Old 05-04-2011, 07:18 AM   #1501
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,415
Originally Posted by Ol'Muley View Post
Has anyone found a good replacement footpeg for the 640? Not too expensive or worth the extra $$$ ?
im gonna assume its the same as the e-models. you have to replace the left side foot peg mount. buy one from a '04 SXC, then you can instal what ever you want. unfortunately it's not cheap, especially when you add in the foot pegs, but i LUV my fastways.....
you can see the size diff between those and the rally pegs. the rally pegs are bigger than the stock pegs.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-04-2011, 05:02 PM   #1502
Ol'Muley
old, not dead
Oddometer: 82
Question peg
Thank's Laramie,
Should the right side be a direct fit?
Ol'Muley is offline   Reply With Quote
Old 05-04-2011, 07:53 PM   #1503
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,533
this is what I want to go with to get my legs a little farther out, not cheap but damned pretty
footpeg extensions
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 screwed with this post 05-05-2011 at 05:56 AM
skibum69 is offline   Reply With Quote
Old 05-04-2011, 08:15 PM   #1504
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,627
Thumbs down
ZipTy extensions
Linky failed!!!!!
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 05-04-2011, 08:34 PM   #1505
dnrobertson
Big Bike, Slow Rider
Oddometer: 836
Originally Posted by mxchamp View Post
Linky failed!!!!!
http://www.lmgtfy.com/?q=zipty+extensions
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 05-05-2011, 04:01 AM   #1506
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,165
Originally Posted by G-Funk View Post
I just had my shop make me one ....... I put rox risers on my 640 and the only cable that needed to be longer was the decomp cable. Oh, and BTW my shop (I know the peeps there) is a triumph shop. I could see if they could make you one if you'd like - EDIT: Just read your post again and you have a place that can make you one if you send them an OEM one ...... I believe I have the original one still. If I do you can have it for the cost of a six pack.
I'll check when I get home from work and post up, eh ......
G.
Thanks G-Funk. I just need an OEM cable for show and tell that Motion Pro can use to duplicate. PM sent.
fastdadio is offline   Reply With Quote
Old 05-05-2011, 05:07 AM   #1507
laramie LC4
crash test dummy!
Oddometer: 2,415
Thank's Laramie,
yup, the right goes right on without issues.
laramie
Old 05-05-2011, 05:55 AM   #1508
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,533
Originally Posted by dnrobertson View Post
nice one David-thanks
here it is again-fixed without my articles
footpeg extensions
Beerthief
Old 05-05-2011, 05:30 PM   #1509
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
PM sent back .....
G.
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 05-24-2011, 09:17 AM   #1510
frdbronco8
frdbronco8's Avatar
Oddometer: 245
stumble at idle when warm
I posted this last fall on the BST 40 section but I have since replaced the carb with two others with the same results and so I feel I can rule that out.
My 99 LC4 E starts fine and runs good when cold. After its warmed up fully and ridden around a little it starts to stumble at idle and occasionally die. Especially if you try to feather the clutch and go slow but it also does it just sitting there in nuetral. It starts right up each time after it dies but then does it again right away (assuming its stull warm). When I let it sit for a while it starts to run normal but quickly begins the stumble again (as it gets warmed up faster since it didn't sit long enough to become completely cold). Im thinking it has to be electrical. The plug is new and I just cut the tip off the plug wire and screwed the cap back on with no results.
Anyone experience the same thing? Im am all ears.
Or does anyone wanna buy this bike as is for a discount in the Seattle area?
2005 Yamaha Roadstar 1700
2008 KTM 450 XC (540) ATV
2005 KTM 450 EXC
frdbronco8 is offline   Reply With Quote
Old 05-24-2011, 10:22 AM   #1511
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
Lot of oil smoke when I cold started the engine
Hi, mates!
I have posted this issue at the thread "KTM 640 Adventure owners, sign in please...", but had no luck.
Following the same procedure as always, I have cold started the engine with the choke set to the level which maintain 3.000rpm, until the engine gains 1 line in the temp scale.
Then my bike started to produce that smelly grey oily smoke we all know someday must happen... but not with 45.000Kms on the clock...
I immediately released the choke, despite I was sure the smoke will keep going out of the exhaust, but... it actually stop. Then I put the engine @4.000rpm and no smoke. Then I put it @5.500rpm, this time riding to my office, and nothing!
1 week later it has never appeared again.
What the heck is going on??? I know there must be a reasonable explanation, and I hope it does not include a severe damage...
What do you think, guys?
Thanks in advance for your help...
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 05-24-2011, 11:43 AM   #1512
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,165
Since It's done this with 3 diff carbs, Check valve clearence. Temp related problem could also be an intermittant open coil.
Old 05-24-2011, 02:23 PM   #1513
frdbronco8
frdbronco8's Avatar
Oddometer: 245
Im going to try to check the coil(s) tonight. Laramie posted what the ohms should be for me on TT. I have never done this and dont even know where to put the meter to test. Anyone have pictures?
2005 KTM 450 EXC
Old 05-24-2011, 02:28 PM   #1514
ericswede
Oddometer: 8
Check the valves too, I read somewhere it can be the issue if the LC4 dies or is hard to start when hot
ericswede is offline   Reply With Quote
Old 05-24-2011, 03:07 PM   #1515
Zwoehr
Oddometer: 52
How old is the battery? My Duke had the same problem when the battery was almost dead. I raised the needle one clip and replaced the battery at the same time so I'm not sure which solved it but everything is back to normal now.
Zwoehr is offline   Reply With Quote
Times are GMT -7.   It's 05:32 AM.
