Old 05-25-2011, 10:39 PM   #1531
frdbronco8
frdbronco8's Avatar
Oddometer: 245
Originally Posted by laramie LC4 View Post
you can get it cheaper on ktmtalk through Munn racing. i just checked....
laramie
Sweet! I just rechecked it and the primary coil test reads .7 I checked with the leads touching each other and it read between .2 and .3 so it looks like that test is just about right since Im looking for .4 to .5ish. The secondary coil test give me no reading (OL). I tried it again directly to where the ignition wire connects to the coil with the same result so Im assuming this means the coil is bad? Im surprised that the bike runs at all this way. Does this make sense? Time to order a coil?
2005 Yamaha Roadstar 1700
2008 KTM 450 XC (540) ATV
2005 KTM 450 EXC
frdbronco8 is offline   Reply With Quote
Old 05-26-2011, 05:01 AM   #1532
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,475
Originally Posted by jonnyw View Post
Anybody got one setup on a ADV or any LC4? I was wondering about the side straps. Or if anyone can finda some pics. thanks
dancingboy runs one on his 690
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 05-26-2011, 06:34 AM   #1533
AWM
Beard Bros Racing
AWM's Avatar
Oddometer: 11,383
Hey guys,,a good friend,noninmate,just picked up a 2000 640ADV,and has been have'n problems with starting the bike.
For some reason the bike doesn't like to start unless he turns the idle way up.When he turns the idle up,it'll barely start.Then he gets the idle set and rides.Runs great,,,till you shut it off,and try and restart it.Then he has to turn the idle way up again to get it started.
Anybody have this problem?
Or what do you guys think?Valves maybe alittle to tight?
Or is there a common thing with these BST carbs??
"Hes not called the Angry White Man for nothing,much more fitting then the,Unicorn Clouds and Happy Trees Man".... UpST8
Theres a name for people without beards,"Women".
AWM is offline   Reply With Quote
Old 05-26-2011, 09:17 PM   #1534
HydroDog
Oddometer: 132
This is the only picture I could find of my bike with the GL on.
08 Buell Ulysses
07 GasGas 300
02 MZ Skorpion Traveller
99 KTM 640e
HydroDog is offline   Reply With Quote
Old 05-26-2011, 09:43 PM   #1535
frdbronco8
frdbronco8's Avatar
Oddometer: 245
So much for that, looks like the coil is good after all, I was using the meter wrong. Once I set it to 20K setting it read 12.73 which is within spec for the secondary coil. So, the coil is good, the carb seems good, the capacitor seems good. Ok guys whats next. Im all ears
2005 KTM 450 EXC
Old 05-26-2011, 10:12 PM   #1536
Zwoehr
Oddometer: 47
What does your spark plug look like? Check that your choke (enrichment) cable is not adjusted wrong or bound up. How many volts does your battery have? Can you start the bike over and over with the E start? Still sounds like a fuel problem (too much gas) since it happens when it is warm.
Zwoehr is offline   Reply With Quote
Old 05-26-2011, 10:15 PM   #1537
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,073
How do you get off of that? Your bike, like mine, only has a center stand, and I can't figure out how to get off the bike with packs right in front and behind. Without just laying the bike on it's side, I mean.
Maybe I should be asking "just how tall are you?"
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 05-27-2011, 04:46 AM   #1538
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,475
break down and buy an SW Motech sidestand from Twisted Throttle-it will make your life sooo much better! One word of advice with it is to seal up the hole in the bottom with silicone
Beerthief
Old 05-27-2011, 06:41 AM   #1539
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
Am I the only rider who steps onto the left footpeg to get on and off the bike when it's full loaded??? Am I dishonoring our dirt rider's breed? AM I TOO GIRLY TO BE PART OF ADVRIDER????
Please... tell me if I should buy an old little Vespa scooter... yes, those ones you can use a skirt with...
Seriously, since the first time I full loaded my bike, I felt using the footpeg like getting on a horse, was the most basic way to go (even though months later I added the side stand).
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 05-27-2011, 06:48 AM   #1540
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 513
You are not alone, I do it the same way.. it seems my legs were shipped from the factory about 2" shorter than my 640's were designed for. (Loaded or Unloaded, it is way ez'r)
NitroAcres is offline   Reply With Quote
Old 05-27-2011, 06:54 AM   #1541
Lance R
Lance R's Avatar
Oddometer: 16
AMEN,
I just got mine on yesterday and i love it. I'll seal the hole asap - good advice.
I decided i had to have one as i had been getting on the bike while it was on the centerstand and then rocking it off forward. I was doing this in public the other day and a guy pulled up and asked "where do you put the quarters?".
Lance Reeves
De Leon Texas
85 Honda V65 Magna
97 KTM RXCe 620
Living well is the best revenge!!
Lance R screwed with this post 05-27-2011 at 07:05 AM
Lance R is offline   Reply With Quote
Old 05-27-2011, 07:07 AM   #1542
meat popsicle OP
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
Creeper’s Valve Inspection
Creeper's Finding TDC-C
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 05-27-2011, 08:31 AM   #1543
slackmeyer
slackmeyer's Avatar
Oddometer: 3,073
That's fine, I just haven't figured out how to put the bike on the centerstand before I get off. Getting on is not the problem.
Zak
ktm
old bmw
others
Old 05-27-2011, 09:12 AM   #1544
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
Ouch... yes! I was there too... sorry I forgot about it. Anyway, as you saw, I felt funny today... and your post gave me the space...
Do you remenber when we were kids, and we get off our bikes (a.k.a. bicycles) while still in motion? ok, I did that everytime I didn't find a
rock/slope/trunk/log where to step on... but I recognize it's not always comfortable. That's why I added the side stand as our inmate skibum has adviced.
Old 05-27-2011, 10:48 AM   #1545
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,392
Use your kick start lever to lift up on the bike when putting it on the center stand. Makes a perfect handle.
Laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Times are GMT -7.   It's 10:06 AM.
