Old 05-08-2013, 10:53 PM   #16
boxertwin
Oddometer: 1,023
Below is a link to my DRZ build. There's lots of ways to make this work. This was my first project, it ain't pretty, but it did work well. The parts that I want to point out are; I was able to have a narrower rig by seating the passengers one in front of the other, with roll cage protection, and five point harnesses by using car seats.
The attachment points to the bike worked well.
I would not use a dirt bike swing arm with linkage to the shock as I did. It makes for an easier project but adds in several problems...in my humble opinion.
http://boxertwin.smugmug.com/Other/Hack/9828482_dMbJDQ
boxertwin is offline   Reply With Quote
Old 05-09-2013, 04:23 PM   #17
Old Mule
Old Mule's Avatar
Oddometer: 441
Dr
Very nice job on that tandem seater.
Old Mule is offline   Reply With Quote
Old 05-09-2013, 05:29 PM   #18
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,490
This oughta be a perfect "Munchkin Mobile" for the young'uns!
I also have a feeling you'll be called upon to make an occasional "beer run" too.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 05-09-2013, 05:43 PM   #19
JPierce
Oddometer: 5
I've been thinking about a small cc hack, but I haven't settled on which tug to use yet. Leaning toward my old Honda SL350
For stick welding, smaller diameter rods, keep your arc short by holding the rod closer to your metal, angle it to distribute more heat the thicker piece if the two pieces are different thickness.
Easier to do than to explain
JPierce is offline   Reply With Quote
Times are GMT -7.   It's 08:26 AM.
