams by Chris!! The front lower can b edon ewith a pllate on each side of th edowntube through bolted ...yes. pic up as many mounting points as possible and connect th edots with tubing. Overkill rules!
Claude
http://freedomsidecars.com/
Old 03-08-2013, 11:00 AM   #7
Boxer Metal
Mad Scientist
Oddometer: 3,521
When I get over this stupid cold and I'm at the shop I'll take some pictures of a clamp and home made upper struts. You might have to remind me.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-08-2013, 12:16 PM   #8
jaydmc
Oddometer: 1,059
Make this a one peice sub frame that gives you all 4 mounting points. Start at the front of the frame, the two bolts at the botom of the frame use these and go back on both sides of the bike to the foot peg mounting bolts. Also go up from these two bolts (this part could be bolt on) and as sugested also clamp around the frame. From the rear go up from the sub frame and pick up the mounts for the passenger foot peg.
Spread the parts as far as part as possible.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Old 03-13-2013, 07:40 PM   #9
SantaFeTrailer OP
Stromtrooper
Oddometer: 325
Thanks for the suggestions.
I played around with some prototyping tonight.
I will double up to the other side as per suggestion.
A little hard to tell in this pic, but I have a 1x1 upright bolted to both engine mount bolts that I can attach the front upper strut to.
Maybe use this area to mount the upper rear?
and pay no mind to those ugly welds
Old 04-23-2013, 02:49 PM   #10
japako
japako's Avatar
Oddometer: 592
I'm a noob at building a side car also. Have not built one yet..
But I do a little welding. You should not grind your welds to make them look purty. When doing this you weaken the weld. Use some scrap of the same thickness and practice.
I like what your doing and plan on doing something similar..
japako is offline   Reply With Quote
Old 04-24-2013, 06:33 PM   #11
MILLENNIUM FALCON
Oddometer: 245
Its great to see some more people putting hacks on small bikes. here is a picture of my xt350 project Ive been working on. My subframe is very similar to yours. I have a few more braces to add but its almost done.
MILLENNIUM FALCON is offline   Reply With Quote
Old 04-25-2013, 07:34 AM   #12
SantaFeTrailer OP
Stromtrooper
Oddometer: 325
Originally Posted by MILLENNIUM FALCON View Post
Its great to see some more people putting hacks on small bikes. here is a picture of my xt350 project Ive been working on. My subframe is very similar to yours. I have a few more braces to add but its almost done. [URL=http://s1080.photobucket.com/user/captain_neto/media/DSC_0675_zpsf325ac32.jpg.html]
Nice job! That is way more advanced than I am shooting for on my first project (but I do have an XS650 cafe project calling out for a leaner!)
SantaFeTrailer screwed with this post 05-07-2013 at 07:00 PM
Old 05-07-2013, 07:07 PM   #13
SantaFeTrailer OP
Stromtrooper
Oddometer: 325
Well, its alive. I rode around the block and it didn't handle miserably at least. That's a whole different beast to ride, huh?
Lots of work to go on unit, subframe, etc. but hopefully I'm on track to have something to ride around Overland Expo.
[IMG][/IMG]
I switched to the stick welder and I am getting better results with that. Some welds aren't even embarrassing!
This is more representative: decent penetration but ugly:
I am having a problem on the superstructure which is thinner metal. I have the heat turned down as far as I can and still strike an arc but it is burning through. Japako, what do you think? Maybe need smaller rods?
Old 05-08-2013, 03:33 AM   #14
cleatusj
Dirt floor engineer
cleatusj's Avatar
Oddometer: 1,202
3/32 or 1/16 rods and move faster. Just my .02.
In the stable now. '76 Moto Guzzi Convert Hack
'93 Moto Guzzi Calli 3 with Leaner turned rigid
'99 WR400F
Hack build: http://www.advrider.com/forums/showt...rt+floor+build
cleatusj is offline   Reply With Quote
Old 05-08-2013, 09:47 AM   #15
SantaFeTrailer OP
Stromtrooper
Oddometer: 325
Thank you.
Times are GMT -7.   It's 07:01 PM.
