Old 03-08-2013, 11:30 AM   #1
Laki TC OP
Laki TC's Avatar
Oddometer: 7
Fuel injectors and fuel level light BMW r1100rs
I have two problems on my 94 RS.
1. Light that signals that fuel is out, the red one, is working constantly, despite the fuel level in tank. Fuel level gauge is working as it should, so I know how much fuel is in the tank.
2. Left injector is leaking, when ingnition is off, when I pull out the injector it let about one drop every minute or so. Oil also stinks like fuel, when I smell the cilinder with the oil cap remowed. Should I clean injectors ultrasonically, will it stop leakage? Is it possible that oil can smell like gas because of something else as well?
Laki TC is offline   Reply With Quote
Old 03-09-2013, 09:48 AM   #2
Laki TC OP
Laki TC's Avatar
Oddometer: 7
nobody?
Old 03-09-2013, 10:44 AM   #3
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,938
You need to clean or replace the injectors. If you're goin to try cleaning them yourself, you should energize the injector so it's open so the deposits on the pointless, the little valve are cleaned off.
The oil has fuel in it be because of the injector.
So far as the fuel level light, I believe ere are two circuits on the sender, one for the guage and one for the light. Maybe the warning light contact at the sender is bad.
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 03-10-2013, 11:45 AM   #4
Laki TC OP
Laki TC's Avatar
Oddometer: 7
Thanks, I will get the injectors to the service to clean them ultrasonically.
Cheers...
Old 03-13-2013, 02:00 PM   #5
Laki TC OP
Laki TC's Avatar
Oddometer: 7
Do you know what settings do I need for 93 r1100rs with no CO pot, Laser exhaust and no O2 sensor? CCP is removed, so I need to switch it back to 30-87 connection or 30-87a?
Old 03-15-2013, 07:57 AM   #6
walkingbear
walkingbear's Avatar
Oddometer: 3,543
same with mine
I found a used fuel pump and checked the connection. That took care of the fuel problem on the fuel sending unit.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Times are GMT -7.   It's 12:10 AM.
