Old 05-24-2011, 03:07 PM   #1516
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,421
Originally Posted by frdbronco8 View Post
Im going to try to check the coil(s) tonight. Laramie posted what the ohms should be for me on TT. I have never done this and dont even know where to put the meter to test. Anyone have pictures?
just read the pig tails coming out of the coil. it's easy, the blue/white wire is obvious, use the green as a ground or any other good ground. the "ignition wire" is your plug wire.
since this happens when the bike is warm i would be concerned that you may get diff results cold.
in the mean time, i would be looking at every single connector plug and every wire. i know its hard to check all the wires without stripping the bike but do your best. pay close attention to anything that is close to the engine or exhaust.
good luck,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-24-2011, 06:38 PM   #1517
frdbronco8
frdbronco8's Avatar
Oddometer: 246
good luck,
laramie
I keep getting all 000 on my multimeter. Dont really know what Im doing though as there are multiple setting on the meter for ohms. they all seem to read 000 when I touch the wires from the blue/white to the ground. This is with the bike off and cold.
2005 Yamaha Roadstar 1700
2008 KTM 450 XC (540) ATV
2005 KTM 450 EXC
frdbronco8 is offline   Reply With Quote
Old 05-24-2011, 06:40 PM   #1518
frdbronco8
frdbronco8's Avatar
Oddometer: 246
Theres another canister thats orange on the right side of the head with a yellow/red and a brown wire coming out of it that came loose one time and hit the head pipe. I put it back but it got hot would this be something related?
2005 KTM 450 EXC
Old 05-24-2011, 08:05 PM   #1519
laramie LC4
crash test dummy!
Oddometer: 2,421
this is a little more complex, you will need some alligator clips and a test lamp to do this. if the capacitor is bad, it could certainly cause some issues.
laramie
Old 05-24-2011, 08:17 PM   #1520
frdbronco8
frdbronco8's Avatar
Oddometer: 246
Sweet, running out to the garage to do this now! I assume the bike has to be running and in my case probably warmed up for this test to be accurate? I may have to run a lead under the tank to the green/white wire to be able to test it while running since it is all hidden under the tank and whatnot....
2005 KTM 450 EXC
Old 05-24-2011, 09:08 PM   #1521
frdbronco8
frdbronco8's Avatar
Oddometer: 246
Ok scratch that, I just read on my meter that the power is supposed to be off to the tested unit. I tested the capacitor with positive results. The coil however Im am not sure of.
0,425-0,575 (is that the same as .425-.575 on the meter?) When I set the meter to the 200 range it reads .7 Any other setting on the meter and it reads 000.
The coil to plug wire give me a no read indicating no matter what setting its on. (On my meter its a 1 at the front of the display, same as when the leads are held apart and not touching anything).
2005 KTM 450 EXC
Old 05-25-2011, 03:23 AM   #1522
jonnyw
Oddometer: 585
Giant Loop on a LC4
Anybody got one setup on a ADV or any LC4? I was wondering about the side straps. Or if anyone can finda some pics. thanks
jonnyw is offline   Reply With Quote
Old 05-25-2011, 05:54 AM   #1523
mr. matteeanne
Bender can pass him
mr. matteeanne's Avatar
Oddometer: 14,414
Where can I buy "dash lights", neutral etc? On a 1997 Duke 620e?
Don't be surprised.
mr. matteeanne is offline   Reply With Quote
Old 05-25-2011, 06:03 AM   #1524
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Originally Posted by ericswede View Post
Check the valves too, I read somewhere it can be the issue if the LC4 dies or is hard to start when hot
+1
Check Creeper's valve lash inspection thread discussion; after my first inspection he asked me that very question.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-25-2011, 06:40 AM   #1525
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,172
Yes. 200 will usually be the lowest range. Anything over 200 ohms will be infinity. In the 200 range on your meter, touch the test leads together and note the value. subtract that value from the reading you got from the coil. The test leads themselves have a resistance value which must be subtracted to get the true value of the coil.
fastdadio is offline   Reply With Quote
Old 05-25-2011, 06:40 AM   #1526
laramie LC4
crash test dummy!
Oddometer: 2,421
i wired in my own LED's that i got from an electrical suppply store. works like a charm, very durable, and dont burn out. the only catch is you have to wire in diodes if you want the "blinker" indicator to work in both directions. pretty simple process though. if you need i can post a schematic of what you need to do.
here is what mine look like, i completely removed the speedo (i use the GPS) and then built an aluminum bracket to hold the lights.
laters,
laramie
Old 05-25-2011, 06:46 AM   #1527
laramie LC4
crash test dummy!
Oddometer: 2,421
yes, 0,425 is the same as 0.425 ohms. as for your settings im not sure, my multimeter does all that shit for me, i just have 1 ohm setting.
remove the ignition wire and read off the coil, see if that changes the numbers. you may have a bad plug wire.
laramie
Old 05-25-2011, 05:10 PM   #1528
frdbronco8
frdbronco8's Avatar
Oddometer: 246
Thanks all for the info, I will check the plug wire tonight. If i get the same results I believe I will be ordering a coil. Looks like about 85 bucks on Bikebandit.
2005 KTM 450 EXC
Old 05-25-2011, 05:22 PM   #1529
laramie LC4
crash test dummy!
Oddometer: 2,421
you can get it cheaper on ktmtalk through Munn racing. i just checked....
laramie
Old 05-25-2011, 05:38 PM   #1530
WVhillbilly
WVhillbilly's Avatar
Oddometer: 11,087
Nope but I'm getting one
WVhillbilly is offline   Reply With Quote
Times are GMT -7.   It's 02:21 PM.
