Old 05-31-2011, 02:02 AM   #1561
bigboyxl
bigboyxl's Avatar
Oddometer: 325
Originally Posted by Sumi View Post
I have the SW-motech one, and like it:)
http://shop.sw-motech.com/cgi-bin/co...typid=36991190
If you have a 2006 with the black powder coated frame, maybe you'll want the black sidestand..
Ohh thanks for the info!
But still, I have a question:
I've heard about the issue that for some models of Adv it restraints the movement of the kickstarter. What can you say about it? How does the kickstarter work with this side stand?
bigboyxl is offline   Reply With Quote
Old 05-31-2011, 05:36 AM   #1562
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,403
no problem on an '06
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 05-31-2011, 07:56 AM   #1563
frdbronco8
frdbronco8's Avatar
Oddometer: 245
Originally Posted by Zwoehr View Post
What does your spark plug look like? Check that your choke (enrichment) cable is not adjusted wrong or bound up. How many volts does your battery have? Can you start the bike over and over with the E start? Still sounds like a fuel problem (too much gas) since it happens when it is warm.
Plug is new, choke is good, battery is new and it starts every time.
Going to check the valves next.
2005 Yamaha Roadstar 1700
2008 KTM 450 XC (540) ATV
2005 KTM 450 EXC
frdbronco8 is offline   Reply With Quote
Old 05-31-2011, 08:36 AM   #1564
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,519
Thumb
Originally Posted by bmwktmbill View Post
Champ,
On my '02 one of 3 fuses under the dash, check them all, on mine the dash mounting bracket was razor sharp and cut into the fuse wire grounding and killing the lights or causing them to flicker.
A quick file job and a couple of pieces of tape solved the problem of the sharp edge.
bill
Fixed it Thanks Bill.
It was under the dash. The fuse never blew I think water got into it long ago and it finally corroded away. I have a picture but can't figure out how to attach using my iPhone.
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 05-31-2011, 11:29 AM   #1565
Sumi
Sumi's Avatar
Oddometer: 1,790
For my '05 the kickstarter only "works" if the sidestand is in the up position.
Old 05-31-2011, 11:44 AM   #1566
Sumi
Sumi's Avatar
Oddometer: 1,790
Does anybody have any idea about this?
If I stall it, then all the instruments go blank, it seems like there is no power, no lights, no turn signal, nothing. But it starts for the first kick, and electrocity is back imediately - lights, speedo, rev gauge, everything. And they are on good power then - driven from the battery imo.
Last time I've stalled it at home just to make it easier to diagnose.. Pulled off the tank + fairings, moved all the cables, and still power didn't come back.. Where should I start looking at?
If it is running, charging voltage is 14.4V, battery has 13.3V in it, but when it has this wierd power off issue mentioned above, multimeter displays 0.0V in the battery.
Maybe the whole thing isn't related to the stalling though.
Old 05-31-2011, 01:12 PM   #1567
mr. matteeanne
Bender can pass him
mr. matteeanne's Avatar
Oddometer: 14,327
Originally Posted by Just_P_Dirty View Post
somedays- and somedays it isnt there at all...
Same here. First bike I ever had that is diffacult to find neutral??
Don't be surprised.
mr. matteeanne is offline   Reply With Quote
Old 05-31-2011, 02:01 PM   #1568
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,403
mine starts now too after I cleaned out the foam I injected into the bars that filled up the whole starter switch assembly and dried there
Beerthief
Old 05-31-2011, 04:01 PM   #1569
bigboyxl
bigboyxl's Avatar
Oddometer: 325
I had the same problem 2 times:
1. There was a problem with the ignition key connection cable (specifically with contact near the key), I noticed where the problem was when tried to turn the steering wheel to the maximum
2. There was a basic bad contact on the battery
Dunno maybe it will help you.
Old 05-31-2011, 04:05 PM   #1570
bigboyxl
bigboyxl's Avatar
Oddometer: 325
Super, then Im going to get this one!
Old 05-31-2011, 04:05 PM   #1571
Sumi
Sumi's Avatar
Oddometer: 1,790
Thank you! I'll check it out tomorrow.. I tried to wiggle the cables around the ignition keylock, but it didn't make any sense
Old 06-01-2011, 04:07 AM   #1572
AppFan
Oddometer: 336
Center Stand Install
Can someone post pics of where the parts bolt up for the center stand? I've searched and find the parts diagram for the stand itself but not what bolts to where (especially the crescent shaped piece).
AppFan is offline   Reply With Quote
Old 06-01-2011, 06:09 AM   #1573
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,403
here are a couple of quickies if that helps
Beerthief
Old 06-01-2011, 07:37 AM   #1574
AppFan
Oddometer: 336
That is perfect. Thanks!!!
Old 06-01-2011, 07:05 PM   #1575
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,403
glad I could help
Beerthief
Times are GMT -7.   It's 04:06 AM.
