Old 03-09-2013, 09:16 PM   #1
silverdog OP
silverdog's Avatar
Oddometer: 589
Wiring diagram
Any one care to draw me a wiring diagram how to properly hook up driving lights, using a switch?
Also using high beam to turn on light.
Thanks.
silverdog is offline   Reply With Quote
Old 03-09-2013, 09:44 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,477
Take your pick:
http://www.jimvonbaden.com/BMW_Wiring_Diagrams.html
Connect the 12 volt switched power to your high beam, use or do not use the switch, your choice.
Jim
JimVonBaden is online now   Reply With Quote
Old 03-09-2013, 09:45 PM   #3
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,816
Same as this except you are going to trigger off the high beam instead of low as shown.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 03-09-2013, 09:46 PM   #4
JimVonBaden
"Cool" Aid!
Oddometer: 54,477
I like yours better!
Jim
Old 03-10-2013, 05:46 AM   #5
silverdog OP
silverdog's Avatar
Oddometer: 589
good job guys........ thank you.
Old 03-10-2013, 10:35 AM   #6
troidus
Oddometer: 16,276
Is there an online circuit designer that lets you drop in components and draw lines between them to mock up circuits? I've had an idea kicking around in my head for awhile, but every time I sit down to sketch it out I quickly run out of colors and the connections get a bit confusing. I'd also like to put a virtual 12VDC to the mocked-up circuit to verify operation.
troidus is offline   Reply With Quote
Old 03-10-2013, 10:40 AM   #7
duck
duck's Avatar
Oddometer: 10,403
You might also want to consider:
Relay terminal 86 - high beam
85 - grounded via switch
30 - power in
87 - power to aux lights
duck is offline   Reply With Quote
Times are GMT -7.   It's 02:51 PM.
