Go Back   ADVrider > Bikes > Hacks > Hack Vendors
Old 05-12-2011, 01:37 PM   #1
Sparrowhawkdesign OP
Sparrowhawkdesign's Avatar
Oddometer: 132
BMW 800 GS pictures
The first two pictures of the 800GS / M72 install. More will be added over the next couple days as the install progresses. Barry
DMC SIDECARS
General Manager, designer, installer, test rider, problem solver. Generally whatever needs doing.
37 YEARS PLAYING WITH SIDECARS
Myths and misinformation are more seductive than the truth.
Sparrowhawkdesign is offline   Reply With Quote
Old 05-12-2011, 01:39 PM   #2
Oddometer: 132
800 GS pic
Second picture.
DMC SIDECARS
Old 05-12-2011, 02:05 PM   #3
DirtyDR
Dana
DirtyDR's Avatar
Oddometer: 2,575
06 Ural Patrol
03 R1150 GS Sport/ Friendship II
94 R1100RS
99 Rokon Ranger
71 Rokon RT140
Hack'n the TLH
http://www.advrider.com/forums/showthread.php?t=592860
http://dirtydr.smugmug.com/
Proud Member of the Patrol Patrol
DirtyDR is offline   Reply With Quote
Old 05-12-2011, 02:53 PM   #4
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 5,972
very much looking forward to watching this thread
i know it's going to be great
Greg
'11 R1200 GS Adventure with a DMC M72DX Sidecar
'14 R1200 GS & '14 R nineT (march, 2014)
Live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW is offline   Reply With Quote
Old 05-13-2011, 01:06 PM   #5
camaroz1985
Oddometer: 172
Me too. Can't wait to see the finished product.
camaroz1985 is offline   Reply With Quote
Old 05-13-2011, 01:25 PM   #6
KCDakar
What are we waiting for?
KCDakar's Avatar
Oddometer: 3,388
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay
Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6
KCDakar is offline   Reply With Quote
Old 05-13-2011, 01:25 PM   #7
Oddometer: 132
mounts on
Just got our first in house built Sportster trike out the door. Now I can concentrate on this build.
Barry
DMC SIDECARS
Old 05-13-2011, 02:22 PM   #8
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 05-13-2011, 03:05 PM   #9
Oddometer: 132
Frame
M72D frame mounted on adjustable installation stand. This allows us to level the frame and roll it around while mounting to the bike. B
DMC SIDECARS
Old 05-13-2011, 03:11 PM   #10
Oddometer: 132
Custom wheel
We used this custom built Excel wheel. This is the same rim used by Touratech in combination with the spline drive spokes to upgrade stock BMW wheels. This also allowed us to match the rim color on the bike and install the same tire used on the rear.
I don't know if I will get more pics posted today or not. I will be away through the weekend so posts will probably start again Monday.
Barry
DMC SIDECARS
Old 05-13-2011, 03:51 PM   #11
Oddometer: 132
Motorcycle install stand
This stand allows us to set the preload and initial lean out.
DMC SIDECARS
Old 05-13-2011, 03:54 PM   #12
Oddometer: 132
Together
You can see in this picture how we can roll the sidecar up to the bike and align the two. More Monday. Barry
DMC SIDECARS
Old 05-13-2011, 04:39 PM   #13
KCDakar
KCDakar's Avatar
Oddometer: 3,388
I remember that set up!
Old 05-13-2011, 08:26 PM   #14
ClearwaterBMW
The Examiner
Oddometer: 5,972
i can't wait to see more....
and..... not just of that 800GS install....
maybe a couple of bikes with 400 more cc on their designation...
great thread, barry
awesome stuff happening at DMC
and... even more all the time
Greg
Old 05-16-2011, 10:53 AM   #15
Oddometer: 132
800GS build
The next step is to connect the A-arms between the bike and sidecar frame. At this point we only snug the bolts as adjustments still have to be made. The A-arms set the wheel lead and put the toe-in close while not compromising ground clearance like can happen with the usual boss/clamp setup. Next we fine tune the toe-in with a turn or two in or out on the heim joints. This will mean rolling the frame stand away from the bike to allow the heim joints to be turned in the required direction. Fortunately the use of the heim joints also allows for easy alignment with the clevis. Once the toe-in looks good we re-snug all the bolts and check the toe again. If it is still good we then torque the A-arm pinch bolts to 80 ft lb. and tighten the jam nuts on the heim joints. One last check of the toe-in is a good idea as it can sometimes move while tightening the bolts.
DMC SIDECARS
Times are GMT -7.   It's 07:47 AM.
